2021 VOLKSWAGEN ATLAS V6 SE WITH TECHNOLOGY WITH 4MOTION
saabotr1saabotr1 Member Posts: 39
edited January 2021 in Volkswagen
Hi there. Back once again. Hopefully for the last time since our current lease is finally up. Can you please give the current money factor, residual and any rebates / incentives on the above referenced vehicle? The zip code is 17331.
Also, can you tell me how long this MF and residual is good for? Does it end February 1st? Later? Earlier? Any info on that is appreciated. Thanks a lot!
  • MichaellMichaell Moderator Posts: 270,949
    Programs end 2/1
  • saabotr1saabotr1 Member Posts: 39
    Oh good grief, I knew I was forgetting something. LOL! 39/15. Thanks again.
  • kyfdxkyfdx Moderator Posts: 276,058
    .00101 MF and 52% residual
    $2250 dealer lease cash
    Thank you very much!
    ... And is the MF and residual you mentioned above the same for these vehicles:
    2021 VOLKSWAGEN ATLAS V6 SEL 4motion
    2021 SE V6 w/technology R-Line 4motion
    2021 VOLKSWAGEN ATLAS V6 SEL R-LINE WITH 4MOTION
    Same terms on the lease and same zip....39/15, 17331
    Yes, the same
    Hi. Regarding the 2021 SE V6 w/technology R-Line 4motion. Slowly narrowing the search down and may end up driving a distance to get this car after local dealer is having a hard time with a dealer to dealer transfer.
    For 39//15 .... am I still looking at a .00101 and 52% residual for zip code 18103? Allentown, PA. Thanks again. It's been a saga with many twists and turn from local dealer. About ready to move on from them.
    Yes
    Thanks again! I'll have to post the results once this battle is over.
    Hi. Can you please give me the new money factor, residual and any incentives / rebates for the February program? 39 // 15 lease. 2021 Volkswagen Atlas 3.6L V6 SE with Technology R-Line 4Motion. Zip code of the dealer is 17331. Still trying to work out this deal as dealer swap is delaying things. Thank you for your continued support.
    New programs start on Tuesday
    Ah, OK. Thought it was today. Will follow up tomorrow. Thanks again.
    Good morning.....following back around for the new MF, residual, etc. Please see my original message below. Thanks again!
    Ah, nice! So it did not change from the January parameters, correct?
    You have all the numbers
    Thank you! Happy the numbers didn't change for February and I appreciate the service you provide!
