But today, temps are expected to reach the low 90's again - ENOUGH ALREADY! 😝😩
The cold weather has set and my battery is dead after sitting idle for about weeks without any activity. Everything is dead not even the fob works. My question thus, should I do a jump start or have the car towed to the dealership where they will replace the battery, do a re-flash and reset my preferences? Also, does the battery have reserve power to protect the electronics in situations like that?
If so I would just take it out, have it tested and if known bad replace with new.
If you can't, I'd do a jump start (preferably from a jump start box) and drive it over.
Having said that, I don't see how getting a boost would hurt anything.....maybe the battery had some reserve power to keep the settings......but, my opinion isn't worth a lot.
My first inclination would be to try a jump start and then take it to the dealer for inspection. It might screw up some of the electronic functions, on mine it did something to the power window and the dealer had to reset something. If you have a lot of electronic nannies there’s no telling what gets screwed up.
One possible thing to check is the key fob itself. I had a fleet car that wouldn’t start, fob wouldn’t make it lock doors etc. I was able to start it by pressing the start button with the fob itself. Evidently the fob battery was weak and the car couldn’t detect the signal except at close range.
My buddy's Dad started the biz in '64, he and his brother took over when Dad retired. Great place to get all the local scoops too. As good as any barbershop LOL
Our friends just came back from Ft. Lauderdale visiting their son and DIL for a 10-day trip. I didn't ask if they were happy to be back in the global cooling we're getting. Going down 20s for tonight and then cold days in that range first of the week!
My car shows are over, but Muncie Indiana, home of alma mater BSU has resurrected what many here may have seen in high school days where young folks cruised certain streets in their old, new, junk, etc., vehicles. In Muncie they started a cruise on their historic main street one evening a month last year. I hoped to make it but never worked out this summer. But they have one this month. Lots of cars will already have been mothballed, but I suspect I'll spend an hour 15 and drive over just to watch the people show off their cars who are the hardy ones. The good thing is the cars have the hoods down, unlike lots of the car shows/cruise ins.
Might go early and visit BSU campus again. Old memories.
I think I need to move closer to the equator. Though I guess I would be single if I did!
TPMS
Tire pressure sensor reset tool. Amazon. $10
You can program the car's computer for the TPMS yourself. One wheel at a time.
I received the check for $3.50 today, but they left off half of my last name....repeated everything on the phone. I gave up, but Mrs D says it can still be cashed. I looked it up, and this is what it says:
Let the Teller Know
Tell the teller. If the misspelling is harder to read than a mere missing letter or two, go to the teller inside your bank and explain your problem. The teller will instruct you to endorse the check exactly as it is made out, with the name misspelled. Then you will be instructed to write your name with the correct spelling below that.
Hopefully they won't give me a hassle over $3.50!
On my Acura, they've been remarkably accurate, within a pound or two of my handheld dial pressure gauge. I find it very helpful to be able to see what all four pressures are when I get a low tire pressure light (particularly at this season of the year) -- tells me if I should have a tire repaired, or just wait for them to warm up until I have a chance to pump them all up 3-4 psi.
When we got the Forester, I was surprised to learn that there was no way to look at individual pressures or even to see which tire or tires were causing the light -- you have to look at all four of them with a real gauge to find out what's going on.
With cooler weather beginning to arrive here, I will have to have them add air to all four tires.
for some reason the right rear on the F150 readout usually indicates a pound lower than the other tires with the same gauge.
I think I will check the MKZ today, just to see. I did set the pressures a coupe of weeks ago.
The easiest solution would be to throw it away.
I’m sure you wanted to drive the Cutlass more @ab348, I hope you get to next year.
Oldfarmer will need a 2000 mile oil change and ab....what do you do....zero miles in one year?
I'm going to skip the fall oil change. Only 300 miles, whats the point? Just wait until next year.
I did put the top down in the spring and never put it back up.
Will have to that before I put the cover on it.
