Visitor Agreement.
If the battery is very low despite the trickle charger, then driving 1 block and back should have had the alternator putting lots of current back into charging the battery during that short time. Car should have starter better than when first taken off the trickle charger...
https://itstillruns.com/difference-float-charger-trickle-charger-7646389.html
The car started the first time, she drove it to the neighbours in -10F temperature....it is about 1/10th of a mile, stayed and talked, drove it home 1/10th of a mile, it sat in the garage -0 F overnight...then wouldn't start. I doubt the battery got charged up at all with the short run.
She went out of town this afternoon, went to lunch, came back, 30 miles each way, and it seems fine...but, will put the
tricklefloat charger on it tonight.Thanks for the info and thoughts.
YOU ARE INVITED TO OUR SNOW DAYS EVENT ON FEBRUARY 18-22!
We would like to invite you to our upcoming Mercedes Snow Days Event happening on Feb 18-22 here in our dealership. If you currently have a Mercedes-Benz vehicle, our team would like to offer you a complimentary trade evaluation.You may have an opportunity to drive a brand new, similar model as what you have now and pay the same or lower monthly payments with our current offers.
Since it is so cold....and there is a bit of snow on the ground, they are going to give you a fabulous deal. Probably a slow time of year to begin with and they probably aren't selling too many cars in this -10F weather. But, what really gets me is, " If you currently have a Mercedes-Benz vehicle, our team would like to offer you a complimentary trade evaluation". WOW, I should fly back to get my free complimentary trade evaluation!
Reminds m of the realtors....let us come and evaluate your home for FREE, and let you know what it is worth.
That's not how a good trickle charger works.
It keeps the battery close to 100% charged.
Remember too, the car started the first time....then it was left out in -10F temperature for an hour....started again, was in -10 temp overnight....could have drained out any power left......who knows?
it is of course also possible that the battery is starting to go.
All I can conclude is that starting a car and idling actually drains the battery. If you combine that with an old battery and cold weather I can see the no start happening.
Battery is also coming up to 6 years....though the car is kept in a garage it does sit in cold weather for long periods of time.
I have a case of water sitting on the floor on the north side of the garage.
It isn't frozen.
I have a 3 bay garage with the north side being furthest from the house.
That wall and part of the concrete slab are not getting any heat from the house.
Maybe a Mercedes costs less, I can't find how much this would cost.
I'm not sure...the car wouldn't start in extreme cold when it hasn't run in 2 months......took it on the highway, seems to be charged up fine now. What is the problem?
I'm surprised the MB store wasn't more interested in the problem with the battery. At 6 years of age,
I'd think it is time for a replacement. My Autozone guy was adamant that my 5-year old top line battery in the Cobalt would show signs of aging and might not have enough power to crank after sitting on coldest winter night outdoors. I trust him because I've known him for years. I replaced battery.
I do the same with tires: having 40% tread depth on the car I want to run on snow, drifts, ice makes a difference. A deeper tread grips better, so I replaced tires that look good but are at the 30-40% depth. Not worth having less traction. Also 90% of tire problems occur in the last 10% of the tread wear was a platitude someone said long ago.
I consider it fake economy to try to get another year out of the battery because I measured the sitting voltage, after car was off for hours, and came up with a voltage that showed 60% as the status of the battery. The voltage after the surface charge drains off should be 12.6 v and there are charts showing the voltage as a function of battery output power for lead acid batteries.
Your battery may be AGM (absorbant glass mat) which has a slightly different character like my Malibu's battery which is AGM.
A float battery charger brings a battery up to full charge and then holds at 13.8. That voltage does not boil off water (electrolysis). (I have done a lot of reading to learn since your post.)
When your car was started, the alternator surely is over 150 amperes in rating and the circuits would
have started pumping in coulombs of charge into the battery to bring an undercharged battery back to having enough oomph to start the car again.
If the system wasn't working right for recharging the battery, there should have been some kind of notice from the "computer" that there was a charging/battery problem.
My point is, your garage is not as cold as you think it is.
I wanted to see if it got below freezing in my garage.
Being too cheap to buy a thermometer, I took some clear spray bottles, filled them halfway with water and put one on each shelf(different heights) of some storage shelves I built in the garage.
Only rarely have I seen any evidence of ice in them.
Considering the vehicle started when taken off the charger, and has been ok since jumped, I'm going to guess operator error, but I don't think anyone will ever know for sure.
It was in the 20s outside and when I returned and my house was still 50 inside.
COMPONENT SELF-LEARNING IN THE EVENT OF BATTERY DISCONNECTION
After connecting the battery negative terminal, the following self-learning operations must be performed
to ensure that certain connected devices acknowledge the system again:
"EPB FAILURE" AND "PARKING BRAKE ENGAGED" WARNING LIGHTS
Each time the battery is reconnected, the “EPB FAILURE” and “PARKING BRAKE ENGAGED” warning lights flash
for about 10 seconds and then go off.
This is normal and not indicative of a failure.
MOTOR DRIVEN THROTTLE SELF-LEARNING
Turn the ignition switch to ON and wait at least 15 seconds.
After performing the self-learning cycle for the “throttle position”, you must perform the same cycle also for
the timing variators (VVT). To do this, start the engine and let it idle for about 20 seconds.
CENTRAL DOOR LOCKING
LOCK and UNLOCK the doors using the remote control.
NIT (IT node) and CLOCK
Turn on the IT Node, reset the correct time and date since the IT node looses this information every time the battery is disconnected.
FRONT SEATS
Following any power cut-out (e.g. after using the battery master switch or if the battery has run flat), check
the seats to ensure that they are operating properly when the power supply is available.
Perform the following procedures on both seats in the event of a malfunction.
When the ignition key is at STOP and the door next to the seat concerned is closed, open the door and start
the following procedure within 5 seconds, then complete it within 10 seconds.
forward - STOP
backward - STOP
forward - STOP
backward - STOP
tilt the seatback fully forward and wait until the seat performs two complete travels
(forward and backward).
Put the backrest in the normal position.
If you need to disconnect the battery, wait at least 30 seconds from the last seat movement. If you
disconnect the battery before, you will have to run the initialisation procedure.
TGK VALVE STROKE SELF-LEARNING
Every time the battery is connected, the acquisition procedure relating to both the water valves is started.
After connecting the battery, turn the key to ON and wait at least 15 seconds before starting the engine.
The phases for a correct self-learning of the strokes are the the following:
complete valve opening (max. 6 seconds)
memorisation of the opening position of both valves (950 on the average)
complete valve closing (max. 6 seconds)
memorisation of the closing position of both valves (50 on the average)
memorisation of both valves' stroke (Stroke=Opening-Closing, 900 on the average)
stroke analysis
if even only one of the 2 strokes is below 500, both strokes are assigned a recovery value of 800 and the
procedure is repeated upon the next network wake-up or when the key is turned to ON
if both strokes are above 500, the strokes correspond to those calculated and the procedure will not be
I am finding it difficult to get an exact answer. But, this is what I found would have to be done if your battery is dead. I assume that would be similar. It i long, but, it could be a few hours of labor, plus having a new battery installed (might be costly for a Maserati);
Problems That May Occur If You Disconnect Your Car battery
What happens when the battery is disconnected? It depends on the year, make and model of your vehicle, but any of the following may happen:
Loss of learned values in the PCM's Keep Alive adaptive memory. This may cause the engine to run poorly because the air/fuel mixture is too rich or too lean for a period of time until the PCM can relearn the fuel trim adjustments. This may take up to several days and 50 to 100 miles of driving until engine operation returns to "normal."
Erasing the PCM's adaptive memory may also affect the way the transmission shifts and feels. The transmission may not feel the same until the PCM or transmission control module relearns the shift adjustments. This may take 50 to 75 miles of driving.
It resets the FMEM (Failure Mode Effects Management) module on certain late model Ford vehicles. This module provides an adaptive fail-safe strategy that substitutes estimated or fixed data for missing sensor data. Normally, this should not cause a problem UNLESS the vehicle has a bad sensor and has been substituting data from the FMEM module for a missing input.
It resets the ABS (Antilock Brake System) and SIR (Supplemental Inflation Restraint) or airbag modules. This should not be a problem UNLESS one of these modules requires a special relearn or reprogramming procedure after power has been lost. In that case, the affected module may prevent the ABS or airbag systems from working.
It resets the Climate Control module. On some vehicles, the module will not start working again until a special relearn procedure or reprogram procedure is performed with a factory scan tool. That means no A/C until the module is programmed with the correct instructions.
It resets the Body Control Module (BCM). Like the Climate Control module, the BCM may not resume normal operation until it has undergone a special relearn procedure or is reprogrammed with a factory scan tool. This can mess up the operation of power accessories such as power windows, memory seats, power sunroof, or electronic suspension settings. Worse yet, the BCM is the "gate keeper" module on many 2003 and newer vehicles that have a CAN (Controller Area Network) system. If the BCM cannot communicate properly with all of the other modules, or it does not recognize the addresses of other modules, it can cause all kinds of problems.
It may reset or disable the anti-theft system. The engine may crank but not start because the anti-theft system thinks somebody is trying to steal the vehicle. Again, it may require a special relearn procedure or reprogramming the anti-theft system with a factory scan tool to resolve the problem.
Loss of power window and/or power sunroof position settings. Unless power is maintained to the vehicle's electrical system during battery replacement, the power windows and/or sunroof may not work properly until the position values have been reset using the vehicle manufacturer's relearn procedure.
Loss of steering angle sensor settings. The steering angle sensor will have to undergo a relearn procedure following battery disconnect or replacement.
Replacing the battery on some vehicles requires entering the new battery info into the PCM with a scan tool (type of battery, battery serial number and CCA rating). This is necessary because the vehicle's charging system is programmed to gradually increase the charging rate as the battery ages. If the charging rate is not reset back to that for a new battery, the battery may overcharge and fail - or vent toxic hydrogen sulfide gas into the passenger compartment if the battery is located inside the vehicle.
It causes a loss of channel settings on an electronic radio and clock. This is more of an annoyance than a problem, and can be fixed by resetting the radio channels and the time.
SPECIFIC VEHICLE BATTERY PROBLEMS
Here is a short list of some of the problems that can occur when disconnecting or replacing the battery on the following vehicle applications (refer to the OEM service literature for specific model and year applications and cautions):
Chevy Tahoe Loss of voltage to the vehicle electrical system causes the 4WD module to go to sleep permanently. The module never wakes back up when power is restored, and the only way to restore normal 4WD operation is to replace the module with a new one (a repair that may cost you over a hundred dollars!).
Mercedes (various models) Loss of voltage to the vehicle electrical system will prevent the A/C from working. The climate control module must be reset to restore normal operation. It may also disable the Stability Control System. The ABS module has to undergo a relearn procedure for the steering angle sensor to restore normal operation.
I don't know how much that adds up to but a battery could be $200 to $300 installed possibly.
They didn't have time to work on her car at that time. They said she could leave it with them, but, she had to drive 30 miles out of town, so they said it was worth a try to just drive it and see if it charged up....which it did.
I like your rule about tires, mine usually went at the 10% remaining level.
The GLK has about 24000 miles on it and it is in a garage every night, and when not in use, but, yes, probably a good time to replace the battery...6 years is about the limit.
Then she asked if I wanted to watch it again.
"How To Scare Rubes Into Taking Their Car to a 'Professional Technician' Every Time it Hiccups So That They Can Be Thoroughly Screwed"
Real footage, about 27 minutes long.
The clip of the kids in the 'Ferrari' gokarts cracked me up.
It seems to be as much about the people attending the event as it is about the race.
I have a picture I took of the winning Mark IV back in the late 80's.
It was stationed at the front of the Henry Ford Museum as the featured vehicle.
What was really great is that it was still in 'after race' condition, not cleaned up, as it is in the studio portions of the video.
Something happened after the race that endures until today.
2013 LX 570 2016 LS 460
My biggest fear in life was that I would be out of work (that happened a lot) and the only job I could find would be being a waiter. I would be a disaster, getting orders wrong, spilling food on people, not really caring if their steak wasn't done to their exact specifications.
But, JM, you just convinced me my biggest fear for a job would be having to change a car battery. I just know I would let the wrong dangling wire hit something that will cause the car to blow up!
Same with tires, depending on where you live, it sounds like 6 years is getting near the max before the rubber starts to deteriorate.
This wouldn't make sense for you as you are knowledgeable about testing your car and knowing what has to be done.....but, you represent a very small percentage of the driving population.
I have a friend who fixes his cars and keeps them running for a long time...usually around 200,000 miles.
This was his quote about the GLK not starting, and about it being OK after a 30 mile run on the highway;
Chargers perform the best by trickle charging, so, methinks your battery needs to be replaced! There may still be a bit of life in the battery, but on really cold days it loses 2/3rds of its power! A good charger will get the battery up quicker than the alternator/generator of the car.....so.....driving the car helps but an overnight charge is far superior!
My point is that I think that all that palaver about cars requiring upwards of $1,000 worth of work to allegedly "reprogram" the car is nothing but B.S.that is calculated to cause people to go go a tech, hand over their credit card, drop their pants, and grab their ankles.
Look it up, if you don't know already.
