Visitor Agreement.
So are you saying Nissan is challenging to work with on leases?
This is a great example of lease terms being so out of whack in favor of the buyer (lessor).
I already have an appointment with an electrician to get a 240v outlet installed.
I didn’t think Nissan leases were Fully transferable, but it seems I may have been mistaken. Odd since Infiniti makes the original leaser remain responsible, even if someone takes over the lease.
So, theoretically after selling the Subaru and pocketing $1400, I would have been able to bank 7 months of payments. Would have been a nice down payment on something in the spring! Oh well. Still considering replacing the X1 if we find a good deal on something the wife loves. Might sit tight and see what spring brings. If we truly do not go back full time thats as good of an excuse as any to flip the fleet!
As I mentioned, I’m having an electrician install a 240v outlet in our garage.
The Leaf came with a charging cable that has a NEMA 14-50 plug.
My Chargepoint charger that I already have has a NEMA 6-50 plug.
Which plug should I have installed? I believe the 14-50 will give me more flexibility for potential future chargers. But maybe just having the Chargepoint on the wall will be the most flexible option for any future EVs.
For example, let’s just say hypothetically, I placed a deposit for a Rivian. And perhaps with that a new charger would be beneficial...would it be better to just have the 14-50 installed now (which will work with the Nissan charger also of course)?
Or maybe these chargers aren’t really evolving all that much and my existing Chargepoint is fairly future proof. Or maybe a future charger will be hardwired anyway and it doesn’t matter.
anyway, point of this particular ramble, is that they have different plugs depending on the units, but he had adapters to convert to the plug the car needed. I assume Tesla supplies one of those, in case you need to use a non-Tesla network?
so in this case, seems safest to get the most modern one and just make it backward compatible to the leaf using the adaptor, since that would set you up better for the future.
Learned a couple of weeks ago that the office will no longer be a place for employees to have a permanent work space; it will only have meeting rooms and reserved cubicles for occasional work.
I probably should have waited to replace the Enclave and banked a few months payments... but couldn’t help myself.
Again, congrats!
WFH is interesting. I’m used to it now and like it a lot. Handy to be able to knock out things like laundry while sitting on a call. Plus being able to run an errand here and there. Not that I do that
I would be surprised if my wife goes back in before Q2 2021, and even then, would bet it is part time, likely without a dedicated desk. So just as likely, they let her just stay home for good. In which case, really no impediment to relocating next year!
I upgraded the 40A Clipper Creek charger I had to a 60A Tesla charger this year. They had to pull out the old wire and run new wire to support the amps. But it was worth it, the 3 previously added 30 miles of charge for every one hour connected, now it's 45 miles. When you get into the 100+ kWh batteries on the S/X, Rivian or a Cybertruck, this becomes a significant time saver.
So makes sense the deal is not necessarily a national one.
I actually don't know what gauge wire they ran from the breaker to the garage - I suppose they can pull a larger gauge pretty easily at this point.
The Chargepoint I currently own is a 32 amp model. I'll have to see what the electrician has to say tomorrow as to what the maximum amp breaker I can have installed and go from there. I don't even know what dictates that? If I can only get up to 40 amp anyway, then I may as well use the Chargepoint. But hopefully I can get to 50 or 60 amp and have capacity to upgrade down the line.
I installed a 14-50 receptacle in my garage many years ago. I was plugging in an oven there at the time (nothing has changed, sadly), so I just bought a matching cord for the unit, but I figure the 14-50 is more versatile since it has a port for both hots, the neutral, and the ground. The 6-50 only has the hots and neutral, so even if you adapt it, you still don't have that direct-to-ground connection.
out of curiousity, it looked at local supply of leafs. The big stand-alone dealer has 4, all Plus models. The auto mall store has a whopping zero. And the other stand-alone dealer (2 stores now) shows 7, 3 base and 4 plus.
I kinda like this color. But I suspect that NJ incentives are nowhere near the level CO is at so the lease quote would be much less enticing. especially is supply is super thin.
https://www.mthollynissan.com/inventory/New-2020-Nissan-LEAF-SV-1N4AZ1CP9LC306731/
Used to get paid weekly at Hertz and got somewhat used to it but Enterprise is the more common bi-weekly. My pension comes in monthly so it's nice to have something else coming in. Still enjoying work so will stay until I finally get tired of it...got a good couple of yers left in me at this point!
