2019 Infiniti QX80 Lease Deals and Prices
135
  • Mpop302Mpop302 Member Posts: 12
    Mpop302 said:
    April MF, incentives and residual on qx80 ‘19 in 91607
    10/12k 39/mo thank you
    bump
  • MichaellMichaell Moderator Posts: 266,493
    bump
    RWD or AWD?
    If AWD, base or Limited?
  • FrankieFrankie Member Posts: 37
    What are the RV/MF/Incentives for 2019 QX80 Luxe 4WD for 36/12 in 07731?
    Limited 4WD - .00166 and 50%
    no lease incentives
  • kyfdxkyfdx Moderator Posts: 269,472
    Base: .00245 MF and 53% residual
    Limited: .00166 MF and 50% residual
    For either 36 or 39 months.
  • KAMKATAKAMKATA Member Posts: 9
    What are the Residual and MF for the QX80 AWD and RWD Luxe for the month of May for Zip 77407 and Any Manufacturer Incentives?
    TIA
    TIA
    39/15
    .00196 MF
    51%/52% residual for AWD/RWD
  • bluelikejazzbluelikejazz Member Posts: 14
    Please provide residual, MF and any incentives for QX80 AWD 48/15 for 23230. Thank you!
    48 month term not supported, this month
    39/15
    .00196 and 51%
  • We just did one, end of April 2019.
    2019 QX80 Luxe 4WD w/Pro Assist Pack + Split Bench + Premium Paint Color.
    MSRP: $72,500. Selling Price: $64,754. Residual: 56%.
    Zip 33462.
    39 month lease, 10K miles per year, $0 down only first month payment, all taxes included.
    $939 per month.
    Hope this helps.
  • mod220220mod220220 Member Posts: 15
    Can someone help out, negotiating a 2019 QX80 Luxe AWD
    what are current MF and Residual, 10k/39, zip is 43220?
    Zip 33462.
    $939 per month.
    Hope this helps.
    In plugging in your numbers and 7% tax rate (33462 zip), I get a MF of .0024, is that correct?
    Also, the car's sticker has "Destination Charge" of $1,395, is this negotiable, and should this be included in the MSRP number used to calculate residual? I would think not, as it's not tied to the car's actual value.
    .00196 MF and 54% residual
    It is part of the MSRP and used to calculate residual.
    Use the bottom line of the factory window sticker, including all factory options and destination.
  • Hi mod220220,
    Yes it looks like 0.0024.
    Regarding destination charge: It is part of MSRP but try to cut it off the top. I built it online and it came to $73,300 but I remember my dealer over the phone told me MSRP was $72,500.
    You can try to negotiate a better selling price than I did.
    thanks, they had me at .00226, new car loans are in 3-4% range, hoping to end there but not sure how much they will move
    MrElusive said:
    Hi mod220220,
    on their website they show MSRP as total price minus Destination Charge, obviously the higher that number is the better for residual balance and lower payments, so will try and use the full amount...
    how much room do they have with Money Factor? I would assume there is some correlation with APR and MF?
    mod220220 said:
    MrElusive said:
    Hi mod220220,
    It ihttps://forums.edmunds.com/post/quote/52421/Comment_5704597s part of the MSRP and used to calculate residual.
    The MF we quote is the best rate for top tier credit.
    Infiniti does off an MSD program - max 9, each of which lower the MF by .00010.
    mod220220 said:
    Hi mod220220, Yes it looks like 0.0024. Regarding destination charge: It is part of MSRP but try to cut it off the top. I built it online and it came to $73,300 but I remember my dealer over the phone told me MSRP was $72,500. You can try to negotiate a better selling price than I did.
    It ihttps://forums.edmunds.com/post/quote/52421/Comment_5704597s part of the MSRP and used to calculate residual. Use the bottom line of the factory window sticker, including all factory options and destination.
    on their website they show MSRP as total price minus Destination Charge, obviously the higher that number is the better for residual balance and lower payments, so will try and use the full amount... how much room do they have with Money Factor? I would assume there is some correlation with APR and MF?
    The MF we quote is the best rate for top tier credit. Infiniti does off an MSD program - max 9, each of which lower the MF by .00010.
    Sorry but what is current MF?  Why wouldn’t it be higher than others who has .0017 when rates are so low right now?  How exactly does MSD work?  Thanks guys!
    mod220220 said:
    mod220220 said:
    mod220220 said:
    MrElusive said:
    Hi mod220220,
    RWD or AWD?
    MSD is multiple security deposit. Each one is the amount of the monthly payment, rounded up to the next highest $50, and will reduce the MF .00010. You can make a maximum of 9 of these.
    RWD or AWD? What lease term and how many miles per year? MSD is multiple security deposit. Each one is the amount of the monthly payment, rounded up to the next highest $50, and will reduce the MF .00010. You can make a maximum of 9 of these.
    AWD, 10k/39
    zip is 43220
    @mod220220
    .00196 MF and 54% residual, as we noted on your first request
    9 MSDs would bring the rate down to .00106 MF
    It doesn't matter what the rates are for other makes. This is the program that IFS provides on this vehicle.
    edited May 2019
    thanks!
  • aekchianaekchian Member Posts: 66
    What are the terms for 48/10 for the base level QX80, 91206?
    We only have the info up to 39 month term
    39/10
    .00172 MF
    52%/53% residual for AWD/RWD
  • quesenberry96quesenberry96 Member Posts: 20
    Could I please get the mf and rv for 2019 base QX 80 for 36/15 in zip 33614?
    RWD or AWD?
    RWD or AWD?
    RWD please.
    RWD or AWD?
    RWD please.
    .00172 and 50%
  • cmcfarling09cmcfarling09 Member Posts: 1
    Looking for MF/RV for a 2019 QX80 Luxe 4WD in Indiana
    .00172 and 49% for either 36/15 or 39/15
    $2500 summer bonus
  • kar_freakkar_freak Member Posts: 148
    Hi! Looking for 24/36/39 15k lease numbers and incentives on 2019 QX80 Luxe RWD in TX. Are numbers same for the base RWD?
    .00172 MF
    53%/50%/50% residual
    $2500 summer bonus
    On all RWD trims
  • ATMBATMB Member Posts: 2
    What are current MF & Residual for 10K AWD Luxe
    39/48/60 Month
    39/48/60 Month
    What is your location?
    39/48/60 Month
    Sorry 66210. Thank you in advance.
    ATMB said:
    39/48/60 Month
    .00172 and 52%
    $2500 incentive
    36/10 or 39/10
    No published 48 month numbers
    What is the MF / RV for 2019 QX80 Luxe 4WD 36/12K 07731 and any incentives?
    .00172 and 51%
    $3500 incentives
    $2500 summer bonus
  • therealbofatherealbofa Member Posts: 59
    Hey guys - considering a '19 QX80 LUXE 4WD in 80104. Can you share the MF and residual for 36/12 (or 39 if its a better deal) and any incentives?
    .00172 and 51%
    $2500 incentives
    Either 36/12 or 39/12
    Hi! Looking for lease numbers, incentives, conquest and loyalty for 2019 QX80 RWD Luxe for 24/36/39 15k in TX.
    .00172 and 53% / 50% / 50%
    $2500 summer bonus
  • mpgxsvcdmpgxsvcd Member Posts: 179
    Could I get the numbers for an AWD QX80 Luxe in 27502 for 39/15k?
    .00139 and 48%
    $3500 dealer incentive
    $2500 summer bonus
    Can I get updated numbers for October please?
    $2500 summer bonus
    .00139 MF
    51%/48%/48% residual
    $3500 incentive
  • uglygorillauglygorilla Member Posts: 2
    What are the RV/MF/Incentives for October 2019 QX80 Luxe 4WD for 15K miles 36 & 39 in 08535?
    .00139 and 48%
    Total Cash of $7000 includes:
    $3500 IFS Lease Dealer Cash - Lease Markets exp. 10/31/2019
    $3500 Dealer Bonus Cash exp. 10/31/2019
