Dodge Dakota Accessories and Modifications
Dave.
The bedrail and tailgate protectors from Bakliner are much like what a Ford has except the texture is not smooth. When I ordered, first they mixed up and did not ship. after waiting a week, I called again and "oops" well they first offered to pay shipping (via e-mail from them) then when I asked on the phone I got the run around. They finally shipped and payed the shipping but I received rails for a standard bed. Rather than ship back I just cut to fit myself. Very frustrating but the end result is some very cool rail protectors.
www.Bakliner.com Just try to get them from somewhere else.
As far as the LS11 is concerned, it is fairly easy to remove - but heavy. I have a club cab and the removal process consists of undoing 4 clamps and lifting it off. Definitely a 2 person job to carry it. Yours would obviously be smaller and lighter, but I would still reckon on two people to safely lift it off without risk of damage - but certainly not a difficult process.
Bookitty
BTW, has anyone found a good tailgate lock? I don't want my soon-to-arrive extender to get stolen...
Pretty sure mine only has 4 - I'll check.
Dave.
Bookitty
PS If you run colour and honour through the posting spellcheck, they will show as "misspelled"
words; So there!
My 4.7L V8 Hemi did not start to idle smoothly until after 10K miles. The MPG also improved steadily up to around that point. In my mind, this is what I think of as "break in"... when the engine ceases to change its operating characteristics.
Keep in mind that this engine has VERY tight tolerances. It will take some time for the moving metal parts to become "accustomed" to each other.
I would also like to remove the airbag warning labels from my visors. I pulled off the stickers only to find another label underneath. These labels looked like they were "ironed on" and part of one of them was removed when I pulled the first sticker off. Has anyone removed these labels? I am thinking of heating them up with an iron and pulling them off with duct tape.
Before the exhaust install, mileage averaged 13.4 (city/hwy) over three fill-ups. Filled it up immediately after the install... No change in mileage over 190 miles.
Drove another 240 miles, filled up, and averaged 14.5 under roughly the same driving conditions... Nothing conclusive yet, but if the improvement is consistent, I'm looking for pay-back on the exhaust at about 45K miles at today's fuel prices.
It appears that what the exhaust manufacturer indicated regarding the computer requiring 600-800 miles to "adjust itself" to the improved flow may be true.
"Goo-Gone" or "Goof-Off" will both do the trick... I believe that the Goo-Gone is heavily citrus-based, so it should cause no damage to the fabric.
JimH
Bookitty
http://www.aerotanks.com/dodge.htm
They're in SoCal and won't ship the tanks, but if you're close it sounds like a really nice setup.
I'll check into it...
Any ideas?
http://shop.store.yahoo.com/wyckoff-chrysler-parts/6discdchanan.html
Ron,
Springfield, VA
1st is the Tonneau covers, we are leaning towards the fold a cover style over the fiberglass one piece. Which do you all have and are you happy with the style you chose? Which brand did you get and where? I've visited the thread on this subject already. Looking for current advice.
Second is my hubby wants to put a dual exhaust system on the quad cab (we have a 2001 4X4 4.7). Any advice or suggestions?
Thanks everyone.
the Dak has triple catalysts which are an intrinsic part of the engine-management system. Federal law prohibits such modifications.
I you are asking about a "fake" dual exhaust that simply has two outlets,(aka...Cat back) there are some available.
However
It has been discovered that the 4.7L V8 hemi can loose low end torque if "too much" exhaust is allowed out. This engine does not have the "cubes" to drive the negative ram effect that such an exhaust system is tuned for.
If you are looking for improved PERFORMANCE, It has been found that a quality SINGLE exhaust of the proper diameter to improve the scavenging of the engine is a better choice.
Here are some links to get you started...
INTAKE:
http://www.intenseperformance.com/
http://www.quickd.com/
EXHAUST:
http://www.jardineproducts.com/automotive/index.htm
http://www.edelbrock.com/home.html
http://www.gibsonperformance.com/
http://www.spintechmufflers.com/spintech/index.asp
There was a test of the 4.7L with a K&N intake/exhaust in a recent "Truckin" magazine.
There are a number of people over in the DML (Dakota Mailing List) who live-n-breathe performance. Its tedious reading but your answers are in there!
for towcrazy2... I think that you and I might be the only 5.9 guys around! i also have full time 4wd. thanks for your exhaust / mileage updates... i'm thinking of doing something similar. so far i've just installed smittybuilt ss nerf bars. plz keep the updates coming!
Ordered Westin Step bars from Atlanta Auto, & they tell me that they shipped them the same day!
(mon)
I hope to get them put on as soon as they arrive, but I can't remember how many beer's a job like this is rated at...
Seriously, how easy are they to install?
(I'm a computer geek, not a mechanic)
Next upgrade on the list is a roll top cover.
I would rate this a no-beer job, only because they can be installed so quickly, you won't have time to enjoy a beer.,....until you're done. :-)
Seriously, it took me maybe 1/2 hour and that included getting tools out and putting them away. If you have air tools, an impact speeds removal of the body mount bolts. With a normal ratchet wrench, install could take 45 minutes due to some "Lock-Tite" type goo that was applied to the bolts during factory assembly.
The bars are attached to the cab's front and rear body mount bolts with some nifty supplied HD brackets. This provides a very sturdy step bar that sure helps when washing the roof!
I left the protective wrap on my bars until installed, just to protect the surface. I only peeled it back when the end of the bar bolts to the brackets.
Let us know how it goes...
fat_fenders
PS. One of my bars was damaged upon arrival and Atlanta Auto arranged replacement through Westin with no questions asked. The provide excellent email communication, should a problem occur. I don't have any personal interest in AA other than being a satisfied customer.
No time to install them today
I have no access to air tools, and I only own a few regular tools that are larger than what I need to work on computers..
I guess I'm gonna have to go up & open the box to make sure that they are not damaged in any way.
These ought to look real sharp once I get them on.
Black Bars on a bright White QC!
As soon as I get my Digital camera back from a friend (borrowed it for a wedding) I'll get some pictures taken, & post 'em on one of my web pages.
Thanks again for all the advice
Stnick
My bad...
The only reason I passed on the Pace Edwards or the Roll-n-Lock was because of the space the box takes up next to the cab.
The Mopar cover was too expensive. As I think Towcrazy can tell you, it's exactly the same as the Fold-a-Cover (Fold-a-Cover apparently makes the cover for Mopar), but the Fold-a-Cover is considerably cheaper. I was lazy and went with the Mopar version since it was easier to arrange to have it installed.
Someone posted a while back about another folding cover. It was two pieces and the material on the web site said it removed without tools. If I hadn't already bought mine, I would have seriously considered this one. Just do a search for "cover" or something like that in his topic.
Overall, however, I really like the Mopar cover.
this offer. They need a Dakota to use as a
prototype. If I was in California, I would
DEFINITLY take advantage of this offer.
Check it out;
http://www.gibsonperformance.com/free.html
http://www.advancecover.com/2fold.htm
http://www.autobulbdepot.com/
For aftermarket fog lights, just do a search on www.dogpile.com You are bound to find several.
NOTE:If you DO NOT have foglights on your Dak. It is highly recommended that you spring for the factory 'kit' that includes wiring and dash switch. Anything else may look kludgey.
I'm assuming you know that you don't want to have boards from flare to flare unless the bed (short) portion on each side is SEPARATE from the cab (long) part. Never have the cab and bed pieces 'connected.' Bed needs to 'float' separately from the cab and all that, what.
Oh, and the prices above are delivered, and if you tell them Jack (me) sent you, they might even double the price for you!
