2019 NSX
kerbkerb Member Posts: 204
edited May 2019 in Acura
Greetings Moderator,
Could you pls. provide the buy rate and residual for 24, 30 and 36 terms with 5k, 7.5k and 10k miles, together with any incentives (33327).
Thank you in advance.
  • MichaellMichaell Moderator Posts: 270,853
    10K
    .00215 and 55% / 53% / 50%
    no lease incentives
    Add 1% for 7.5K or 2% for 5K
  • ArgoteArgote Member Posts: 2
    Wow, those residuals seem much worse than the used NSX market seems to indicate.
    Are they the same for 94065?
    The Acura lease numbers are national.
  • The_0zmanThe_0zman Member Posts: 16
    Can we have money factor and residual for zip 20705.
  • kyfdxkyfdx Moderator Posts: 275,734
    .00215 MF and 46% residual
  • 03qx03qx Member Posts: 110
    Can you please post the rate and Residual for the 2019 & 2020 NSX for 36 Mos and 10K Miles. Thanks
    2020 - .00215 and 53%
    2019 - .00215 and 48%
    Hello
    Can I have the residual for 7.5k 36 months for zip 21117 as well as the money factor. Thank you
    The_0zman said:
    Hello
    The lease program for the 2019 NSX has ended.
    The_0zman said:
    Hello
    I am sorry, could you provide em this for a 2020 please thank you
    The_0zman said:
    The_0zman said:
    Hello
    .00215 MF and 54% residual
