Then there is the SOOB side to the Bimmer clan....... 2002 owners!! Nice folks, friendly, remind me a lot of the people here. Met a bunch at a party that tried to talk me into the world of 2002...I dunno if I am ready to tackle one though. Still, one guy's wife has an Outback, another had a GL for part hauling, and yet another just bought an RS for foul weather/primary driver. They're all on modest incomes and go junkyard raiding every weekend for parts they can turn on Ebay to feed their 4-speed passions.
bitman, it's a tough call. If there is a weld that hasn't been made up in there, and your vehicle's structural integrity is in question, then heck yeah! The headliner pull is worth it. If on the other hand it's some odd little groan associated with two parts rubbing together oddly, then the headliner pull isn't worth the effort. You have to listen, consider, and decide, I guess.
Good luck,
-wdb
mike
-wdb
-Frank P.
I think about the only vehicle that looks good with cladding is the Vehicross, it goes with the whacky looks of the vehicle in general, but hey at least you know a person actually installed the cladding by hand on it!
-mike
My headliner was removed for the moonroof. You do notice that fact, too. There are some dings in it, and the B-pillar on the driver side has a broken clip. I'm sure it's a 25 cent part, but a pain nonetheless. You may end up with more rattles than you started with.
Ask if they can apply lube to some parts without removing the headliner.
Loosh: when I read '97 I was going to find the guy and offer $6k!
wdb: plastic cladding is functional in that you get a ding proof surface, a la Saturn. If it's not painted, it's also scratch resistant. It looks better on some (Forester L, base Grand Cherokee) than it does on others (Echo, Aztec).
-juice
PS I've seen an RS lift it's inside rear tire too!
The way cars are spot welded and glued together with robots these days, I would be very skeptical of a manufacturing defect. That part of the manufacturinbg process has very good quality control.
Craig
If work is done by outside repair shops, can the Subaru owner manually update his/her files?
Bob
http://biz.yahoo.com/prnews/001204/nj_subaru_.html
A few months ago I read an article on an automotive site that showed that 2wd vehicles/w snow tires were better in typical winter conditions than 4wd vehicles/w radials. How true it is.
The stock Wilderness tires on the 2K OB might as well be summer tires for all I care, they are absolutely useless on slush and snow. I get much much better traction with my MX-6 and Yokohoma Guardex's.
Moral of the story: AWD in snow without the right tires won't help you combat winter.
2wd + snow tires > awd + radials
awd + snow tires? well that's a different story
-- ash
Subaru of America, Inc keeps a database of the information collected by this site, on your behalf, to allow you future access to your information. Other uses of this information may include updating our customer records, fulfilling e-mail requests and sending you important information concerning your vehicle, as well as promotional material about Subaru products and services.
I'd really like to be able to say "no thanks" to the promotional material. I'm not saying I will, it depends largely on what and how much gets sent; but I feel very strongly that the option should be available to turn that stuff off.
-wdb
There are exceptions, though. On long down hills, if you use a lower gear to slow down, all four wheels are in play.
Also, with AWD in corners you're less likely to break traction when slowing down or speeding up.
-juice
It really is a minor thing that I can only hear at very low speed. So either I can drive faster (should be fun entering the driveway) or ignore it.
I think I might see if I can once again prove to the wife my OCD is real and get her to back in an out of the driveway a few dozen times with me in the back seat . I'll put a little pressure on the moonroof mechanism and the roof rail and see if I can make it stop. Even knowing what causes the groan will relieve some of the anxiety.
Maybe the front strut brace I ordered will stiffen things enough to stop the groan. Wouldn't that be nice?
bit
How 'bout spraying some lithium grease in the affected area? A few bucks a can and it does not harm rubber and plastic surfaces (which is why you should not use WD40 in certain areas).
Plus, with the little straw they provide, you can aim it throught the dome light opening (if you're willing to remove that).
-juice
Dennis
-mike
It is however reasonable to agree a deadline for resolving the problem. Three or six months is usually a fair thing. Any dramas which develop after that time are really not the manufacturers problem.
Do get any such agreement noted a get a warranty reference number from Subaru to avoid any hassles later.
Cheers
Graham
Dennis
bit
Even though my OB wasn't as sure-footed as I would've like, I had a BLAST! But, I must get better tires, a come-along and good tow rope if I attempt something like that again.
Snow- I really had no problems last winter in my OB; I am a little mystified by the griping. Baltimore was completely snowed under, and I spent 2 days straight ferrying family and co-workers around
Dennis: sounds iffy. Tires are designed a certain way, and modifying them like so will surely change their performance. You may get better snow traction, but lose dry traction and quietness, and maybe even tread wear.
Brett: I bet simply airing down to 20psi would have made a big difference. Just make sure you have a pump with you to air back up later!
The 2000s had the LSD optional, with the AWP. For 2001 it's standard though.
Loosh: maybe you're just a great pilot! Nah, it's the Soobie...
-juice
Juice: You're absolutely right. I forgot to lower the tire pressure until I was in the middle of it. It did help tighten up the steering, but powering uphill would still cause me to go slideways.
One bummer: didn't get pictures taken, the car looked fantastic afterwards!
If not, feel free to call us and start one. If you prefer not to, just keep the RO's from the dealer. That can document the concern in warranty (which may be why some folks get help beyond warranty - not for sure - but it makes sense based on how we operate). But. . .if you have a problem, it would be good to let us know now so we can check further. The groan you mention does not ring any bells with me. I think we'd like to check it out further.
Obviously I hit the right spot with the lithium grease but it just changed the characteristics of the problem. More obvious now than before.
I did a trip to the coast on a twisty road to work in the grease but it didn't change. Going to give it a little time to work. Can't ask my wife for another ride in the back seat with my head out the moonroof or she will surely drop me off at the nut house.
bit
bit
My cousin has a 2000 OB, and last summer we took her car and my trooper on a few trails near our houses in the adirondacks, although I could go over bigger rocks faster than she did (she had to crawl over the rocks to save the front air-dam) on one trail she was able to go much further because she could make a smaller radius u-turn than I could ever have done with my trooper.
photos @ http://www.iace.com/ia/trooper
-mike
Bit: sounds like patching a leaky canoe -- fix one leak and another pops up. But, I think you're hot on the trail, so keep obsessing.
Craig
I'll be back tonight!
Cheers,
-wdb
Craig: my Jeep buddies would always air down for mud/dirt/gravel/sand, but not snow.
Patti: the Soob will also go places the Hummer won't. Huh? Yep, the Hummer is so wide it simply won't fit on many narrow trails.
Bit: I'm guessing the moonroof tracks are out of alignment. Time for a dealer visit.
Kate: don't sweat it. Let them take their time. We're talking about frame realignment. They'll also probably order parts more than once, as they go along and find out what is damaged.
Still sorry to hear about that. How's your daughter feeling?
-juice
1) what type of highway fuel economy should I expect (55-65 mph). Real world as opposed to EPA.
2) Tweeter kit - worth it or not?
3) do you wax the painted plastic bumpers on the exterior?
Chip
Juice- I'll try and get a picture to you. May take a few weeks because I have to do it the old fashioned way.
Juice- Of course Kate's sweating it. How'd you like to be without Sandy for 5+ weeks? :-(
FYI: speaking from experience, with the proper equipment, frame realignments don't take any time at all.
Kate again (OT)- read in today's paper that 30% of national sales of homes for more than a million dollars are in the Bay area! Guess where I'm not moving!
-Frank P.
1. MPG varies significantly due to driving habits, gas formulation, time of year, altitude etc. On my Forester, I've found the EPA's figures to be pretty accurate.
2. Tweeter kit. Definitely worth it and is pretty simple to install yourself (order from Darlene when she gets back form being sick).
3. Yes, wax the bumpers also. They aren't subject to rust (obviously) but the paints the same as on the rest of the vehicle and it still needs protecting.
-Frank P.
Yeah! Another GT wagon.
I have a 00 GT wagon with 5 speed and did an 8,500 mile road trip in Sept/Oct. Over the 7,600 miles that I kept track of mileage I averaged 28.3mpg. Mostly highway 55-80mph with a third or so using cruise. But it also included a lot of mountain passes, rural 2 lane and some urban driving.
Love my GT.
bit
bit
Let me know about the tweeters, since I'm also mildly interested. The ones on my Miata seem to make a big difference. Too bad the CD skips.
Yes - wax all painted surfaces. Even wheels if they're painted (vs. polished).
-juice
Soon we'll know if three baby seats fit in back. It's their 3rd!
-juice
Also did a little more sleuthing with the help of friend and pro sheet metal bumper. He listened then pointed to a spot inside the roof (through the open moonroof) were the inner and outer roof panels begin to converge. We wedged a little piece of foam rubber in there. No groan and no clunk. So I am still going to visit the dealer and tell them whats up and ask for their blessing just in case. But at the very least this saved pulling the headliner for now.
bit
-mike
Maybe Patti can relay this to the factory -- sounds like they need an extra squirt of glue up there.
Craig
I'll keep my OCD fingers crossed. I think my marriage survived this one though I am sure I am one step closer to being committed.
bit
2) Yes! Consider the powered sub too. Both are a noticeable and valuable improvement in sound quality, more than sufficient for those of us with less than audiophile eardrums.
3) Yes.
Cheers,
-wdb
