2019 Infiniti QX80 Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 264,561
edited September 2018 in INFINITI
Ask your 2019 QX80 lease questions here! Get info about prices, money factor, deals, incentives, and payments.
Check out the 2019 Infiniti QX80 here.
«1345
  • lonjon27lonjon27 Member Posts: 4
    Hi can I get the September MF/RV for AWD 36/39 mos at 15k miles for 2019 models if available. Indiana location. Any incentives are also appreciated. Thanks
  • kyfdxkyfdx Moderator Posts: 264,561
    .00257 MF
    54%/53% residual for 36/39 mo.
    No incentives
  • CornelCornel Member Posts: 1
    Hi can I get the September MF/RV for AWD 36/39 mos at 12 miles for 2018-2019 models if available. Illinois location. Thanks
    .00257 MF
    56%/55% residual for 36/39 mo.
    2018 discussion is here:
    https://forums.edmunds.com/discussion/49797/infiniti/qx80/2018-infiniti-qx80-lease-deals-and-prices#latest
  • TheMachine44TheMachine44 Member Posts: 1
    Would you please provide the current MF/RV for 2019 RWD & AWD models in Nashville, TN for a 36/12 lease? Thank you.
  • MichaellMichaell Moderator Posts: 261,572
    .00257 and 57% (RWD), 56% (AWD base) or 53% (AWD Limited)
  • Coloradogirl55Coloradogirl55 Member Posts: 5
    Hi could I get current MF/RV for 2019 RWD in zip code 35801 36/12 lease?
    thank u
    thank u
    Infiniti coming out with new programs, today.
    Might be 24 hours before we see them.
    thank u
    .00257 MF and 57% residual
  • angdresangdres Member Posts: 16
    Can you provide MF/RV for RWD 36/10 36/12? Are there any incentives? Is 36 month best numbers? Texas 78572
    thank you
    thank you
    .00257 and 58% / 57%
    How many MSDS can I get and how much does the MF get reduced by each? Thank you going to the dealer today.
    Max 9 MSDs, each of which lowers the MF .00010
    thank you
    Is this MF only for excellent credit? Or it’s the same for all credit scores?
    angdres said:
    thank you
    The numbers we quote are for top tier credit only.
  • MZA212MZA212 Member Posts: 355
    Hello, Can I please have numbers for Luxe 2WD 39/10k for FL.
    .00257 MF and 56% residual
  • masterfungmasterfung Member Posts: 36
    Can I get MF and Residual for QX80 Luxe 2WD and 4WD for 77379? 36/12... thank you.
    Either drive
  • MustangTX96MustangTX96 Member Posts: 19
    Hi. Can I get the lease numbers for 2019 QX80 limited edition for 75214. 36/10 & 48/10. Thanks!
    .00257 and 66%
    .00256 and 66%
    One of the rare times when 48 months might give you a better payment.
    .00257 and 66%
    .00256 and 66%
    Did you mean to put 66% or should it be 56%? Just wanted to check. Thanks!
    .00257 and 66%
    .00256 and 66%
    Those numbers don't seem to be right, do they?
    But, sure enough.... two sources show 66% residual for either 48/10 or 60/10.
    I don't know if that's accurate, or a typo.. But, if so, that would be one cheap 60 month lease.
    And, Infiniti programs are scheduled to update on Thursday, so if you are going to check it out, better hurry.
    .00257 and 66%
    .00256 and 66%
    Hello! Since it is Thursday now, have the new lease numbers come out yet today? Again, need the lease numbers for 2019 QX80 limited edition for 75214. 39/10 & 48/10. Thanks!
    .00257 and 66%
    .00256 and 66%
    The old numbers were extended one more day.
    .00257 and 66%
    .00256 and 66%
    Just checking to see that the new numbers were today. 2019 QX80 limited edition for 75214. 39/10 & 48/10. Thanks!
    Hi. New #'s came out today. Can I get the lease numbers for 2019 QX80 limited edition for 75214. 36/10 & 48/10. Thanks!
    36/10: .00253 MF and 66% residual
    48/10: .00264 MF and 66% residual
    Can you check the residual on the 48/10 for Texas again? Did it remain at 66%? Dealer said it dropped to 63% for the 48/10 on Friday. Don't want to start yelling if it was a typo. Thanks!
    I show 66% for 48/10; dealer may not be adjusting the 48/15 residual correctly.
    And, they can't change it; if the contract is submitted incorrectly, IFS will kick it back.
    Still 66%
    The chart shows the 15K/yr residual. He didn't add the 3% for 10K/yr
    Still 66%
    Yep! You were correct. They confirmed it just now. I am super happy!
  • majapomajapo Member Posts: 6
    Zip 60005
    AWD Luxe
    MSRP 76,130
    $10,000 off + $3,000 additional incentive= $13,000 off MSRP
    Lease needed 36/10
    What lease $ rate can I expect that's fair to both sides?
    majapo said:
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    using $63,130 as the cap cost, I get $625/mo plus tax, assuming all fees are paid up front
  • dobby7dobby7 Member Posts: 1
    Residual for AWD Base 36/29/48 please (10k)... 07834. Thank you!
  • larryJ27larryJ27 Member Posts: 4
    Spinning off the discussion with Mustang, these QX80 Limited residuals seem too good to be true, but the IFS website is spitting out really low lease payments on 48/15 and 60/15 leases. Just to compare, can I get the 15k residuals for both the Limited and the Luxe 4WD at 36/39/48/60 mos in Indiana? Sorry for all the data point requests.
    36/39: .00223 MF and 58%/57% residual
    48: .00264 MF and 45% residual
    It's only the Limited that has the cheap long-term leases.
    AWD:
    36/39: .00223 MF and 55%/54% residual.
    48/60: .00264 MF and 42%/37% residual
    LTD
    36/39: .00253 MF and 63%/61% residual
    48/60: .00264 MF and 63%/63% residual
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    Question: Can multiple MSD be used? If so, how many to a maximum allowed? What do they reduce the MF by? Are MSDs legal in Illinois?
    majapo said:
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    Max 9 MSDs, @ .00010 each.
    Yes, MSDs allowed in IL
  • LollerAgentLollerAgent Member Posts: 18
    Hi - could I please get MF/residual/incentives for a 2019 QX80 Luxe 4WD (36/12) in 40515?
    .00223 MF and 57% residual
    Thanks - any cash back/incentives? Looks like a deal above had some.
    Would you also mind giving me the same numbers for a 2018?
    $500 Winter event bonus (Infiniti-to-dealer)
    Please post in the 2018 discussion, here:
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    Yes, MSDs allowed in IL.
    Michael,
    Dealer said that his residuals are 50%, not 66%.
    Where are the residuals derived from that you are quoting?
    I would like to have an educated conversation with the dealer.
    majapo said:
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    Michael,
    It's the AWD Limited that has the high residual; the regular AWD has a 36/10 residual of 58%.
    Confirm the trim, term and miles per year.
    majapo said:
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    Michael,
    It is Infinity 2019 QX80 AWD Luxe
    60005 zip code.
    Please confirm MF and Residual.
    Does MF go down by 0.0010 per MSD? Everytime?
    Do dealers manipulate residual? 58% is taken from where?
    majapo said:
    majapo said:
    Zip 60005
    AWD Luxe
    MSRP 76,130
    Lease needed 36/10
    .00236 and 66%
    Michael,
    60005 zip code.
    My data only shows numbers for the AWD or AWD Limited, so I'll guess that the Luxe is part of the non Limited trim
    .00223 and 58% for 36/10
    Yes, .00010 reduction for up to 9 MSDs - would take the MF down to .00133
    Residual is fixed by the bank; dealer cannot alter it.
    Our sources are confidential, but accurate.
