2020 VW Passat Lease Deals and Prices
gregw5gregw5 Member Posts: 113
edited November 2019 in Volkswagen
2020's are rolling into dealers now. Is programming available for 2020 in the month of November? Looking for R-line and SEL for 36/10k in 48390.
«13
  • MichaellMichaell Moderator Posts: 271,492
    No numbers for the 2020 Passat, this month.
    Perhaps in December...
  • gregw5gregw5 Member Posts: 113
    s programming available for 2020 in the month of December ? Looking for R-line and SEL for 36/10k in 48390.
  • kyfdxkyfdx Moderator Posts: 276,892
    .00085 MF and 54% residual
    All trims
  • BettiniBettini Member Posts: 15
    Hello can I please have the MF and Residual for a 2020 Passat SEL in 21093. 12K / 36 month or 12K 39month for sign and drive if applicable. Also any incentives?
    .00085 MF
    53%/51% residual
  • jacob129jacob129 Member Posts: 18
    edited December 2019
    Hello can I get mad and residual for 2020 Passat se, sel on 10k/36 and 10k/39. In area code 33603
    .00085 MF
    54%/52% residual
    Either trim
  • seasidechargerseasidecharger Member Posts: 22
    Can I please get MF & residual for: SEL; 36mo; 15k; 92123.
    .00085 MF and 51% residual
    A salesperson told me that the MF/Residual change today. Is that true? Is so, can I please get MF & residual for: SEL; 36mo; 15k; 92123.
    Thanks very much
    Thanks very much
    It changes tomorrow
    Hi Gang,
    Thanks very much
    Hi Gang,
    Thanks very much
    .00068 MF and 50% residual
    $750 dealer lease cash
  • OGilOGil Member Posts: 2
    Hi There! Can I please get MF & residual for: SEL; 36mo; 15k, and 10k; 77041.
    Thanks in advance.
    Thanks in advance.
    $1000 dealer lease cash
  • DucyDucy Member Posts: 6
    Numbers on the 2020 sel 12/36 11720 Thank you.
  • e39silverm5e39silverm5 Member Posts: 33
    Hello, can I get the numbers for the SE R-Line? 36/10 - 95608. Thank you.
    .00068 and 52%
    $750 incentives
    .00068 and 53%
    $750 incentives
  • Ishaan16Ishaan16 Member Posts: 123
    Hello, may I please have the MF, RV, and incentives on an S trim in ZIP 92886? 36/15k. Thank you.
    All trims
    Hi, can I please have the MF, RV, and incentives for a SEL 36 month 12K or 39 month 13K in 21093. Thank you
    .00068 MF
    52%/50% residual for 36/39 mo, 12K/yr
  • Seagrad3cSeagrad3c Member Posts: 1
    Hello, can I please get MF and RV for SE 36mo 12k 80128. Thanks
    .00068 MF and 52% residual
    All trims
  • Dorie497Dorie497 Member Posts: 3
    edited February 2020
    Hello everyone. Can someone let me know what the residual and money factors are on 36/12 and 36/15? And also incentives. 06112
    S
    Se
    Rline
    S
    Se
    Rline
    All trims
    If you would be so kind to post lease programming for 2020 Passat R-line in 48390; 36/10. Thank you in advance.
    .00068 and 53%
    $750 incentive
    .00004 MF and 52% residual
  • howdiihowdii Member Posts: 17
    Hi there, could I please get RV/MF/Incentives for the 2020 VW Passat S and SE, 36/12k, 75209. Thank you!!
  • ajames8774ajames8774 Member Posts: 27
    Could I have the RV/MF/Incentives for the R Line in 08035. Both 36/12k and 36/10k. Thanks
    .00004 and 51%
    $250 incentive
    Either trim
    .00004 and 51%
    $500 incentives
  • dongsan41dongsan41 Member Posts: 5
    May I have a MF/RV/Lease incentives for:
    2020 Passat Automatic
    SE, R-Line and SEL
    home zip 10954
    (would it be same for 07446? I'm leasing from dealer at 07446 but will be registering at 10954)
    SE, R-Line and SEL
    home zip 10954
    $500 dealer lease cash
    All three trims
  • AmeezyAmeezy Member Posts: 3
    SE, R-Line and SEL
    home zip 33179
    Are there any loyalty incentives for current VW lessees?
    SE, R-Line and SEL
    home zip 33179
    .00004 MF and 51% residual
    SE/SEL: $500 dealer lease cash
    RLine: $1000 dealer lease cash
    No info on loyalty
  • PerrierPerrier Member Posts: 10
    I am looking for the MF/RV/Lease incentives for:
    SE, R-Line and SEL
    home zip 55416
    SE, R-Line and SEL
    home zip 55416
    $1200 dealer lease cash
    All three trims
    SE, R-Line and SEL
    home zip 55416
    All three trims
    If it moves from a 36 month to 39 month - does the MF or RV change with 12,000?
    SE, R-Line and SEL
    home zip 55416
    All three trims
    Subtract 2% from the RV for 39/12
    Following up again to inquire if the May numbers have changed because I was unable to get a deal done in April.....
    SE, R-Line and SEL
    home zip 55416
    SE, R-Line and SEL
    home zip 55416
    .00001 MF and 50% residual
    $1850 dealer lease cash
    All trims
  • CTeeOCTeeO Member Posts: 26
    edited May 2020
    2020 Passat R-line
    MF & Residual ?
    36/15k
    33076
    48/15k
    CTeeO said:
    2020 Passat R-line
    MF & Residual ?
    36/15k
    33076
    48/15k
    .00001 MF and 48% residual
    .00051 MF and 41% residual
    $1600 dealer lease cash
  • xpertjoeyxpertjoey Member Posts: 46
    Hi, checking for June’s money factor and residual value for a 2020 Passat SE 36 months 10k miles?
    Any lease cash?
    Zip 11204
    Thank you so much.
    Any lease cash?
    Zip 11204
    Thank you so much.
    .00001 MF and 51% residual
    $1800 dealer lease cash
  • l_a_z_10l_a_z_10 Member Posts: 9
    Hi, do you have the numbers for 2020 SE for 15k/36m in zip 11787.
