Can't believe I corrected Sir Colin on a technical error. Never before and probably never again. :-)
Group buy, LOL. I'm in on it though!
-juice
I have a Milwaukee and Makita. The Makita is better? but I find the forward/reverse switch gets in the way once in a while.
--jay
Cheers Pat.
Thanks for sharing Pat.
I like the carriage.
-Dave
Did you carve a replica of your GT? :-)
-juice
-Brian
I can't get this stupid grin off my face!
-juice
http://www.info.gov.hk/td/eng/services/20030208ret.htm
If you go here, you'll find links to a description of the process, and also results of two previous auctions in January of this year.
http://www.info.gov.hk/td/eng/services/auction.html
Remember dollars are HK$, worth about US$7.75 each.
I haven't yet found the record-breaker. Have fun looking.
Steve
2 women, a waterbed, and a cordless screwdriver ... a comedy of 'errors' ...
Ok .. when I 'ran away from home' after 25 years of marriage I moved into an apartment without a stick of furniture of any kinds. A friend of mine had a few things in the garage and she brought them over on a trailer .. including a kingsize waterbed that had been put up and down a number of times. I was happy as that's what I had slept on for quite a few years before moving out. (Probably was 'against' apartment rules, but I was on ground floor and didn't check!) It was the kind with the soft vinyl mattress, the internal baffle, and the hard frame. The "platform" of particle board on which the bed sat had been attached a number of times to the frame. The base of the bed (for those who don't have this type of bed) does not come all the way to the edge, but is recessed a bit. Shortly after setting it up, I put too much weight on the end of the bed, which pulled the screws out of the platform. The bed proceeded to attempt to 'ooze' out between the platform and the frame around the sides. Waterbeds also happen to be extremely heavy. I managed to get the mattress basically back where it belonged and wedged a heavy pot underneath so that it would stay until a more 'permanent' fix (and help) could be arranged.
That weekend the owner of the bed came over to help me fix it. We knew the real problem was that the braces between the platform and the frame needed to be attached in a little bit different place since the holes had become too large with the several taking aparts and putting ups the bed had been through. We went to the hardware store and bought the "L" shaped connectors and new screws. She brought her power screwdriver which we'd already used when we set the bed up. (You might need to know that people who have known us a long time refer to us as either "Lucy and Ethel" , "Laverne and Shirley" or "Thelma and Louise" according to the circumstances.)
As you will readily see, the first mistake is that we thought we could fix this without draining the bed. I got ON the bed and pulled (rolled) the full waterbed mattress away from the end of the bed so that she could attach the bracket to the side frame. (That part went without a hitch.) However, I had to get off the bed and behind and almost underneath her to push UP on the platform in order for her to connect the bracket to the platform. SHE had to hold the waterbed mattress back with one hand while putting the screws in the platform with the other. Everything went fine until the very last instant when the mattress "slipped" .... right into the whirling blade of the screwdriver ...
So .. now we have a full king-size waterbed mattress with a HOLE IN THE BOTTOM OF THE MATTRESS with water FOUNTAINING into the bedroom carpeting. She's frantically grabbing at the mattress trying to get the hole above the water and of course it's wet and slippery now. I'm running to get all the towels I can find to mop and soak up water.
She ended up with the mattress where it could be 'contained' and I had to go to WalMart for a patch kit!!!! Knowing me (and the fact that I had worked in this town in schools for 14 years), she's yelling do NOT stop to talk to anyone .. get the patch kit and get back here!
Got the kit, we patched the mattress .... and then drained it so we could make sure the patch was good and tight ... lol
Unfortunately .. that wasn't the ONLY waterbed story over about an 8 month period .. you'd think neither of us had any brains if I told them all ... lol
Feet!? What crackhead do you have for a weatherman? Right now they are saying 2-4" tonight, another 2-4" tomorrow. I do notice there are no predictions for Sunday, however. So maybe there's the rub.
Brenda
-juice
Man what I wouldn't do for a couple of feet of snow around here...
Cordless: 18v with a 1/2" chuck is the minimum I'd consider after having a 9.6 volt 3/8" unit and upgrading to an 18v Skill Warrior. The Warrior was built by Bosch and is nearly indestructible - $100 on sale. Battery is good for several hours of near continuous use (drywalling).
This car just is not willing to let me pay off the Sube before getting into another loan... We've put $2k into the Sentra over the last 18 months - left front axle, right front axle, alternator, tires, rotors, airbag control unit, oil pressure sending unit, not to mention the leaking front crank seal and left axle seal which I'm ignoring for the time being. It's getting to be a car payment.
I'm looking at used Sube's now. Might not be able to wait and buy that mini-van I've been looking at for the last 2 years. Sigh.
Brenda-
AGES?!!!
No wonder they washed it...
the techs didn't want to get themselves dirty. ;-)
-Dave
I was looking at some cordless drills during lunch. The 18V models are pretty heavy and clunky. Is there much of an argument for going for a smaller capacity drill just because the size and weight is too much? I'm just getting started with this home repair stuff so I don't think I'm going to be jumping headfirst in using the drill to sink holes into concrete! Or, will I regret not getting a bigger drill later on?
Ken
We got just 2" here, but it was packed snow and slush. It's above freezing, so we're OK for now, but tomorrow it's supposed to be in the teens, with the big storm, maybe a foot.
I bet you had more a little north of us, we were right on the snow/rain line, sort of.
-juice
There's no way I would've paid to replace that part. If it was throwing an airbag warning light, disconnect the light instead.
The rest of the items in your 18 month shopping list, yeah you can't probably do without those.
-Colin
My brother is in construction and has had bad luck with the yellow brand (mostly bearings going out). Go with blue and you will be happy.
Eric
http://www.makita.com/html/impact_drivers.asp
bit
Cut your losses now and let it go.
Cheers Pat.
Serge
Cordless: 12v Porter-Cable and 12v Ryobi, in case we have to put up our hurricane shutters during season
Bob
Hey, didn't we meet her @ the Auto Show? ;-)
So far we got zilch up here in NYC.
-Dave
I doubt we'll ever see one though... Who knows, perhaps when they start building turbo Legacys in Indiana, maybe that state will use a few—to help support the local economy, of course.
I think the time may be right to re-investigate that possibility.
Bob
Bob
2.5l turbo WRXs for the PDs would be awesome. Forget the legroom in the rear. Felons don't need the legroom.
Hee hee they might even enjoy the ride to Central Booking.
-Dave
In any event, I think the power characteristics of the low-boost 2.5 turbo found in the Forester, combined with an automatic, would be perfect for police (or fire) work—especially with AWD. The Forester, of all Subies is the easiest to get in and out out, and would probably make for the easiest transition for those used to the hulking Crown Vics.
Bob
PS: comparing 3/8" chuck drills here...
Craig
For Paul's interest, Forester GT Turbos are used exrtensively her in Australia for ambulance and police work. The local ambulance service has a pre order for 26 of the first Forester XT as soon as they are available to replace their now aging fleet. The Police are also after soem new ones.
Cheers
Graham
The Dunlop Sport A2s handle great in the snow--it's just the slushy tire ruts that make driving a little tricky.
Let me see if the Giant is open...and return those DVDs to Hollywood Video...ah don't you just love Suby-weather?
Suby = No shovel required (except on my sidewalks)
Michael
Bob
Bob
Len
So far we've got well over 20" of snow, and it's supposed to continue until sometime tomorrow. Weathercasters are saying this could turn out to be one of the biggest snowfalls to hit Maryland ever, possibly 36" or more! In fact a few are saying this snow storm could end up being the biggest this state ever recorded!
If anything, this storm should do wonders in helping to put our drought behind us.
Bob
Bob, my early estimates were about 1.5 inches per hour. Who knows how deep the snow is now? I did see one plow in my neighborhood, but that was around 9:30 a.m. At least my work is closed tonight!
Michael
yet.
The Weather'persons' are projecting a foot or more.
-Dave
Brenda - really enjoyed your story. Two women, a screwdriver and a waterbed lived up to the hype!
Lab reports on my daughter came up positive on the Lyme Disease, so she is on anitibiotics and Advil. It is hard seeing my little girl moving like an old woman from stiff joints.
Steve
Steve
So now questions for the experienced: Application is '02 OBW - base model. I pulled the rubber covers off the mirror mounts and the wires for the tweeters are there. But I checked under the drivers (power) and passengers seat and cannot find an unused harness. Where does the sub-W go, and should it be pre-wired?? Will I like my present??
Steve
Steve, I hope your daughter gets better soon. Sounds scary! When I lived back in CT, I knew somebody who got Lyme disease (and they actually live near Old Lyme, where the name originated). They caught it before it got too serious, and seemed to make a full recovery. I can't remember -- I don't know if you can actually rid it from the body or just keep it in remission. In any event, my friend is doing fine many years later.
Craig
Apparently there are two adjustment knobs on the sub, probably for the crossover frequency and dB/octave slope. I need to tweak the unit in my wife's Forester, as it seems too boomy sometimes.
Craig
Steve, Sorry to hear the news about Emily, but she should begin to feel better shortly. Lyme is a nasty disease if left untreated. Most cases happen in warmer weather, but you can get Lyme at any time of the year. My mother was bitten by a tick several years ago in February! She had already had it once before so she quickly went for treatment as soon as the rash developed.
Lyn
The 4 window switches are grouped in one module and the lock button is another module. So, it would not be possible to share the lighting between the window button (AUTO) and the lock switch with a fiber optic cable.
I did not dissasemble the lock switch module, but I would bet there's a place inside for an LED. There is actually an unused connector on the lock module with 3 pins. It may be that this connector would be for illumination, I don't know. It was getting cold and late and I decided not to take it apart. I think the bottom line is that it seems to be an easy project if someone wanted to add illumination to the lock switch on an Impreza or Forester.
Craig
