Dodge Dakota: Problems & Solutions
Sawn
Shawn
Maybe this offset axle and leaning front end is designed for oval track racing . Just maybe.
Thanks in advance if you can provide any guidance.
Obviously I will be checking out the websites you suggested. Any thoughts on the minor "scratches" on the windshield I mentioned?
Saskquad - I must have inadvertently the Oval Track Racing Handling Group.
This is one reason why I did not get the 45RFE xmission. Not only does it cost nearly $1000 to purchase it... it will cost $$ if one changes the fluid, filters and gaskets as often as DC recommends.... and if one DOES NOT change the fluid that often..... it will surely die an early death.
Besides.... The manual xmission is FUN to drive and is LOW maintenance.
Shawn - I have a maintenance tip for you... buy a garage or carport!!! This truck, by far, has been the toughest to keep clean! Too much wiping and waxing for someone who is to lazy to drive a stick :]
Tips for washing your windows --> never used ammonia based window cleaner on tinted windows. Also, ink newspaper as a rag works the best with window cleaner, try it you'll like it!
I'm driving around with the tailgate off!! The PCM is alittle confused right now!, but I'm getting much better pickup with less drag. I'll let you know if gas mileage changes substantially.
I did not realize just how quirky the 45RFE would be. I figured that Chryslers stellar reputation in RWD autos would carry over in the new millenium. Not so it seems. Never have I driven an automatic that shifts so harshly and simply refuses to develop a proper shift pattern. Its overbuilt, needlessly complex (I read the BOB) and maintenance intensive.
Like bpeebles said, save a grand, and exercise your left foot. If there's one and only one thing I would change, I would wish for a five speed and tell Chrysler to take their automatic and stick it where..........you know the rest.
Next time I won't make this mistake.
Bill in NY
Still working on minor windshield "scratches". It was suggested that maybe they were wax streaks and I should try a more HD cleaner such as Simple Green. I did and they didn't come out. I guess they really are scratches and I'm stuck. #$%@!!
The thing is I'm so happy with the overall form and function of my QC it hard to get too bogged down in a few imperfections. Overall it came from the factory in good shape, it's mine and I sure enjoy driving it.
As we all know, the year 2000 is bright orange.... thus the name BOB.
The year 2001 has a dark blue-green cover for all Dodge shop manuals. I guess we cannot use the name BOB for anything except the 2000 manual.
I'll be picking up my brand new dakota club cab 4x4 tomorrow. It's got the 4.7L and it's the new graphite color, I love it.
Anyhow, just wondering if anyone has any good break in tips for her, she's got only a few miles so I want to do it right.
Paul
According to the site, the pennzoil filter is a Fram filter painted yellow instead of orange.
Even with sythentic, I sill go 3500-4000K oil changes. I use Mobil1 5W30. And yes, the filter gets changed also.
Greeno>>>>>I don't have a clunk but a click during slow parking lot maneuvers with light brake application. Sounds like brake pad shifting in caliper. No vibrations though.
As for HOW LONG to go between oil changes...
The 3000-mile oil change is a myth. It is promoted by people who get GET PAID to change your oil.
Read your owners manual on recommended oil-change intervals. These recommendations MUST be followed to maintain your warrantee inforce. After that... you can decide for yourself what is best for your driving habits and weather conditions. I can tell you personally that the 7500 interval has worked out fine for over 100,000 miles in EVERY VEHICLE I HAVE OWNED. Certainly anything less that 4000 is wasting your $$ and time.Keep in mind that I am not just a casual observer... I have been INSIDE engines for about 30 years and KNOW what I am talking about.
Paul.
No 1: What could have caused it?
No 2: Has this happened to anyone?
No 3: I know I'm covered under warantee, but what about the rest of the electrical system. Could damage have occurred?
I'm calling the dealer first thing Monday morning. I'd very much appreciate this board's input. Thanks in advance.
While I have a long way before passing appearance care 101, I think I pased my first test. You can see it in the results.
Thanks for the help.
The cause may be an internal short in the battery or a loose cable causing arcing or sparks.
This is fairly uncommon and usually only happens when boosting improperly.
Under normal conditions, a lead-acid battery produces HYDROGEN GAS while it is charging. (This is HIGHLY EXPLOSIVE...Think HINDENBURG) Normally, the gas is released in very small amounts, it is controlled by the special vented caps on the battery and quickly dissapates beacuse it is lighter than air so it 'leaks up' around the edges of the hood. INSIDE THE BATTERY IS COMPLETY FULL OF HYDROGEN GAS ABOVE THE ACID AT ALL TIMES!
If the conditions are exactly right... any stray spark such as from a relay picking or the starter motor might ignite the hydrogen gas within the battery and BOOM... there is your answer.
Your concern now is echoed in the wordy of saskquad. The sulpheric acid splashed under the hood may cause all kinds of problems for years. Copious amounts of hosing off followed by baking soda might help.
My question to the tech was: Will corporate be advised of this failure? He said YES, but this was a very rare circumstance. I told him that I was going to pass the word anyway.
Ron35
bpeebles? Ahasher?
Thats a good question you have. I can only guess as to why.
ron35, when i switch between outside and inside there is a big difference in air and noise. but its funny when its on outside air and the a/c turned off i get no air at all, every vehicle i have ever owned had air coming through when the vehicle was moving hence the name VENT.
robert
I also feel it has poor performance...always in the 2nd fan position at least, recirculating inside air does indeed make a much louder noise...still trying to see of this makes it colder in the cab.
I've seen pictures of insulated A/C lines, perhaps this would help?
One thing I do religiously is keep the condensor clean as can be, it only takes a little dirt, bugs leaves etc to interfere with heat transfer and thus reduce Ac performance.
I've driven other 90's vehicles and I seem to notice airflow on the lowest postion on fan setting seems barely adequate.....anyone have a reason for this?
When you're talking about positions, is position 1 the farthest to the left (counter clockwise) which I take as blower OFF? Or is position 1 the first ON position (2nd actual position)? Just to be clear.
mopar67 - Ordered the FSM today. $99 plus tax or shipping or whatever. Asked and was told there is a 2001 version, not just a 2000 with an 01 supplement. So hopefully I'll get the right one.
So I'd say that's 1-4 ON and whatever (0) for the OFF position. Anyway, the point is I now know exactly what you mean that it has to be in 2 or higher to do anything. Position 1; the air drifts in barely noticable. Position 2 is the first setting where the air is moving with some purpose.
Another major variable is which vents are opened or closed. The main force of air in my 01 is coming through the vents between the steering wheel and the center of the dash (radio & climate controls). With both these vents open, there is little or no air flow through vents on the ends of the dash at all but the highest blower speeds. With these vents (between steering wheel and controls) partially or totally closed, the air flow out of all other vents is improved.
Even with the vents between the steering wheel and controls closed, air still "pours" out of them at the higher speeds.
Bottom line: It seemed liked with a little experimenting I could get air flowing where I wanted; front seats, sides, & up through the middle to the back. I know some may say well you shouldn't have to fuss around with the vents so much and you're probably right. This is just feedback to help find ways to get it to work for you.
BTW, my 1990 station wagon has an "OFF" and "VENT" position on the mode control. If switched to vent, and the blower is in the lowest setting, I believe outside air comes in relative to vehicle speed.
My 2000 blows all kinds of cold air when I want it to. I use all of the various fan-speed settings given differing conditions. Bear in mind that my HEATER is used for over 4 months of the year... the low fan speed is great to maintain an undetectable flow of fresh air.
I also have a 2000 Dak 4x4 4.7 auto and I definitely have the clunking problem. Anytime I go over a bump at anything other than a crawl there is a clunk/squeak from the front end. There's also a lot of rattling that goes on in the front end, it's pretty annoying. If there is a tech bulletin, I'd like to know the details.
As for you question about "adjustments" on the rear leaf springs. The simple answer is NO
There are no adjustments. Everything is solid steel that is bolted into place. There is no means of "adjusting" anything in the rear.
With that said, Leaf springs can be removed and "re arched" using a huge machine that bends the springs. Spring shops have these machines. This process is labor-intensive and often the spring-steel used for the springs has "memory" and quickly un-arches back to the original shape.
This is not something you want to consider!
Other folks install "shims" between the axle and the leaf springs to change the ride height... I have never heard of this being used to "adjust" one side.
I will ask again... Has anyone actually looked in the service manual and actually MEASURED using the factory procedure? There are very specific procedures as to where to measure and what to expect within factory tolerances. It is either IN or OUT of tolerance!
This would quickly isolate the source of the ride-height concern without GUESSING?!!? about it.
On straight axle trucks back in the old days (before my time) one could adjust the caster by inserting shims either on the front side or the back side of the spring pad to change the caster angle from pos to neg or vice versa.
I know this is a cold hard fact of reality since it was done on my Fathers International.
Shawn
My dad has always done exaclty what you are doing. I did the same thing and it was a good call because I do a lot of in town driving.
I have a 2001 Dakota QC 4x4. I live in So.Cal and my truck is driven 1-4 times a week
(around 25-50 miles each time).
Whenever I switch from AC to normal Air, and particularly after
using the AC, I get a nasty rotten stink from the blower vents.
(it is there for a moment when AC is first turned on, and after
blower has ran for a while without AC on, the smell is gone)
Any idea what would be causing this ?
Can I fix this problem myself ?
If I have to take it in to the dealer, any idea what they would do
to fix the problem ?
Thank You All !
Ole
