Dodge Dakota: Problems & Solutions
Thanks and I hope everyone is having a great 2002 so far.
Robert
Still going ok?
Robert
not expect..Truck gets looked at 1/23 after fixing cracked headlight cover, and poor weatherstripping.Don't recall seeing any "real correct" fix for the concern-problem of the clunking on any postings- otherwise direct me to a post,thanks. Just making sure It's documented at the dealership, almost 11.5k miles !! Truck runs great otherwise! Ger
So in Reference to the above, If I Don't Want to put on the extra Miles, that is to Drive for over 30 minutes, to somewhere then..., Really dont have anywhere to go yet, still trying to meet a Lady - Hence the Screen-name :-)
1. Should I be changing the OIL more often? If so? more often than what is says in the manual?
2. Or is there some otherway around preserving My QC engine's Oil and/or engine-mechanicals
3. Yes I have ( seen the Vapor ) coming out of the tailpipe, Its my recollection that for Every Gallon of Gas that is Burned there is 1 Gallon of Water Blown out the tailpipe... Though on my nissan I have a lifetime warranty on the muffler through O'Reilly auto-parts and I thinks I have changed it maybe 3 times since '87' when I bought it.
OK, Hmmm is there a ... Don't say it... uh, Additive-Oil that I might want to add to the engine that would allow me to Keep the Oil in the engine, for the way that I drive my QC presently, untill I finally either meet a Lady or Find somewhere to go on a Regular Basis, Thus finally allowing the oil to do it's job as it's intended...
"Wanted, a nice looking woman who enjoys fishing, cutting bait, baiting hooks, making lunch and owns a boat and motor. Please send photo of boat and motor."
James, this is your opportunity.
Bookitty
If I Don't Want to put on the extra Miles, that is to Drive for over 30 minutes ...snip...
1. Should I be changing the OIL more often? More often than WHAT?
If so? more often than what is says in the manual? NO! I already said NEVER MORE OFTEN THAN EVERY 4000 MILES!
2. Or is there some otherway around preserving My QC engine's Oil and/or engine-mechanicals. YES...DRIVE YOUR TRUCK (have you ever heard "use it or lose it"? This is what it means)
Letting a vehicle sit around is the most sure way of having problems with it.
OK, Hmmm is there a ... Don't say it... uh, Additive-Oil that I might want to add to the engine that would allow me to Keep the Oil in the engine, Quality oils ALLREADY contain all the additives they need
Bookitty
With women, well, they don't always respond to repair. Sometimes they just don't respond!
SO focus on the dakota. WHen its paid off, then look for a woman.
Hey! I resemble that remark. ;-)
KarenS
Owner's Clubs
Well anyway, sorry its so long but I havent been on in awhile so I thought I would make up for the lost time.
Robert
Bookitty
Ah well. Live and learn.
Its not the first time I've incurred the wrath of a female.
Probably won't be the last either!
1. Oil leak between engine and transmission/transfer case
2. Ashtray opens when dash is bumped or driving over bumps
3. Front-end pops when making sharp turns
4. Engine idle gets real rough at 500rpm and below sometimes and will occasionally die and have to be restarted. Will also die sometimes when shifting from reverse to drive with vehicle at full stop (There is a TSB out on it I believe)
5. Engine diesels when under load/going up hills real bad with regular, a little with mid-grade and quiet with premium fuel (I have tested between 3 different fuel stations and it occurs with grades of fuel and not with brands of fuel)
6. When braking it is starting to shimmy and squeal. Also after braking, then letting off for a second and re-braking the pedal will go almost to the floor and I have to let off for a few seconds before pushing pedal again for the brakes to become valid (Its not the ABS, there is no pulsing its just real mushy)
Wish me luck.
Robert
CAUSE: FLASH MODULE
08194496 VEHICLE PERFORMANCE; COLD START
HESITATION - TSB 18-08-96
152 W40
1 4275086 LABEL - GENERAL INFORMATION
1 4669020 LABEL - AUTHORIZED SOFTWARE
FC: FM
PART # 4275086
and at the bottom:
26306 (CHK IDLE) FLASH MODULE 08194496 .5 TSB 18-01-01 FLASHED POWERTRAIN CONTROL MODULE.
Good luck either way..
To henne: Ouch...notta lotta fun, hunh? And disappointing that it's your second go round with this model. Hope everything is resolved on this one!
KarenS
Owner's Clubs
Bookitty
5 oz of trac lok additive Note that the stuff is sold in 4 oz bottles I think so guess what, you buy TWO!
front axle 3.55 pints 80w90
Courtesy of the BOB.
Robert
What I find shocking is the utter lack of urgency I have witnessed in the area of service. Seems like once you drive off the lot, its goodbye charlie.
Ahahser had to pound and pound and pound to get his PCM updated. Good news is, and I had this done also, is that it works. It worked then and it works as I type this. My rig runs like a fuel injected vehicle should, not like a putt putt lawn boy or something. Now thats not too much to ask after forking over mucho dinero right?
Hell, camp out on their doorstep, call the service manager every hour on the hour. www.4adodge.com has an email link on there I think, write them an email. Believe it or not, they responded to my complaint about the lousy rotors and when I called for an appoiintment, the service manager knew all about my tirade!
Did I get lucky? Dunno....but I got results that way.
My point? "thats normal' and "do YOUR homework, and check back in LESS than a month".... nothing beats a well educated and prepared owner.. keep your cool but dont let up..
ok ok.. my .02 worth.. and thanks for holding my beer.
Robert
Robert
I do not know if it will come on during extremely high temps; it would seem to me that the mechanical fan has plenty of oooomph to do the job.
Exide was chosen by SEARS in 1994 to manufacture the Die Hard line of batteries, ending a 60+ year agreement with Johnson controls. Following admission of Exide that it engaged in fraud (regarding the false test data Exide supplied Sears regarding test results) Sears ended the ralationship in 1999 and has resumed using Johnson Controls as the supplier for Diehard batteries.
To Sears..........GOOD choice.......finally! ALl they had to do was ask Kmart how many exide batteries we replaced and presto its a no brainer to stay with JOhnson Controls!.
I remember another person posting here quite a few months ago about them feeling the same "torque steer". I wonder if the transfer case is shifting in and out of 4wd on its own.
Has anybody else felt this same thing on their '01+ dakota?
This is in ADDITION to its programming for the AC system.
I beleive there was a TSB about the electronic xfer case. Perhaps you should look into the TSB website about this.
I was tempted to remove the viscous drive fan for the winter to help keep heat in and maybe squeak out a little better gas mileage.I removed the fan on my van last winter and the noise reduction and quicker warmup was great especially in the first ten minutes of operation.
Most of my driving is highway with no stop and go city , so air flow isn't a big problem.
or the Bosch 4418.
I did a search on the AutoLite web site for my
truck,2001 Dakota,4.7,etc,, comes back with
these plugs; AP5524(platnum) or 5224 copper.
what is a 3923? Did I get the manufacture wrong?
mick
NOT for any of the ol' 1960s-based engines.
Details;
When It came time for my 4.7L to get new plugs, I did a lot of research. I searched over 5000 posts
across 5 different websites. Although folks have tried many different sparkplugs... by far, the BOSCH 4418 was found to be best for the 4.7L V8.
You may do your own research if you wish... if you find somthing different, please post your findings here for all to see.
I just got off the Bosch web site. The 4418 was listed for both the 5.2 and the 5.9 engines. According to their site there is no Bosch plug recommended for the 2000 4.7l engine! I don't care what the Dakota web sites say work. Bosch may have invented the spark plug but "their" web site says they haven't invented one for the 4.7 yet. Rick
Sure, we're not using stromberg upgraft or webber side draft carbs and the sparks come from advanced coil on plug setups, but the premise is pretty much the same. Compress air, add measureed amt of fuel, ignite a spark at a predetermined time, and BOOM! Explosion, piston moves con rod, which turns a crankshaft....et cetera.
Autolites site and catalog list the 5224 as the correct plug gapped at .040 for the 4.7L engine.
Ron35
"#1442 of 1447 4.7V8 spark plugs by bpeebles Feb 07, 2002 (05:06 pm)
BOSCH 4418 is for 4.7L!
NOT for any of the ol' 1960s-based engines."
The original question in message 1438 was
"I'm confused,,,people recommend the AutoLite 3923
or the Bosch 4418.
what is a 3923? Did I get the manufacture wrong?"
The correct Autolite replacement plug according to the Autolite web site is the 5224 copper, not the 3923. I stand by my reply based on the manufacturers data on their web site. If the 4418 is correct for the 4.7l thats Boschs error, not mine. ;-) Rick
So far I have Amsoil 5w30 in the engine and 75-140 in the rear. I have the 75-90 for the front diff and atf+4 approved Amsoil for the tranny still to go and am awaiting the knowledge of you guys on the transfer case.
Also is there an easy way to put the fluid in the front diff? There isnt much clearance for funnel and bottle.
Thanks for any answers in advance.
Robert
