Dodge Dakota: Problems & Solutions
bonnie_rick
Member Posts: 115
world of Dodge Dakota Maintenance!
Bonnie Rick
Conferences Manager, Town Hall
Edmunds.com
Bonnie Rick
Edmunds.com
To access TSB and Recall data, I suggest viewing http://www.nhtsa.dot.gov/
Select Vehicle & Equipment Information" under Car safety. Then select Tech Service bulletins or Recalls.
I have had better luck with the selection window on the left side of the screen by entering 2000, Dodge Truck, Dakota and leaving the last selection blank.
Note the new April Recall Update on the main page. It contains a Dodge Dakota Recall for 1999 and 2000 Tow Hitch fractured receiver mounts. I mention it because it is not in the TSBs.
A source for the details of a TSB is www.alldata.com for a fee however.
Has anyone ever seen this before? Is it just a suspension adjustment?
Wondering if anyone else had solved the problem and what fix they implemented.
By the way I am going to go with Mobil 1.Is the filter out(Mobil) for the 4.7L 2000 Quad yet?What is the #?
Allen-
Allen-
With my constant cleaning, the spot has not fully dried yet since Monday. So far here's what I've done/used:
Bissel carpet cleaner/extractor with Bissel Cleaning products
Tough Stuff Carpet cleaner
Baking soda and water
1Lifter carpet cleaner
Resolve carpet cleaner
One of those "As seen on TV" Spot Removers
I've also taken it to a Car Wash/Deatailer and they used an extraction unit and some citris smelling Orange stuff.
So far, Resolve has worked the best. It fully removed the stain from the rear floor mat, but I soaked the mat in my tub with diluted Resolve overnight. It has also done most of the lightening on the stain that remains on my floor.
Any suggestions would be appreciated. So far, I've had two recommendations from the car wash/detailer: Try an oxidizing cleaner (can't find one in the local stores, yet), or take to a full service detailer that is equipped to dye the rug if necessary. I've also called a few residential carpet cleaners to see if they would try to remove the coffee stain, but none was willing to do such a small job.
Does the 4.7L take the FULL 6 quarts with the filter change?...Be nice..
Allen-
filter change?..."
YES, nice enough? Rick
Allen-
Quick questions from a newbie to this group.
I'm looking at a 1997 Dakota Sport (V8 Automatic) for my son. There is a problem with though. The vehicle was wrecked (drivers side door, fender, etc). Looks very good now. I will have it checked carefully before I purchase it.
Anyway, to the remaining problem with it. According to the owner, it is very sluggish when you first start to roll. After you get to five to ten MPH, everythings fine. He said that he did a tranny oil and filter change and found a ton of sludge.
What are my options as far as rebuilding this goes? Will a rebuilt tranny work OK? While I'm doing this, should I get heavy duty torque converter and other parts?
Any advice would be greatly appreciated.
Any other problems with this model that I should know about?
Thanks in advance
Eric
Anyway I put all 6 quarts in,live on hilly ground.Next parking lot I'll double check it.The book does say 6 quarts not 5.1/2.
"Jack" I hope it is not a build issue,that would mean they gave me the wrong manual..
Allen-
Black "permanent" marker ink (a sharpie marker) from white jeans
Axle grease from our lite beige living room floor.
It has save 8 - 10 pairs of dress pants for me - I think it's the best.
The URL for it is:
http://www.quicknbrite.com/
for 25 - 35 bucks, I think it may be worth a shot for you. I have used it on lite gray auto carpet in my 92 van for years (red Kool-aid & a 3 yr old back when).
For anyonelse also - this is one product I really like & has paid for itself many times over!
Let me know if it works for you.
PDS
only does it catch the eye of auto enthusiasts, it
also caught the eye of a local constable.
He claims I was going 61 in a 45 zone. I really
wasn't, really! In fact, I was on my way to play
golf and I had just turned onto the road leading to the golf course. The cop was coming from the
other way. He made a quick u-turn, pulled behind
the truck ahead of me and on went the lights. The
first truck pulled into the enterance to the golf
course to get out of the way.
I pulled in also, to go to the clubhouse, when the
constable signals me to pull over as well. After
the traditional license and registration bit, I
lamented that I could not being doing 61 since I
just entered the road about 200 yards back.
Obviously, he didn't believe me.
To add insult to injury, my boss, with whom I had
the pleasure of sharing a golf cart with for the
next two hours, passes us as I am sitting there.
Finally, as I am paying for the round, the person
working the counter states that they were right
behind me and had me pegged at 45 mph. But, they
have expired tags and don't want to get involved
(yeah, sure).
Needless to say, the golf game was a disaster.
Well, to sum it up: Ticket: $97; Golf round:
$62.50, Loosing to your boss: $36, having to tell
your wife: Priceless.
colbates: I'm not familiar with the other products mentioned, but I use one of two cleaners to eliminate stains: PRO 409 (any store) or Oil Eater (I get it at BJ's Warehouse).
Is there a reputable auto shop on this earth??????
The manual for my Dakota seems to recommend a 5W30 oil at all times for the 4.7 auto, and I have been adhearing to it. Is this what everyone is doing? Thanks.
Or just move to Texas where it's 60 in the winter.
Anyway, dealer wanted me to buy a replacement. After a few choice words with the service manager, it was replaced at no cost. Of course, now I have to get new plates
KnK
Thanx, Scott
CHECK YOUR MOUNTS! Mine was dealer installed with only 2 screws, not nuts and bolts as it is now.
KnK
The paint methods used today have the finish
"baked" as the vehicle bodies pass through an oven. Just make sure you've cleaned the surfaces thoroughly, so thayt nothing gets between the wax and the paint. (clear coat)
Jim h
Like Jack I have been using Meguiars,not the spray but the 3 step #1 (surface prep) #2 polish(Deep crystal)#3(Gold class clear coat wax)all liquid and it seems to be a 4 hour affair(washing drying wax on wax off).I have to say I did a lot of looking around an Meguiars is suspose to to be one of the best.I'm not all that impressed.Seems like it needs to be 3 stepped once a month!
Don't get me wrong I don't mind spend time but 4 hours,there has to be a better way.
I have the Flame Red which is cake to keep looking clean compared to Black and the Green.But like I said before I am not all that impressed with Meguiars.($45.00 worth).
What is everyone else using??I'd like to know.Maybe I'm not the only one who feels like this.I need to learn.......LOL
PS.I have heard of the Zaino brothers,now that is expensive stuff plus I have not seen it applyed in person.Any other ideas????
Allen-
I bought the new tutle wax paste which is carnauba mixed with some other new ingredient with a funny name. I'm pretty pleased with it. I did it about a month ago, and with all the rain since then, and a few washings, it still holds up pretty nice.
You'll probably have to experiment a little until you find something you like.
Mailman
My main concern are Texas bugs and gravel chips that are quite common out here in the boonies. The L/G 'builds' coat by coat (w/o yellowing over time) into a barrier that keeps chipping and staining from being too noticeable. It was developed for the leading edge of airplane wings, and it works quite well on boat hulls as well. :-)
p.s. i know double posting is frowned on but since the rear end thing happened just wanted to notify everyone, so i am posting in quad and maintenance.
robert
<<A HREF="http://www.guarding-our-earth.com/amsoil/knairfilters.shtml#">http://www.guarding-our-earth.com/amsoil/knairfilters.shtml#>
Obviously it's an Amsoil site and not objective but it has me wondering if I want to use a K&N air filter.
Basically, it states that the K&N is no better at filtering out dirt particles than standard air filters- but does allow more air and with this increased volume of air also comes an increased volume of dirt particles therefore creating a "dirtier" engine than you would have with a standard filter.
Any comments?
(P.S. what is the official K&N web site address?)
