Visitor Agreement.
NORM: National OrdeR of Moose (there might even be such a thing!)
I believe Bruce said he was going to Malaysia yet again (Iwonder what kind of mileage he gets on those trips).
scottie
National Order of Real Mopars
Once I catch up on the 500 or so Dakota appends... I will be heading out on a well earned vacation. (Fly fishing for native brookies out in the boonies)
My Dakota will be getting the 20K mile service this Friday. I hand washed/waxed it thisafternoon using Zymol (true carnuba Wax... no petroleum products on my precious paint!)
Idle problem seems to be solved, it took a third update to the PCM to fix it. Idles 625-650 in drive(approximately BIGLUCY! ha ha)
No more stalls on cold starts. That's a plus. Idle is much more steady and how should I say, "solid". Maybe the 4.7 ain't so bad after all.
Still working on the warped rotors and even more warped drums.
45RFE is well, a mystery. TOday it shifted fine no matter how hard (or easy) I drove it.
Best news is I am no longer going to track you down and "borrow" your PCM. Since mine works now, I won't need yours. Thanks anyway!
But your rotors.........................
Are you saying they applied the SAME PCM flash 3x or are you saying that there has been 3 distinct updates issued by DC? (each being different)
If there are flash updates this often... I think I will wait another year or so until things settle out a bit. My 2000 Dak is running quite well and I have one of the first ones sold in 1999. The more miles I put on this 4.7L V8 Hemi... the smoother it gets.
At any rate, it runs good now even if the idle is a little quick. I'll live with that anyday instead of stalling etc.
I never was a fan of Detroit's first efforts on new designs which is why I sorta cringed when I learned that the v-8 in my Dakota was not the tried and true 318. I went for it because I knew it had already found time under the hood of the Grand Cherokee so I figured whatever bugs are there must have been solved. SO I thought. Other than the PCM issue, it really does run ok. I'll get back to you in a few years and 100K later and we can compare notes and stuff. Maybe the 45RFE will have even learned to shift by then right?
What kind of oil and filter do you use?
Drive safely.
scottie
3.55 less low end power, better gas mileage.
3.92 more low end power, less gas mileage, better for towing.
Salesman said there wasn't really any difference in gas mileage, that 4x2 vs. 4x4 was a bigger factor in MPG.
As I said, just what I've heard.
The pop up trailers usually don't have a high weight factor so I don't think you'll have any problems with the 3.55.
The advantage of ther 3.92 is you get more power to the ground quicker. I like it because I'm a lead foot. I have a 5.2 with 3.55 in one Dakota and 4.7 and 3.92 in the other. Can notice a slight improvement in acceleration in the 3.92 and notice it eats up more gas. Also if towing massive weight the lower gears (3.92) help give you the most torque your vehicle can deliver (without modifications)
Thanks again for the info... I feel much better now
Now I am reading that the fan clutch is slipping and this is the cause of the roar. I think these are two unrelated issues, one when it is hot at the fan kicks in when a thermal condition is detected and the other is the converter slipping till it warms up.. Are either of these issues anything that should be of a concern? My truck has done this since new. now 5600 miles.
Brett
Here's comfort for you: With 15K on my 4.7 my fan clutch almost ALWAYS roars for the first 1/4 mile or so then calms down. I don't hear it again until I shut off the motor after which the heat buildup makes it kick in again.
Its when I DON'T hear the roar is when I get a little nervous. I learned over the years with viscous fan drives that a little noise is reassuring that the fan drive is simply doing its job.
One solution I discovered is to turn up the radio. Or I also hold my coffee cup off my lap when my 45RFE shifts from second to third. That takes my mind off the fan clutch roar, if only for a second.
Thanks again
Brett
mopar67, thanks for your excellent description of how the fan clutch works!
andy_jordan "Dodge Dakota Owners - FAQs" Jun 27, 2000 12:23pm
Give me back the 727 w/o all the electronic razzmataz. Give me a tranny that shifts properly regardless of what the computer does. Give me a tranny that runs on Dexron and not a specifically expensive dealer item only fluid. Give me a transmission that had a proven record of performance and reliability. Give me a transmission that could take a lot of abuse (like my Cordoba)and still work. Give me a transmission that takes ONE filter, not two.
Better yet, I'll take bpeebles five speed!
maybe chrysler designed this so we would not fall asleep while driving?
the check engine light on the dash stays on although the engine seems , sounds and acts normally. what could this be..????
anyone
I ended up not having to "borrow" bpeebles PCM. Nearly 2 1/2 weeks after the update, no problems at all with the idle. If anything its a little slow to step down to the 600-625 range but I'll live with that over the stalling. Nor does it drop down to 500-550 like it did before. That was never a problem because it only occurred when motor was up to operating temperature.
But the stall out on cold start is gone.....for now.....god only knows whats next though. This truck of mine is like a box of chocolates, you never know what you are going to get next.
Stay tuned....
Jim, the owner of Gene Poon's transmission shop, died of cancer. Jim knew his customers, and had so much of their trust that customers would ask him advice on what new cars to buy. When Gene bought his used Intrepid, he first asked Jim about the status of the 604/Ultradrive. Jim assured him the early problems were solved, and Gene has been happy with his Intrepid since. However, when Jim found that Gene had bought one, he sent a script for customers buying new or used Chryslers. If anyone benefits from this, they can mentally thank Jim...
CONGRATULATIONS, NEW CHRYSLER OWNER!
Some advice on the 4-speed automatic transmission:
This transmission, which is used in virtually ALL Chrysler Corporation [Chrysler, Plymouth, and Dodge] cars and minivans, got a bad reputation early on for poor reliability. The weaknesses in the transmission have been fixed. But there is something which is the OWNER'S responsibility to see to: the proper care and feeding of this transmission.
Observe the "Severe Service" maintenance schedule.
Use, or have your mechanic use, only a QUALITY transmission filter when the transmission is serviced. The best is a genuine Chrysler MOPAR filter. THERE IS A DIFFERENCE. Some aftermarket filters, though they fit, are actually Universal types intended to fit several different transmissions. Some have the same filter in boxes with different numbers! In the case of the MOPAR ones, every one is different!
Use, or have your mechanic use, ONLY the correct transmission fluid, which is Chrysler Type 7176. The current version from Chrysler is called 7176+2, and is recommended. Quaker State and Pennzoil make a "7176" fluid which is compatible and equivalent to 7176+2; it is also OK. Some Chrysler owner's manuals say that you can use DEXRON if the 7176 fluid is not available. DO NOT DO IT! [9096 for 2000 and newer cars]
If the 7176 fluid costs more (it does, about 50-60 cents a quart), PAY IT.
If you need to add a pint of fluid and 7176 is not available, drive a few miles to the next place which has it. This will be less harm than using DEXRON.
If a mechanic says he can substitute a little DEXRON and it won't do any harm, LEAVE!
If someone says he can use DEXRON plus an "anti-friction additive" in your Chrysler transmission, LEAVE!
If you have some DEXRON lying around from your old car, give it away to some friend with a GM or late Ford car.
If somebody puts DEXRON in, take it to a shop which uses 7176, and have them drain the ENTIRE transmission, and refill with 7176. This will cost about $160.00.
WHY? The friction characteristics of DEXRON are different from 7176. It is a "grabbier" fluid. The Chrysler transmission has an electronic system which continuously senses the behavior of the transmission and regulates shifts accordingly. If DEXRON is used, the clutches inside the transmission will "grab", and the electronic controls, which sample the operation of the transmission about 140-180 times a second, will let up on the clutches. The clutches will then slip excessively, the transmission will try to tighten up on them, and due to the characteristics of DEXRON, they will again grab. This will occur at the 140-180 times per second rate, and the transmission will have a shuddering feel to the shifting. This is also very hard on the clutches, and they will have a short life. The cost to overhaul one of these transmissions is about $1200-$1400 on a front-drive car, so you DO NOT want to shorten its life.
There is NO UNIVERSAL TRANSMISSION FLUID. DO NOT USE DEXRON!
Bookitty
For you bookitty, I appoint you the patriarch-at-large. For you have shown us compassion, honesty, and ferver seldom matched by any other mortal being earthly or otherwise. May your dakota be as faithful to you as you have been to us.
For ahahser and myself, we will be court jesters.
May our idles be good and smooth and never stall.
May our headlights always be aimed and always on during rain or snow. For the automatic crowd, may our 45RFE shift firmly but never harshly, may the TCM do its job as we diligently do our job with neither fear nor favor.
May your rotors stay straight and true never a chatter or complaint be heard.
Three cheers for bpeebles!
Hooray!
Hooray!
Hooray!
(ok, ok, I only got only a B+ in English in college)
Maybe that's why I stuck to Social Studies?
But the rhyme and iambic parameter is good ahahser therefore you go to the head of the class.
Wonder what bpeebles will think of all this?
Maybe midlife crisis is setting in and I don't know it. Or now that I can actually start my Dakota in the morning and drive away to work, I have more time on my hands.
We jesters eagerly await the forthcoming environment for this.
I requested made in usa parts, manager told me he'd do what he could.
At least he took time to drive with me and said Yup, I see what you mean.
Still I think its rotors but he swears up and down they mic'd the rotors and no warpage!
stay tuned....
ahasher, how's your idle? Mine is still OK.
Any is bpeebles still AWOL?
Anybody know his whereabouts? Not much fun here without him.
Drive Safe,
Joe
PS I have a V8 with 5-speed. Shifts fine!
CAUSE: FLASH MODULE
08194496 VEHICLE PERFORMANCE; COLD START
HESITATION - TSB 18-08-96
152 W40
1 4275086 LABEL - GENERAL INFORMATION
1 4669020 LABEL - AUTHORIZED SOFTWARE
FC: FM
PART # 4275086
and at the bottom:
26306 (CHK IDLE) FLASH MODULE 08194496 .5 TSB 18-01-01 FLASHED POWERTRAIN CONTROL MODULE.
I also had the synthetic fluid put in the rear end
since i will be towing soon.. $125.75. overall not bad to have it done for me and a record of the work for warranty purposes. ;-)
And mopar67.. the idle is still running as expected.. "perfect" starts and idle at stops. I love this QC.
Question is, why? I don't tow or haul stuff.
Well the answer lies on the outer rim of the drum in small unassuming letters. MEXICO.
Yes, its good old NAFTA making itself known thousands of miles away from a foundry in Saltillo. Bosch is/was the supplier to Dodge for the braking components on 2000 Dakota and they have several facilities in Mexico.
yeah yeah I know all about the so called high priced union labor and the lousy productivity, the EPA laws, workments comp laws, OSHA regs and all that. Oh yes, forgot to mention the time worn phrase "we gotta be competitive" But with who? YUGO? Funny thing is, my past mopars had domestic sourced brake rotors and drums and isn't it interesting that I never had to monkey around replacing them? Sure the odd pad and brake shoe but thats normal.
SO here I am, on my second set of drums (soon to be anyway) and somewhere in Auburn Hills, a VP is counting the zeros on his bonus check for "holding down development costs".
Meanwhile, the consumer gets the shaft and the Dakota gets a lousy rating on brake durability in my opinion.
My company will find that out. Yes, thanks to NAFTA I am out of work as of June 29th. I have seen the Mexican built product and it is junk. I wonder how many sales my company will lose?
When it comes to the brake parts. When it comes time to do mine, whether because of warpage or normal wear & tear I will be looking at aftermarket rotors and calipers. It willl cost more but I would much rather have brakes that I know will work. I drive too fast and hard to have wimpy brakes
I made reference to NAFTA due to the fact that a large degree of lousy quality on certain parts of our vehicles is due to lousy parts from lousy manufacturing entities all over the world. Some of us are simply trying to rationalize why we're having so many problems and you have to look at where this stuff comes from. I can say without reservation, my problems are due to made in mexico parts, the USA sourced stuff (except for the tranny) have performed admirably.
Not that it would matter, but it would be beneficial for Chrysler and the other Big Two to read this and other forums and find out what we customers really think. Isn't that what Toyota and Honda do, listen to customers? Perhaps thats why they sell their wares with small or no rebate at all?
In the meantime, best of luck to you and it tears me up to know there is another victim of a poorly negotiated trade agreement.
