Mazda MSD Program
It looks like now that Mazda is using Toyota instead of Chase they have an MSD program for leases.
https://www.mazdafinancialservices.com/us/en/explore-financing/lease-a-mazda.html
Does anyone have the details on the program?
With Toyota, you had to use the standard MF as the starting point if you wanted to utilize MSDs. Not sure if that will be the same under Mazda.
Toyota allows a maximum of 9 security deposits, each of which lower the MF by .00008 (.00072 total reduction)
With Toyota is it theoretically possible to get the MF all the way down to .00001 or are you left with whatever the remainder is? For example if the base MF is .00023, can you do 3 security deposits to get the MF to .00001, or would the best you can do be 2 security deposits to get to .00007
Most dealers probably aren't aware of the existence of the MSD program.
