Low Oil Pressure
Billy7707Billy7707 Member Posts: 1
edited September 2018 in Chevrolet
What could break if you have low oil pressure? Something in my engine blew right after the light came on. It was a really loud noise. Caused a lot of smoke and fluid was everywhere.
  • kyfdxkyfdx Moderator Posts: 272,621
    Any and every part of your engine could fail, without lubrication
    Most typically, the engine would seize, or a connecting rod would break, or you could spin a bearing on the crankshaft, causing a rod knock. If you were "lucky" maybe something in the upper engine would let go first.
