2020 GMC Sierra Lease Deals and Prices
1235722
  • Malik1388Malik1388 Member Posts: 14
    Hello, can I get mf/rv/ incentives on 2020 gmc sierra 1500 slt crew cab, AWD.
  • MichaellMichaell Moderator Posts: 269,457
    What is your ZIP code?
    95747
    Malik1388 said:
    ZIP 95747
    .00052 and 61%
    $1000 incentives
    No 33 month term from GM
  • Auto_XAuto_X Member Posts: 6
    edited January 2020
    Hello, May I get money factor, residual, and incentives for 2020 GMC Sierra Elevation Crew Cab 4x4 w/ 5.3L. I'm in Detroit area, zip is 48015. Would a similarly equipped 2020 Silverado LT be the same? Thank you.
    36mo / 15k
    36mo / 18k
  • captainjz16captainjz16 Member Posts: 15
    Need #s for 2020 GMC 2500HD diesel AT4. 36m/15k. zip: 33629
    thanks!
  • kyfdxkyfdx Moderator Posts: 273,212
    36mo / 15k
    36mo / 18k
    .00043 MF and 57% residual
    $1000 customer incentive
    Silverado discussion is here:
    https://forums.edmunds.com/discussion/58005/chevrolet/silverado-1500/2020-chevrolet-silverado-lease-deals-and-prices#latest
    thanks!
    We do not have any lease programs for the HD models
    36mo / 15k
    36mo / 18k
    Thank you kyfdx!
    Can I get mf/rv/incentives for 2020 gmc sierra crew cab slt.
    2WD or 4WD?
    Rwd and 4wd. Thank you
    2WD: .00063 MF and 60% residual
    4WD: .00052 MF and 61% residual. $1000 customer incentive
  • anderm30anderm30 Member Posts: 122
    Hello, can I get the 24/12 numbers for a 4wd SLT crew cab shortbed (premium plus if it makes any difference) for zip 37922? Thanks!
  • cal_quailcal_quail Member Posts: 2
    May I have MF/RV/Inc on 2020 AT4 Crew Cab
    36/15 (and is there a 36/18?)
    92506 and 97103
    .00069 MF and 69% residual
    92506 and 97103
    .00052 MF and 59% residual
    Either location.
    We only have the residuals up to 15K/yr.
    Check with a dealer to see how they handle the extra 9K miles
    Thanks! Does the $1000 incentive apply in my zip?
    No
    No
    Thanks! How about the 36/12 and 39/12 numbers for a 4wd Denali for 37922? Any lease incentive?
    No
    .00073 and 62% / 60%
    No incentives
  • moyac01moyac01 Member Posts: 2
    Original negotiations failed in the Dallas area. Now looking for RV, MF, and incentives for a 36/12 lease on a 2020 AT4 4x4 CrewCab in Houston
    Interested in zip code 77338. Thanks again.
    $500 customer incentive
    Looking for RV, MF and incentives for a 36m/15k lease on a 2020 GMC AT4 Premium package and technology package in Tampa, FL. Would the #s change if adding the Performance Upgrade package?
    thanks in advance!
    thanks in advance!
    Crew or Double Cab?
    Crew
  • kr38kr38 Member Posts: 6
    Hello, can I get the following for a 2019 and 2020 GMC Sierra Crew Cab SLT. Thanks a lot.
    MF
    RV
    Incentives
    36m / 10k
    2WD
    thanks in advance!
    Crew
    .00052 and 59%
    No incentives
    Packages and options do not affect the numbers
    MF
    RV
    Incentives
    36m / 10k
    2WD
    2019 programs have ended for all Sierras but the Limited Double Cab.
    MF
    RV
    Incentives
    36m / 10k
    2WD
    Zip code is 33614
    kr38 said:
    MF
    RV
    Incentives
    36m / 10k
    2WD
    Zip code is 33614
    2020
    .00063 MF and 61% residual
  • GVFLYERGVFLYER Member Posts: 16
    Good afternoon, can I get the lease number for a 2020 GMC Sierra 1500 SLT RWD 4D Crew Cab 36/12 plus incentive if possible for February. 33178 Thank you.
    .00063 and 60%
    No incentives
  • 94suburban94suburban Member Posts: 4
    Hi - can I get the mf/rv/incentives for 2wd 1500 crew w. std bed - elevation & sle. Zip: 92663
    36/15k
    Thank you!!
    36/15k
    Thank you!!
    .00063 MF and 58% residual
    Either trim
    kr38 said:
    MF
    RV
    Incentives
    36m / 10k
    2WD
    Zip code is 33614
    2020
    Thank you!!!
  • norcal14norcal14 Member Posts: 12
    edited February 2020
    Hello - Can I get MF/RV and incentives on 2020 1500 AT4 crew cab short bed Zip 94401
    36/10k
    39/10k
    36/10k
    39/10k
    .00052 and 62% / 60%
    No incentives
  • chrisndenisechrisndenise Member Posts: 13
    Hello, can I get Residual, Money Factor and Incentives for 2020 Sierra Denali, Crew Cab, 4x4, 36-15k in 97008? Thank you!
    .00073 MF and 60% residual
  • CFF62CFF62 Member Posts: 15
    Hello can I please have the money factor, residual, and incentives for a 2020 Denali 4x4 in zip 06460, for 36/15.
    .00060 MF and 61% residual
    Hello, can I please get numbers for a 2020 2500HD Denali 4x4. Zip code 33064. It is my understanding the GM Finacial release lease options on the denali heavy duties.
    Hello, can I have the 36/12 mf and residual for 1500 4WD Crew Cab short bed AT4 and Denali? Zip is 37922. Any incentives? Thanks!
  • wheelspinwheelspin Member Posts: 68
    Can I get the money factor, residual, incentives for Sierra 1500 Crew Cab 4WD SLE?
    Zip - 78738
    24/10
    Thanks in advance!
    There may be lease programs, but we do not see them.
    AT4 - .00052 and 63%
    Denali - .00060 and 63%
    No incentives
    Zip - 78738
    24/10
    Thanks in advance!
    .00046 and 70%
    .00056 and 63%
    No incentives
    Can I get the RV/MF/incentives for Sierra Crew Cab 4X4 SLE - Elevation - SLT:
    36mo/15k
    Zip is 48375
    Zip - 78738
    24/10
    Zip - 78738
    24/10
    Thanks in advance!
    .00046 and 70%
    .00056 and 63%
    No incentives
    Thank you. Are the numbers the same for 2WD SLE?
