JEEP COMPASS 2019 - no start
Just got in my Jeep tried to start it. Break would not allow me to push button to start. On screen it said ON not RUN. When I opened door of car it said car told me to press break and push start but it would not work.
Best Answers
zug
Member Posts: 2
Jeep has informed me there is a software update coming out in a few weeks to fix this issue on the 2019 Compass.2 -
530ninja
Member Posts: 1
Just got my 2019 jeep compass sport out of the shop after it being in for over a month waiting on jeep to come out with the update. Its back in the shop already. Mind you the jeep only has 500 miles on it. Found that we can pump the brakes till the vacuum goes out of the brakes and replicate the issue everytime. I'll post again after I find out what Chryslers new excuse is1
Answers
Not a great "start" for a 2019 Jeep. Did you try jiggling the gearshift lever. The Jeep will not start if it thinks it is in Drive or Reverse. This is called a "Neutral Safety Switch" and it could have also been the problem.
not sure why it worked an hour later while waiting for the tow truck which I cancelled.
My suggestion would be if it happens again, and then you try a restart say 3-4 times and it won't start, then have it towed to the dealer. That gives them a better chance of locating the problem.
