Visitor Agreement.
Frank
-juice
Bob
-juice
Bob
-juice
Ken
and spec appropriate tire pressure and load index of tires for a given vehicle's load, NOT for comfort.
they would need to devise something much better than the bulky pressure sensors used with runflat tires before I would think it was a good idea...
-Colin
If you want to give me a guage that tells me the pressure in each tire, fine, but no idiot lights. They are more of a pain than having 1 jillion guages.
Why can't people just be responsible, and check their air-pressure? I'm sick of people suing for stuff they are supposed to be responsible for, and then the manufacturers put in expensive things like air-pressure sensors.
-mike
In a perfect world everybody would do just as Colin suggests. Reality, however, is quite a bit different.
If it works, and it isn't too expensive, I think it could be a good idea. It's really no different than an oil pressure gauge, or engine temperature gauge, and I think most people think those are worthwhile items.
Bob
ABS
Air-Bag
Air-Pressure
Not to mention, what about when you buy new tires? How will different rims/tires effect this? Will they indicate too much pressure as well?
-mike
Bob
-mike
Bob
I've once had some road debris cut into my sidewall causing a slow leak. It happened at the start of my 30 mile commute and I really didn't notice my Forester pulling to one side until I was pretty much getting off the freeway at work. When I pulled off the road, the driver's side front tire was nearly flat!
Similar story with my wife's car. I check her tires regularly too, but somewhere in between she ran over a nail and was riding on 15psi on one tire for several days.
True, the current systems are bulky and cost prohibitive, but I think they provide real time information that could save lives.
Ken
Daniel
I could see this used on the VDC. If it's sensing a difference all the time, as opposed to in curves only or only when there's slipping, then it should know one tire is flat.
Now that I think about it, the "VDC On" light may already notify you of that, if the difference is extreme enough.
-juice
• price-sensitive mainstream cars will get nothing more than a warning light. It would act much like a low fuel warning light, in that as tire pressure gets low in one tire, it would flicker, and when it reaches a certain point, it would stay on.
• Moderately priced vehicles could get a graphic, much like that in Mike's Trooper (which indicates the Torque-on-Demand feature), in which the individual tire could light up, to show you which tire is effected.
• More expensive cars, with trip computers, could even give an actual digital tire pressure readout, in addition to a warning light. Perhaps it could occur whenever you start the vehicle, much like a pre-flight check, before you drive off.
I really doubt that you will see an analog gauge. You would need a gauge for each tire, and that would take up too much real estate on the instrument panel.
Also, what about the spare tire? I guess that would be monitored too.
Bob
It should only require a software upgrade if ABS is in place. Light up when there is a steady difference in rotation speeds from side to side over an extended period.
Spares would left up to you, I guess.
-juice
Bob
I can't tell you how many donuts I've seen on cars that are driven well beyond their intended speed and range.
-juice
Bob
Mark
I can't believe we may get this as a mandatory feature. If this is anything like the current run flats, that's not good.
My father had the Michelin run-flats on a used Lincoln he bought. He ditched the tires quick because they were hard as a rock. The air pressure monitor was also acting up.
My wife and I have both had nails in our tires just in the last few months. Because we visually inspect them about every other day, and check the pressure weekly or bi-weekly, it wasn't a big deal. My wife even has a foot pump in her car and uses it when she needs air. Before she met me, she had never used a pump at a gas station. Tires are a DIY area that she excels in.
Things would be SO much easier if people would RTFM.
Quick - I spilled hot coffee on myself. Who can I sue? Quick - I'm running 24 psi's in my SUV and the tires exploded, who can I sue?
True question from a Swiss friend of mine. "Why do you have signs on your mirrors that 'objects are smaller than they appear'? And why do you have a sign in the restroom telling you to wash your hands? Are Americans that stupid?" (he married an American btw). Umm ...
/rant off
Dennis
Remember passive restraints? The loophole allowed for motorized mice and, even worse, those silly seatbelts attached to the door. How ridiculous were those?
So it'll be up to the manufacturers to come up with something clever that meets their requirements. The ABS sensor idea could work and cost very little.
Not everyone belongs to our little OCD club and checks things like tire pressures every week. We're car guys, so it's normal for us, but my guess is half the drivers on the road have not checked their air pressure this year.
-juice
My wife isn't a "car guy" and she has been checking her tires regularly since she bought a Corolla in the early 80's. :-) She even put snow tires on it in the winter.
Dennis
For too many people it seems, the bigger the vehicle, the less they are concerned with safety, perhaps due to the perceived built-in safety of the behemoths they drive.
-juice
For example when I drove a private cab in Brooklyn the other drivers used to laugh when I checked the air before the shift started. Then again, they also laughed at my carrying my own 4 way and cables; that is until they would call me for help!
On any on or off ramp, listen for tire squeel. They will at the limit regardless, but if they are flat they will squeel helplessly and at slower speeds. Same thing in a parking garage.
-juice
Greg
I'll be the first to admit, I don't do it regularly. In fact I "rarely" do it, even though I know I should—and I'm a car guy.
If the tires look low, I check them. If they don't—I don't check them. And, I'm supposed to be one of the enlightened ones..
Ok, so now hang me out to dry... But I bet (if you're being honest) there are more people on this "educated Subaru forum" like me than not.
Bob
I check both my vehicles tire pressures at least once a week and *always* before a change in load (ie. roadtrip with extra passengers and cargo).
Ever since I was involved in a car crash due to a blown tire (I was a passenger), I've become quite sensitive about the only 4 contact points that keep us on the road.
Ken
But like I said, I'll end up "hearing" a tire with low pressure before I actually measure it. Only the 626 leaks any air at all, actually.
I guess I could rate myself by the lowest I've ever let it get. We set the 626 to 33psi, and I've caught one tire at 28psi. The Forester runs 33psi and stays there. The Miata runs 28psi and stays there, except the spare, which I had to add air to once.
-juice
Bob
-Frank P.
I usually check my spare every month or so. I usually just fill it to the max psi so that I don't need to worry about it every week.
Ken
Speaking of which... I understand there's a new movement afoot in NY to outlaw radar detectors. Paison, ya listening?
Bob
I have two - in each of my cars. I borrow one of them to check the wife's car.
-juice
-Frank P.
Bob
Mine would probably do the same thing.
Though I'll hand it to her. Even though she's very Point-A to Point-B oriented, she drives in a spirited fashion. She's actually pointed out to me which specific tire was low, not by looks, but by driving it. I was impressed.
-juice
-Colin
We both visually check almost every day.
Dennis
I have a nice little digital tire gauge from Radio Shack and I check once a week. I check my husband's car once a week, but I have to do it at night with a flashlight so as not to embarrass him with the neighbors ;~} He does not like me tinkering with his car in front of people. I don't understand why - I don't mind if he helps me with the housework?
Patti
bit
-juice
Odd thing I noticed: On my Forester, I have really long valve stems and the caps don't cover all of the threads even when snugged down tightly. Is this anomalous? When the time comes to replace tires I will no doubt have the stems replaced as well. There's always the threat of having the stem snapped off on a curb. I replaced the stems on my old Jetta with short ones from NAPA and had no problems. Then again, I had problems aplenty with those soft Brazilian-made (no offense, juice) GTI/GLI alloys.
Ed
Just remembered I have a spare to check too (forgot it was there).
Like Bob I carry two guages, one via air compressor.
bit
Don't forget our chat tonight. I invited a couple of newbies that are car shopping to join and ask questions, so pop in if you can.
-juice
