Subaru Crew - Meet The Members II
1354355357359360692
  • c_hunterc_hunter Member Posts: 4,487
    Anybody else watching the WRC 03 season marathon on Speed TV? Tune it if you're not doing anything else, it's a fun show.
    I've been watching since 9am!
    Craig
    No one really knows for sure if there's going to be a Crew chat tonight, but the link is up, and Bob reports he's going to try to open it and see who shows. (It would normally be tonight, right? <g>)
    Condolences, Paul.
  • lark6lark6 Member Posts: 2,565
    I'm in the office for the first time since Dec. 12 so plenty of catching up to do in all areas.
    My condolences go out to you, Paul.
    Good luck to Bob and juice as they head to Detroit. Enjoy the trip - hope weather cooperates - and be prepared to be grilled to the nth degree about the smallest detail of the new Subie product offerings. I'll be looking for your reports here!
    Ed
    Sorry the hear that Paul, let's hope the year picks up for you.
    Missed the chat, if there was one!
    OK, question for the IT gurus (and I'm supposed to be one). I have a Linksys wireless router up and running. Cabled PCs connect just fine, I've had two running simultaneously.
    But my notebook with a Wireless G card does not connect. Or it does, it gives me the signal strenght, light goes green, but I open IE and no dice, no data.
    The Linksys card's light it *not* on, so it does not see the Wireless PC. The PC says it does, but it doesn't.
    I've got the SSID correct, the channel, etc. The Router has a password, but I don't see where to enter it. The card is a AirPlus Xtreme G. I installed that software and the Linksys software on the notebook.
    Any tips? I'm trying to get this to work to take to Detroit, in case there is a Wireless G connection in Cobo Hall or at the Hotel.
    -juice
  • dcm61dcm61 Member Posts: 1,567
    Is wireless enabled on the router?
    Is encryption set on the router but not on the notebook card?
    The router is a B or G, correct? A G card will work with B or G but not A.
    Edit: Not an IT guru (not even close); but did manage to set up wireless at home and at parent's house. Belkin router (B) and notebook card (B) at home. Belkin router (B) and SMC wireless desktop adapter (B) at parent's. I only paid $30 (after rebates) for my router & notebook card and $10 (after rebates) for my parent's router & desktop adapter!
    DaveM
  • locke2clocke2c Member Posts: 5,038
    also check that MAC filtering is not enabled on the router. or rather-- I would suggest that it IS enabled and input your laptop's MAC address.
    -c
  • nygregnygreg Member Posts: 1,936
    Sorry to hear about your loss. I am hoping 04 brings better times as the past 3 have been a challenge.
    Greg
    Yep, there was one last night. Had a good turnout, with some new faces too. :)
    Bob
  • goneskiiangoneskiian Member Posts: 381
    Paul - Condolences from Seattle. Have a safe trip.
    Wireless? What's that? ;-)
    I caught a couple hours of WRC Marathon last night before dozing off on the couch. Nothing like a good sleep after a day of skiing in the fresh cold mountain air. We're having a wonderfully cold wet winter here in the N.W. Lot's of great snow! ;-)
    Happy New Year!
    -Ian
    Both are Wireless G. WEP Encryption is disabled on the router, and on the notebook.
    Hmm, how do you enable wireless on the router? The default setting is for either cable or wireless, I believe that's what I read.
    Signal strength is 94%, it sees it, but no data.
    I'll check the MAC filtering, but I don't think I'd been using it.
    No biggie, I may just wire the house myself, a good buddy used to work with that type of stuff. Plus it's safer. I'd like to have connections in 4-5 different places, including on the deck outside! :-)
    -juice
    Definitely stick with it Juice. I have two laptops and a G4 Cube using wireless at home, and there's no way I'd be able to do it with wires. It's nice to be able to use the laptops all over the house, garage, and yard! I often have a laptop in the car when I do projects and need info from the web.
    Unfortunately, all my experience is with Apple's Airport systems, so I can't offer much help for a PC setup. I guess the first step is to make sure that the laptop can connect to and administer the wireless base station. Step two is to get to the local network (and/or internet). This requires the proper network settings on the basestation *and* the laptop has to be "allowed". On Airports, this is done either via password or using MAC-based access control. If they are not "allowed", clients can connect to the basestation but not see the network (and that sounds like your problem).
    If using MAC-based access control, make sure you use the MAC address of the laptop's wireless card and not the one for ethernet.
    That's about all I know! Hope something might be of use. If you can tell me more specifics about your network setup, maybe something will jump out at me.
    Craig
    PS: my setup is
    [cable modem] ----- [airport] (((((( [clients]
    I can also stick a hub in there and have Airport serve wired clients as well (it's both a basestation and a router)
    I think I have to change the settings on the base station. I'd thought the default settings allowed a connection, but maybe not.
    -juice
  • bluesubiebluesubie Member Posts: 3,497
    as your IT consultant. ;-)
    -Dennis
  • fibber2fibber2 Member Posts: 3,786
    Paul - sorry to hear about how your new year began.
    I slept thru New Years Eve. It was a week long marathon with family and friends. Fun, but exhausting. I crashed on the couch about 10:30pm, and missed the ball drop.
    Somehow my Subi has become the parking lot punching bag. Two more scrapes on what was a clean two year old. I guess if that is the worst that happens in life, count myself lucky....
    On the London cab issue, the wide rear doors & flat floor allow a kid in stroller to wheel right on board without unloading. It made it easy to get around town when we visited family a few years ago.
    Steve
    I really think my notebook is not working properly, it's ancient. I'll get a newer one and try it again. I checked everything to the last detail and still did not get data flowing. I hope I have time tonight, so I know it'll work in Detroit.
    Any last words of advice? Besides dress warm? :o)
    -juice
    Uhhhmmm....have fun?
  • bat1161bat1161 Member Posts: 1,784
    Advice: Take lots of pictures and notes, and ENJOY!
    Mark
  • I completed all my interviews with the company in Wayne, NJ, during Christmas week. They offered me the job, but I turned it down after serious consideration. The job was great and the Wayne area was nice, but I was concerned about the company's long-term viability against some ferocious competitors (Wal-Mart and Target). Considering corporate performance would determine a healthy part of the total income, I just wasn't comfortable with the risk/rewards.
    I just wanted to say "thank you" to all the NJ Crew members who gave me input. It was a tough decision to make, and even now I sometimes wonder if I made the right one.
    -Ty
  • hypovhypov Member Posts: 3,068
    Ty-
    If your gut tells you not to take it, it's the right decision. Whatever your conscious tells you there after doesn't matter.
    -Dave
  • bigelmbigelm Member Posts: 995
    Mark - you reminded me to charge my camera battery!
    You think 200 pics is enough? :o) Low-res, or high-res? It'll probably be low-res to share on ImageStation anyway.
    Ty: always smart to play it safe.
    -juice
  • subearusubearu Member Posts: 3,613
    I take 'em at high res so I have the 'originals' (aka negatives). Then when I upload 'em to ImageStation, I convert 'em all to a lower resolution to save space. Not that ImageStation has disk usage limits though, I haven't seen 'em do that yet.
    That way if someone wants a higher resolution image, you have it available.
    -Brian
    Yeah but it'll take longer to upload, that's the trade-off I'm concerned about. I'll probably compromise somewhere in between.
    My plan is to be on these boards tomorrow night and Wednesday night from the hotel. I should have a laptop with me and hope to get a connection in the room.
    We come back Thursday so that chat should be real fun, too.
    -juice
    So I was swapping memory out of a co-worker's PC, and I mentioned the show. One thing led to another and pretty soon we were talking Subies.
    Well, this guy owned a GL for 25 years (!), 160k miles on it, never let him down. He has an Avalon now but is looking for something sportier. I'll get him a GT brochure...
    -juice
    Juice-
    Check around the hotel for a wireless connection. On the 48hrs one of the guys "found" a connection in the hotel lobby, then in a room facing the street.
    Mark
    Looking forward to hearing from the "insiders" at the Detroit show!! There's also a new topic over on the News & Views board where the show discussion has begun. Here's a link:
    Detroit International Auto Show!
    PF Flyer
    This time in a book (first for me). :-)
    "The End of Detroit" by Micheline Maynard, page 294.
    I have to get a copy to see exactly what I said, LOL.
    -juice
    save 'em locally on your hard drive as the larger files, convert 'em to smaller sized jpgs (save the originals to a backup folder or something), THEN transfer them to ImageStation.
    -Brian
    Yup, but that'll take time. It's a tough call. I want the high-res images for later. I'll probably make 'em some where between.
    -juice
  • ladywclassladywclass Member Posts: 1,713
    re the job decision ... I think a lot of times we 'overthink' particularly AFTER making the decision ... I try to remember this ... "make the decision and then MAKE IT THE RIGHT ONE" ... once it's made it's all you can do ...
    If you have PhotoShop, which includes ImageReady, you can make a "droplet" to do certain actions. I have several set up on my G4, one does 50% scale and optimize. So, I take all the high-res images from the camera, and just drag them onto the droplet icon. Takes a few seconds per image on my older G4, usually just a few minutes for a whole bunch of images.
    As I recall, it was easy to setup too (not that you need another project to do before travelling....).
    Craig
    ImageStation was real slow today. We have storage space from Comcast since we subscribe, wish I had time to set that all up. Hope ImageStation is better in a couple of days!
    -juice
  • subaru_teamsubaru_team Member Posts: 1,676
    We'll be awaiting your post and the chat!
    Patti
  • kate5000kate5000 Member Posts: 1,271
    Hello, XTESG group. My name is Kate. I'm DYING from envy to a couple of new XT owners on the Edmunds board. I cannot see any other Forester (model 2003 and later) withoun thinking of getting my very own Platinum Silver Metallic XT, MY 2004 or 2005. I promised to my family that I'd keep my old MY2001 Forester until it has 95K mi on it.
    Now when I'm at home, I sit in my old Forester and try to hypnotize the odometer into jumping from 88K to 95K. It does not work.
    When I'm at work, I'm trying to hypnotize my boss into giving me a good raise. It does not work either.
    I wrote a letter to Santa, but instead of new XT he brought me a digital camera (Canon S400). Well, at least I have something to take pix of the XT if/when I finally get to buy it.
    AAAAA! HELP ME! HELP ME!
    You're among friends! ;-)
    Although I suspect that a few of those 'on-the-fence' might continue to sway to that GT debuting at the NAIAS this week.
    That just means more XT's for us! 8-)
    -Brian
    what's 7,000 miles among friends? :-D
    -c
    Bob and Juice,
    Have a great time at the show!
    DaveM
  • hondafriekhondafriek Member Posts: 2,984
    I bet if you tried really hard you could run that 7K up in a hell of a hurry, alternatively, you could bribe your family members to forgive the 7K :-)
      Cheers Pat.
    a trip to Lafayette, IN will shave those miles off :)
    -Dave
    What are you sitting in front of the computer for? Get out there and drive!!
    Craig
  • kenskens Member Posts: 5,869
    Kate,
    I have a plan. I'll get the GT and you get the XT -- that way we can compare the next time we have a Bay Area meet. :-)
    Ken
    Finally got Wi-Fi working. This is some cool schtuff! I can surf in bed, like I am now. I can surf in all kinds of place. I can...well, let's not go there! ;-)
    I think it was the old laptop. Router is fine, card is fine is this newer laptop.
    This is cool, and fast too! I can't even tell it's not CAT 5.
    Wow Kate, 88k already? You're lucky, it'll be sooner than you think!
    Detroit here we come! If they have a phone jack, ethernet jack, or even a Wi-Fi signal (G), then I'm in! :-)
    -juice
  • subarusaleshousubarusaleshou Member Posts: 161
    Take the long way to work and home. Forget something important on each trip to the store. Go on a day off to check on something at work, with a family member, at kid's school, etc.. I'm sure there are other ways as well. That's about 3 months driving without any extras around here. Good luck rolling off those miles.
    juice,
    Wifi is great. I don't know how I lived without it in the past. Just make sure you have WEP setup -- 128bit encryption, MAC address filtering and the like.
    BTW, 802.11g is backwards compatible with the more common b version.
    Looking forward to reading your reports from Detroit!
    Ken
  • jfljfl Member Posts: 1,399
    juice & Bob - thanks for going to Detroit to check out the Legacy for us. Don't forget to write. 8~O
    Kate - a couple of trips to the snow along with a few visits to Subaru Santa Cruz to drool over the cars and you'll cover 7,000 miles in no time. Then again, maybe a consulation with Ross would help.
    I received the email from Subaru on the new Legacy. I think I'm catching a strain of the same virus.
    Jim
    http://www.need-desire.com/main.html
    More info trickling in....
    Craig
    is all listed in nice bullets on the subdriven.com site. I know we're not supposed to post links, so I didn't. ;-P
    -Ian
    Good news - I verified that the hotel does have fast internet connections. We'll get on-line somehow.
    Since it'll get a bit hectic over the next couple of days, let's try to make the Future Models thread the main thread for this discussion, OK? That's where we will check in first.
    After all, the 2005 Legacy 2.5i and 2.5GT are future models. Plus we'll see the B9 Scrambler and R1e.
    -juice
    Ken/Kate: Get your cars, and I will be right over!
    Kate - By all the power vested in me (by nobody in particular), I hereby officially absolve you of all obligations related to 7000 unearned miles.
    Steve
