Now I commute from the "valley of the sun" to my high-elevation hideaway on a regular basis, so still accumulate reasonable mileage, speaking of which, it's about time to put on my wheels with the winter tires. Tire Rack was careful enough last year, when I ordered them, to verify that I wasn't totally senile, ordering actual snow tires in AZ. I answered their questions properly and got them delivered in short order. The cabin had up to 4 feet of snow on the ground last winter. Time will tell what we get this year.
It means I will do the oil change next spring.
I doubt anything will be any negative consequences, the car is just going to sit in the garage.
Motor oil becomes less effective over time. Constant exposure to heat, moisture and air leads to oil degradation (oxidation). The end result? Oil thickening, sludge, deposit formation and corrosive wear. Sounds awful, right? Well it is, and all these nasty elements can take a toll on your engine. You don’t want those troublemakers knocking around your engine parts.
Oil additives depleted, oil life finished. When oil additives are completely exhausted, oil can no longer handle the dirt and metals that are freely floating around, causing the oxidation that creates sludge. Most importantly, old oil can no longer protect your engine against corrosion and wear when it breaks down. Picture your engine oil trying to work its way through hard and sticky sludge that’s clogged up oil passageways in your engine. Doesn’t sound very effective, does it? (Not to mention all the havoc these added barriers can inflict on your engine.) Leaving oil in your engine well past the recommended oil change date can result in disastrous conditions and expensive repairs.
Changing the oil on time will help insure your car will last as long as possible. One year is max though.
That's for a car that is driven regularly. Just another example of blind copy and paste with little relevance to the topic.
Does anyone know if this was caused by the way he hooked it up? It would seem to be a coincidence if the dishwasher isn't working when he hooks up the Garbage disposal.
Maybe he forgot to take the stopper out of the disposer(needed if you DON'T have a disposer connected).
Would have had to plug old opening since now drain is hooked into disposer?
The stopper is a possibility....I'll see if there are other ideas, or I'll phone him and ask him about that.
He came over and he had to pound the stopper out of the intake tube.......dishwasher seems to be fine now.
I wasn't looking forward to doing the dishes the old fashioned way by hand tonight....thanks for mentioning "the stopper".
Living here near seniorville, which is Sun City where I have never seen anyone under the age of 35 I had an experience I don't need. I come up to the red light, and there are 5 cars going to turn left when the arrow comes on....I was the 6th. The green arrow comes on and the guy in the first car....a van actually, takes about 15 seconds to move, and only one car gets through on the left arrow........when all 6 of us could have made it through....had to wait for the next left turn arrow.
Glad it was a simple fix.
Your 'guy' probably figured it out pretty quickly.
Charged up the battery in the Mustang today so I could put the top up.
Waited too long, cold enough that the top won't close all the way.
I'll back it out of he garage tomorrow to soak up some solar energy to loosen the material.
https://www.msn.com/en-us/news/us/porsche-launches-into-second-story-of-new-jersey-building-killing-2/ar-BBWyjM9?li=BBnbcA1
https://www.msn.com/en-us/news/us/new-jersey-homeowners-say-aggressive-turkeys-are-terrorizing-community/ar-BBWvWPz?li=BBnbcA1
They’re the same ones who leave shopping carts rolling all over the supermarket parking lot.
The rolling shopping carts....how lazy do you have to be to just leave a shopping cart on a parking lot. That should be a definition of a slob in the dictionary.
Great design Ford.
We took the Wrangler on a 40 mile round trip to make sure the battery stayed fully charged. Really, the only thing that keeps me from taking it on longer trips is the noise level above 60 mph. My wife even agrees that the seats and the ride quality are good. Today I drove the X1; I like it a lot as well; it handles great. It’s quick enough for my bride but for me a mid-fourteen second quarter mile is just acceptable.
I have the day off tomorrow; I may check out a new Supra.
which was the tire air pump that you ended up getting again?
Upcoming birthdays:
20
16
5
1
Lincoln last ride.
wife complained today that she could not get into the call history through the phone button on the audio system. The tech is so old school, it doesn't have a synced phonebook, nor can you BT to make a call. So other than doing it on the phone, the (theoretically hands free) shortcut was to just hit the phone button, bring up recent calls, and just hit redial. Now she said it would not come up. I tried today when I had the car, and had the same thing. history menu came up, but only button that worked was redial last call.
I am thinking that the latest iOS update was too much for the old buggy to handle! At least the car still talks to the phone for calls!
Breezz Tire Inflator, Air Compressor Pump, 12V DC Portable Auto Tire Pump with Digital Display Pressure Gauge up to 150PSI for Car, Bicycle and Other Inflatables
It was actually a bit cheaper, now it is $30, when I got it last week it was $26. So many are similar. The Shell station is only 1/2 a mile away, so I would go there and for $1 use their pump....it works well and seems to be accurate. If for some reason I can't get there, this one is for emergency use. It is a nice compact unit, has a light attached, and it matches the C250. I haven't actually used it yet, I am assuming it will work.
I understand what you're saying, but I don't think anyone else on here does. We're talking about people who accumulate 2000 miles a year, more or less, on a car, yet are willing to register it and pay for insurance, but it has to be on the warranty.
Go figure.
Yeah, but it's often clear to others with whom you interact.
