Dodge Ram Lighting and Electrical Problems
14567810»
  • PaulHRosePaulHRose Member Posts: 1
    The "Auto" function for turning off interior lights and head lights has stopped functioning. What do I do to correct this problem in my 2010 Ram 1500?
  • ray47ray47 Member Posts: 3
    Where are the answers to the problems? This site is a total waste.
  • thecardoc3thecardoc3 Member Posts: 5,852
    There are no answers to every problem, understanding that is what has this site working correctly. Everything needs to be diagnosed and not just have parts thrown at it because "part X" fixed someone else's car. So what kind of a problem are you having and what testing have you done? We can tell you how to test and prove what is wrong if you are capable of following the instructions.
    chuck62 said:
    I have a 2000 Dodge Ram that has started discharging the battery. I have had the alternator and battery checked and all is good. I have narrowed it down to disconnecting the IOD fuse and it will stop discharging. How do I fix the problem?
    shannon16 said:
    I bought a 2004 dodge ram 3500 about one year ago. Shortly after I got it the interior lights alltogether quit working. Next every time it snowed hard last year the running lights would just come on while just sitting in the driveway. I would have to pull the relay until the truck dried out to get them to shut off. Now the bulb out light came on inside the truck. My front drivers side headlight and left turn signal(front and back) are not working. can someone please give me some ideas? I checked every fuse in the panel and replaced the 4x4 switch inside the truck.
    Any help would be great.
    Shannon
    Shannon
    So you have some lights that are stay on and killing the battery? The exact make, model, year, engine and transmission would help.
