2020 Toyota Tundra Lease Deals and Prices
145791016
  • tykush21tykush21 Member Posts: 13
    Hi, looking for MF, Residual, and any incentives for 43062.
    SR5 Crewmax 4WD Cement TRD Off-road package
    24/10
    24/12
  • kyfdxkyfdx Moderator Posts: 273,049
    24/10
    24/12
    .00223 MF and 77% residual
    24/10 not offered
  • chlowdenchlowden Member Posts: 3
    Could I get the MF, RV and incentives for:
    2020 Tundra SR5 CrewMax 4WD in 16066 and 44512
    24mo/10k
    24mo/10k
    Either location
  • AboudinAboudin Member Posts: 14
    Could I get the MF, RV and incentives for US bank :
    2020 Tundra SR5 CrewMax 4WD in 85210
    24mo/10k
    24mo/10k
    We don't have the US Bank numbers
  • md99800md99800 Member Posts: 40
    "Could I get the MF, RV and incentives for US bank :
    24mo/10k"
    I know USB's residual right now is 81%. I've been trying to get the MF and so far have had no luck.
    24mo/10k"
    When you shop, ask the F&I person the money factor. Then, once you get it, ask them if that's the buy rate, and if not, how much markup. They may be forthcoming, you never know.
    I wouldn't trust an F&I person to tell me water's wet. Which is why I am on boards like this. :)
  • luxhomeatlluxhomeatl Member Posts: 9
    Can I please get numbers for SR5 CrewMax 4WD and Limited CrewMax 4WD for 24/12k in 30305. Thanks
  • MichaellMichaell Moderator Posts: 269,365
    24 month term not available for SETF
    .00085 and 70% / 69% for SR5 / LTD
  • sgodairesgodaire Member Posts: 1
    Hi, Could I get MF, RV and any incentives for 2020 SR5 4x4, CrewMax, 02878. 10k/36mo & 12k/36mo? Thank you.
    .00223 and 71%
    No incentives
  • bmwdcbmwdc Member Posts: 9
    Hi! Can I get the MF, RV and any incentives for 2020 SR 2.7L, 32225. 10K/36mon & 12K/36 mon? Thanks!
    I don't see an SR trim level, nor any trim with the 4-cyl engine, for the Tundra.
    Did you mean Tacoma? If so, post here:
    https://forums.edmunds.com/discussion/57951/toyota/tacoma/2020-toyota-tacoma-lease-deals-and-prices#latest
  • mackie2k18mackie2k18 Member Posts: 54
    Can I get the MF, RV and any incentives for:
    2020 Tundra SR5 CrewMax 4WD in 73012
    24mo/10k
    36mo/10k
    24mo/10k
    36mo/10k
    .00223 and 77% / 72% for 24/12 and 36/10
    No incentives
  • hsvnolehsvnole Member Posts: 76
    Hello, can I get the MF, RV and any April lease incentives for:
    (1) 2020 Tundra Limited CrewMax 4WD
    24mo/12k
    36mo/12k
    (2) 2020 Tundra Platinum CrewMax 4WD
    24mo/12k
    36mo/12k
    Zipcode: 35806
    Thanks in Advance!
    24mo/12k
    36mo/12k
    24mo/12k
    36mo/12k
    Zipcode: 35806
    Thanks in Advance!
    Only 36 month term supported in SETF.
    .00085 and 69% / 66% for LTD / PLAT
    No incentives
    edited April 2020
    36mo/12k
    36mo/15k
    35806
    edited April 2020
    36mo/12k
    36mo/15k
    Zip = 35806
    36mo/12k
    36mo/15k
    Zip = 35806
    .00085 and 68%
    Can I get the RV/MF and any incentives for the following?
    SR5 CrewMax: 24/12 and 36/12
    15102
    15102
    Assuming 4X4
    .00223 MF
    77%/71% residual
  • rcdubrocksrcdubrocks Member Posts: 16
    Looking for lease numbers and incentives on 2020 platinum crew can 4x4. 36/10 39/10 ?
    Sorry forgot.
    Zip 43606
    Sorry forgot.
    Zip 43606
    36/10 - .00223 and 68%
    39/10 - .00285 and 66%
    No incentives
    Hello, can I get the MF, RV and any May lease incentives for 2020 Tundra Limited CrewMax 2WD. Zip 35806
    36mo/12k
    36mo/15k
    36mo/12k
    36mo/15k
    The new May programs start on Tuesday
  • haris_haris_ Member Posts: 6
    Can I get the current MF and RV for a 2020 Tundra SR5 CrewMax 4WD
    24/12
    Zip code: 32257
    24/12
    Zip code: 32257
    Only 36 month term available in SETF
    .00085 and 70%
    No incentives
  • jayjayb74jayjayb74 Member Posts: 15
    edited May 2020
    Can I get the MF and RV on a 2020 Tundra Crewmax Limited? 24 and 36 month 10k a year lease. Zip code 97219
    2WD or 4WD?
    4WD
    jayjayb74 said:
    4WD
    .00117 MF
    24/12: 75% residual
    36/10: 70% residual
    They are saying they can't do that. What gives? My credit is 760
    Can't do what?
    Ask them if they are using a different bank - our numbers come from TFS.
    Can I get the MF and RV on a 2020 Tundra Crewmax 4x4 SR5 TRD package? 24 and 36 month 10k a year miles zip code 97219
  • houston_marcohouston_marco Member Posts: 40
    Hello, can I get MF, RV and any incentives for a 2020 Tundra SR5 CrewMax 4x4
    24/10k
    36/10k
    Zip is 78253, Thanks in advance!
    36mo/12k
    36mo/15k
    36mo/12k
    36mo/15k
    Can you provide the May numbers when you have them?
  • kim0hyunkim0hyun Member Posts: 22
    Would you mind sharing the MF, RV, and any incentives for 97006 for 24/12 and 36/10&12:
    Tundra 4x4 SR5 Crew and Limited, please?
    .00100 MF
    24/12: 76% residual
    36/10: 71% residual
    .00100 MF
    SR5: 76%/70% residual for 24/36 mo, 12K/yr
    LTD: 74%/68% residual
    24/10k
    36/10k
    .00207 MF
    24/12: 76% residual
    36/10: 71% residual
    36mo/12k
    36mo/15k
    36mo/12k
    36mo/15k
    .00068 MF and 64% residual
  • thewevelthewevel Member Posts: 14
    edited May 2020
    What are the SETF numbers for a 2020 Tundra SR5 Crewmax 4x4, zip 36532. 36/12 or 36/10 if it's available. Thanks
  • westn82westn82 Member Posts: 1
    Hello, can I get the MF and RV based on Toyota's new May lease incentives for 2020 Tundra SR5 Crewmax 4x4? My zip is 63131.
    36mo/12k
    36mo/15k
    Thank you!!
  • skrockij89skrockij89 Member Posts: 28
    Hello. Can I get the MF, RV for the Tundra SR5 Crewmax 4x4 3/36k? Zip code is 59833. Thank you!
    .00068 and 70%
    No incentives
    36mo/12k
    36mo/15k
    Thank you!!
    .00055 and 68%
    No incentives
