Visitor Agreement.
@thecardoc3 was a single engineering change made to go to this 20 weight oil, do you know from observation? Is this oils excessively thin? Are techs dealing with unforeseen problems from it? Speaking from a perspective that many believe that the change was completely arbitrary to boost fuel efficiency by an immeasurable amount.
http://www.lube-media.com/wp-content/uploads/Viscosity-matters-WEB-ONLY-Sept19c_FINAL.pdf
They are very sensitive to low oil conditions in terms of valvetrain noise. Anything approaching a quart low will induce it.
@thecardoc3 All good questions and I do not have specific answers. All I know is that in an era where engines have generally gotten quieter, these engines sound "loud" to me. These are also my first Subarus. I found this in a forum which seems applicable: "Subaru's tend to have loud clackety motors when listened to from outside the car. The valves of an H4 motor are essentially at the bottom of the car and that valvetrain noise bounces off the pavement and out from under the car. Whereas in a typical inline 4 motor, the valves are between the block and hood and that noise gets dispersed around the engine compartment and never really makes it out."
That 540 Rat still talks about following the rule of 10 psi per 1,000 rpm, and apparently the 20 weight being at the low range of the 30 weight does not maintain that. Is there any validity to that rule today as machining accuracy has increased significantly in these last couple of decades?
I am surprised when you talk of fully-warmed up being 300F. Many current oil spec sheets show a peak temp of 290F, and one would not want to be at the peak of any engineering limit as the oil becomes sacrificial then does it not? From your comments it sounds like oil performance is keeping up anyway.
The 2013 Forester has the newer FB25 block, and that one requires 0w-20 oil. This is the one that will clatter for a second or two upon startup before it quickly quiets down. When I was having the oil consumption issue (short block replaced under class-action settlement) a couple years ago, I asked about the possibility of the oil simply being 'too thin' for the engine tolerances (I was thinking the piston rings), which was allowing it to drink about a quart of oil in less than a thousand miles (varied depending on how hard the engine was working). The service guys said that the heavier oil wouldn't solve the consumption problem and could possibly cause oil starvation in the cams due to tighter tolerances and smaller passages. I don't know if they knew this or were just making it up.
I haven't had any issues with consumption since the block replacement; I think I might have around 30,000 miles on the engine since then. However, the tech didn't do a great job sealing it up, and I have two points of external leakage on the front of the engine now. I haven't identified them, but I suspect at least one is a camshaft seal. I'm hoping both are up in the heads, as those aren't tough to fix with *relatively* minor surgery.
All that being said, the engine is naturally louder than inline four-cylinder engines, in general. I wouldn't call them noisy, but certainly more audible.
Connecting Rod Clearance spec is 0.0007" to 0.0015" ( that's not a misprint, 7 / 10,000's of an inch)
Main Bearings Clearance sec is 0.0004" to 0.0012" The mains are even tighter.
Starvation and bearing failure from oil that is too thick to flow is a common failure.
https://www.sun-sentinel.com/business/fl-ne-auto-tech-shortage-nationwide-who-will-fix-our-cars-20190809-bm77cet2jfgqdcpe2rekebll6u-story.html
On one hand LOL, on the other hand it is the teacher's job to take the unfamiliar and make it familiar, take the talentless, and inspire them with confidence. There are definitely some terrible problems with educational methods in the USA. The kids who could not read in the 5th grade? They still could not read in the 12th grade. Whose fault is that? They were labelled on day one, put in the "dumb" reading group, and that effect snowballed in their psyche, sometimes throughout the rest of their life! So when this article labels the newbies as "there for the money", well, who is not there for the money? I enjoy my job, but, I am there for the money. You guys? Cars are the perfect example of "break it down into its components and it becomes understandable."
"A lot of students just don’t have his drive"
This is a big problem with young people today in general. I know business owners that cannot get employees to show up for work, they cannot find replacements, their selection of young people is just downright awful. A fortune communications company employee told me the company cannot identify tech candidates who can pass the drug test. This is a role where they have internal training, take someone who is ignorant, and fully train them for the job.
I know there are always lazy people in a civilization but it is truly bad now. Yes, a job like working on cars that is similar to 8 hours of going to the gym? I can see that today, finding people to do it is nearly an impossible task.
The troubleshooting with the computer, the extent to which devices are used today, that boggles the mind.
The second video was from the most time that I have gotten to spend with the tool while helping Rob learn how to interpret the data that was going to be generated. For guys like me we had to learn how to figure out vibrations and their causes (source) totally on our own. After forty plus years of fixing vibrations in cars, just by feel alone, I have gotten to be pretty good at it. But the path to get "here" was a mixed bag of successes and failures. Now with tooling like this to assist the technicians, once the vibration is confirmed to be related to a given component, or system hopefully they won't have to have as many hard days at the job honing their skills.
There is a lot to learn with this tool. The first thing is any vibration over 10mg (milli-gravity) is strong enough to be felt. Watch either of the videos closely for the "Ts". T1 is a single tire vibration. T2 is a vibration happening at twice the frequency if a T1, and a T3 is of course three times the frequency of the T1. Consider that the driveshaft will be spinning somewhere between two and three times the wheel speeds. Watch how the T2 and T3 are sometimes low and T1 is very high, then you will see the T1 dropping as the T2 and T3 increase and decrease in amplitude. That is three tires with vibrations, that are usually out of phase with each other but on occasion get into phase. That is something that can make just using a learned feel very tricky. The advantage of the tool is once you see a P1, that is a driveshaft vibration due to runout or imbalance and now you shouldn't be distracted by the tires.
Here is a capture from the first video showing the P1 very clearly.
They were doing alright but the landlord does not want that type of business and is forcing them out. They can not afford rent anywhere else in the growing town.
They are selling off a half century collection of parts for pennies on the ten dollar. Some of it like wheels will get melted down rather than get into the hands of people restoring old bikes who would otherwise see the parts as gold.
The owner is around 60.
Meanwhile those who are good customers continue in vain to find anyone competent enough to touch their bike.
Ummm...am I eligible? (I have no experience at all.)
I suppose if your shop is busy enough, no need to entertain one-off projects like a 25 year old Audi Wagon with Porsche touches.
The poster didn't respond to that question.......
You mention that trailer harnesses are suspect. I guess the install does not match the expense of that Cadillac. I would expect an installer to use better judgement and incorporate strain relief and vibration protection. That is an egregious install job.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwj60NS3hKfuAhVDp1kKHfoFC7IQFjAOegQIIBAC&url=https://www.mobil.com/lubricants/-/media/project/wep/mobil/mobil-row-us-1/files/faqs/mobil-1-oil-product-specs-guide.pdf?la=en&hash=B478EACF4BAC5D7B9A3D33763B53E67669592EE5&usg=AOvVaw24DfL4w38u7I09QLpAYaJB
A general label on the back of the bottle says "For diesel and gasoline engines."
This caught my attention because it was Dexos2 rather than Dexos1, therefore many
would assume it's a better Dexos rating for the oil.
Is this suitable for use in a Chevy Cobalt 2.2 engine?
ACEA ratings take some studying, they aren't linear. A1/B1 is a low HTHS product the same as a A5/B5. The difference is the A5/B5 is truly a long life version. While Dexos1 is an extended life specification it doesn't need to meet A5/B5 requirements. A brand can make a product that will meet both specifications if they wanted to, but that would of course be reflected in the price of the product. No, it would not. Being Dexos2 doesn't make it a better or worse product when comparing it to a product approved for Dexos1 Gen2. They both advanced products and would be an excellent choice for a vehicle requiring those specifications (dexos1 for a dexos1 requirement and dexos2 for a dexos2 requirement) while being a poor choice for a vehicle requiring the other specification..
When a vehicle shuts off vacuum is created, drawing all vapor from the tank yes? So there would be little O2 to assist in oxidation of the fuel?
I know winter is helpful as all chemical degradation slows down with lower temperatures. Except for those of you who have nice weather all year long.
I think I used Seafoam in my last Outback fill-up but I cannot quite recall. That gas is likely two to three months old.
