2020 Porsche Lease Deals and Prices (All models)
1356710
  • kyfdxkyfdx Moderator Posts: 272,427
    Do you have numbers on 2020 Carerra 4S convertible, 36mo, 5k/7500mi per year scenarios, zip 92618, thanks.
    .00200 MF
    60%/59% residual
  • AVS1971AVS1971 Member Posts: 2
    Does anyone have numbers for MF and residuals on a 992 Carrera 4S Coupe (manual if it makes a diff) for 10K miles, 36/39/42/48 months?
  • MichaellMichaell Moderator Posts: 268,562
    .00200 and 59% / 57% / 55% for 36/39/42 and 10K
    No supported 48 month term from Porsche
  • defender4defender4 Member Posts: 4
    Considering a few different vehicles. What is the money factor and residual for the following?
    2020 Cayenne
    2020 Cayenne Coupe
    2020 Panamera
    All for 36 months, 7.5k miles per year. Thanks
    2020 Cayenne
    2020 Cayenne Coupe
    2020 Panamera
    Base models?
    .00200 MF
    61% residual
    61%
    59%
  • V8PROV8PRO Member Posts: 74
    edited April 2020
    Hi, can you please provide the latest MF, residual and incentives for Taycan 4S 36/10k and 36/12k in 94941? Any chance that Porsche is deciding to share the EV tax credit with lessees?
  • llyod23llyod23 Member Posts: 5
    Could I please get the RF and MF for 2020 cayenne e-hybrid and e-hybrid coupe 36/7.5. Thanks
    .00200 and 50%
    No incentives
    .00200 and 59%
    Either model
    Does anyone have MF, residuals for a 992 4S, for 36/42/48 mos, for 5k mikes per year?
    .00200 and 61% / 59% / 57% for 36 / 39 / 42 months and 5K
  • SPS83SPS83 Member Posts: 34
    Can I get the MF, residuals and any incentives for a 992 base for 36 / 39 at 7.5K for zip 73102? Thanks.
  • anesporscheanesporsche Member Posts: 2
    edited May 2020
    Hello, can you please provide the MF and residuals for a 2020 Porsche 911 Carrera Cabriolet with the following lease terms:
    36mo/10k
    36mo/8k
    39mo/10k
    39mo/8k
    .00200 and 63% / 61%
    36mo/10k
    36mo/8k
    39mo/10k
    39mo/8k
    .00200 and 62% / 60% for 36/39 months, 10K
    Thanks! Can I also have the residual and MF 2020 Porsche 911 Carrera Cabriolet for a lease w/ 7.5k miles for 36 and 39 months
    Add 1% to residual for 7.5K
  • ssimssim Member Posts: 113
    2020 Base Cayenne:
    36/10k RV; 36/7.5k RV; Current MF; Current MRM (if MRM is unknown, please let me know where it was the last time it was known, I think it should be around $85k)
    ssim said:
    2020 Base Cayenne:
    .00200 and 60%
    MRM $82,300
  • vtd4524vtd4524 Member Posts: 21
    Can I please have MF/Residual/ any incentives on a 2020 Panamera GTS. 12k miles. 15601.
    .00200 and 55%
    No incentives
    edited May 2020
    2020 Cayenne E-Hybrid
    39/10k RV, MF, & MRM please
    Also looking for numbers on a 2019, though I think I'd have to visit the other thread.
    .00200 and 56%
    MRM $97,700
    Yes, post 2019 questions into the 2019 Porsche lease thread.
    We don't see any programs for 2019 models.
    2020 Panamera 4 E-Hybrid Executive (39/10k)
    RV, MF, & MRM please (trying to decide which Hybrid to order)
    .00200 and 53%
    MRM $125,900
  • m5frothm5froth Member Posts: 55
    Hi do you have numbers for Cayman 718, 36/10, 91436 zip. Thanks.
    .00200 and 47%
  • VirageVirage Member Posts: 7
    Hi. Do you have Macan S / GTS numbers for 36/10 and 36/7.5? zip 33625. Thanks.
    S - .00200 and 61%
    I don't see a GTS trim for the 2020 Macan
  • ElyuriElyuri Member Posts: 1
    Hey! Do you have the numbers and possible incentives for 2019 Cayman 718 Base. 36/12 - zip 91007.
    Lease programs for the 2019 Cayman have ended.
  • vertigo1vertigo1 Member Posts: 59
    Hi, Do you have the numbers/incentives for a 2020 Boxster T, 36 months 12k/10k/9k in the 95032 zip code? Is the 39 or 42 month lease significantly better or worse? Also, are pdk and manual the same? Thank you!
    .00200 and 56% / 54% / 52% for 36/39/42 months and 12K
    Same numbers for either transmission
  • evloverevlover Member Posts: 2
    Looking for numbers for a 2020 911 C4S. 24 months, 7500 miles per year. Thank you!
    Coupe or Cab?
    Coupe or Cab?
    Coupe. 94123 zip code if that matters.
    evlover said:
    Coupe or Cab?
    .00200 and 67%
    Thank you, Michaell. For the Boxster T, how do the numbers change if you drop the mileage to 10k or 7.5k annually?
    Add 1% / 2%, respectively
  • ianmSCianmSC Member Posts: 14
    Hi, are there 39 or 42 month lease programs for the 2020 Macan S?
    So essentially looking for:
    36/39/42 Macan S residual in zip code 92008, at 7500/10k miles. Thanks!
    .00200 and 61% / 59% / 57% for 36/39/42 and 10K
  • edmundsin33323edmundsin33323 Member Posts: 93
    edited May 2020
    Hi Folks!
    May I have lease rates, residual for a 2020 718 Cayman GT4 in 34787 zip.. any incentives or MRM?
    7.5k / 24m and 36m
    10k / 24m and 36m
    Hi Folks!
    7.5k / 24m and 36m
    10k / 24m and 36m
    .00200 MF
    54%/47% residual for 24/36 mo, 10K/yr
    MRM: $120,700
  • mb_enthusiastmb_enthusiast Member Posts: 241
    edited May 2020
    Are there different terms for 2020 Cayenne demos and loaners?
    My stable: 2019 Audi Q8, 2015 Mercedes-Benz GL63 AMG, and 2005 Mercedes-Benz E500W4Found new homes: 2017 Porsche Cayenne S, 2011 Mercedes-Benz R350 BlueTEC, and 2004 Volkswagen Phaeton V8Illinois real estate broker and commercial property manager
  • hemingway9hemingway9 Member Posts: 87
    Greetings: What's is RV/MF for 2020 911 Carrera coupe and 718 Spyder at 24mo & 36mo for 91436 and tier-1. Any incentives?
    There will likely be an adjustment to the residual, but we don't know how it works.
    How many miles per year?
    7.5k and 10k
    7.5k and 10k
    .00200 MF
    718 Spyder - 52% / 45% for 24/36 months and 10K
    911 Carrera Coupe - 69% / 62%
    No incentives
