2021 GMC Sierra Lease Deals and Prices
1679111217
  • kyfdxkyfdx Moderator Posts: 276,346
    wrightp3 said:
    Can I please have the lease incentives, MF and residual for a 2021 GMC SIERRA 1500 AT4 crew cab 4WD in zip 13088 for 36 months 10k miles
    .00015 MF and 60% residual
  • rayachito1986rayachito1986 Member Posts: 18
    Are march numbers for 2021 2500 Denali same as last month for 95901?
    36/12k per year
    Any incentives?
    Is there a discount on MF if one pay?
  • MichaellMichaell Moderator Posts: 271,172
    36/12k per year
    Any incentives?
    .00121 and 66%
    No incentives
    Subtract .00073 for one-pay
  • abm54671abm54671 Member Posts: 32
    May I please have the MF and RV for 2021 Elevation Crew Cab 4x2 w/ 2.7L Turbo 12/36. 28405
    Thank you in advance!
    .00010 and 60%
    No incentives
  • sc456scsc456sc Member Posts: 112
    Hi, could I get residual & MF for 2021 Crew Cab Sierra 1500 SLT & AT4? 36/15 Zip 60126. Thanks!
    .00015 MF and 57% residual
    Either trim
  • drg6654drg6654 Member Posts: 73
    Hi, could I get residual & MF for 2021 Crew Cab Sierra 1500 Elevation & AT4? 36/12 Zip 32792. Thanks
    ELE - .00010 and 60%
    AT4 - .00015 and 59%
    No incentives
  • kcorekcore Member Posts: 3
    Hi, could I please have the residual & MF for 2021 Crew Cab Sierra 1500 Denali? For the V8 and I6 diesel as well as 2wd and 4wd for each. 36/12 Zip 34786. Lastly, any lease incentives? Sorry for the loaded request. Thanks!
    edited March 2021
    .00066 and 63%
    Any engine
    Either drivetrain
    No incentives
  • Crag75Crag75 Member Posts: 5
    Would you kindly provide residual & MF for 2021 Crew Cab Sierra 1500 SLT & AT4? 36/12
    Zip 92656
    Zip 92656
    .00015 MF and 59% residual
    Either trim
    (Assuming both are 4X4)
  • The_SheepdogThe_Sheepdog Member Posts: 98
    Could someone share the Money Factor (MF), Residual Value (RV) & any incentives that would be involved with the following car(s):
    - 2021 GMC Sierra 1500 AT4 4WD
    Lease Terms:
    36 Month's / 15K Miles
    36 Month's / 12K Miles
    Zip Code: 48335
  • envoy982envoy982 Member Posts: 18
    edited March 2021
    Could I get MF/Residual/Incentives on a Sierra AT4 vs a Denali? 1500, 4x4, crew cab short box.
    3/36 and 3/30
    Zip: 55330
    Thank you so much!
    Lease Terms:
    Zip Code: 48335
    $1000 customer incentive
    3/36 and 3/30
    Zip: 55330
    Thank you so much!
    AT4: .00015 MF and 59% residual
    DEN: .00066 MF and 63% residual
  • lucky932lucky932 Member Posts: 119
    Hi, Could I have the numbers for the 1500 RWD Denali and SLT Crew cab
    24/15K
    36/15k
    in 77584
    Thanks in advance.
    24/15K
    36/15k
    in 77584
    Thanks in advance.
    SLT
    .00014 and 67%
    .00006 and 58%
    Denali
    .00018 and 67%
    .00066 and 61%
  • MSGC0053MSGC0053 Member Posts: 13
    edited March 2021
    2021 Sierra Elevation RWD Crew Cab 2.7
    MF & RV
    24/15
    Zip:39534
    MF & RV
    24/15
    Zip:39534
    .00014 and 67%
    .00006 and 58%
  • Gbrl25Gbrl25 Member Posts: 18
    Looking for info on MF/RS/Incentives for Zip code 75056.
    2021 Sierra SLT RWD Crew Cab 3.0 Diesel
  • LRC253LRC253 Member Posts: 7
    ZIP 98374 - May I get MF residual and incentives for:
    2021 Seirra Denali 3500 HD Diesel 36/12 % 48/12
    .00131 MF and 70% residual
    .00137 MF and 64% residual
    .00006 and 60% / 58%
    No incentives
    Either trim
  • GreycadeGreycade Member Posts: 28
    Does anyone know residual for 2500 HD Denali 36/10 and 24/10? Is there difference gas vs diesel on residuals?
    03060
  • jt425wajt425wa Member Posts: 9
    Hi
    Could I get the MF and Residual on a 2021 Sierra 1500 AT4 Crew Cab with 3.0 diesel
    Zip code 98270
    I got quoted .0015 at the dealership and walked because that seemed high
    03060
    .00223 and 76%
    .00131 and 71%
    Engine choice doesn't matter
    jt425wa said:
    Hi
    Zip code 98270
    .00015 and 57% / 55%
    You sure it was .00150 you were quoted?
    jt425wa said:
    Hi
    Zip code 98270
    Yep I was shocked as I had known it was .00015 and was shocked when I calculated 3% or something and they guy thought I was nuts telling him that he bumped the MF on me.
    Thank you for all you guys do and helping people not get ripped off
  • chessmatechessmate Member Posts: 1
    What should I be seeing for a 2021 crew cab Sierra 1500 SLT/Denali (5.3), 48/12 in 11793? Does 48/10 make a huge difference? You guys are amazing, thanks!
    48/12
    SLT - .00088 and 54%
    Denali - .00109 and 57%
    Add 1% for 10K
  • schmatschmatschmatschmat Member Posts: 44
    edited March 2021
    Can I get residual /MF and incentives for a Sierra 1500 Double Cab, standard box 4WD, and also a Sierra 2500 double cab, standard box, 4WD, in 49267 please. 10k a year and whatever best term is - 24/27/36/39...
    What trim level?
    What trim level?
    Standard Trim (guessing its SLE, but doesn't list a Trim)
    What trim level?
    I do see a "base" trim, as well, in my information.
    Base - .00058 and 61%
    SLE - .00035 and 61%
    $1000 incentives
    I do not have any 2500 double cab lease numbers.
  • LeaseCuriousLeaseCurious Member Posts: 16
    Team. Looking for MF/Residual and incentives on a 2021 GMC Sierra 1500 Crew Cab Short Box 4WD Texas Edition SLT Package 36/10K in or around 78664
  • ohiotruckguyohiotruckguy Member Posts: 3
    edited March 2021
    Could I please get MF/Residual and incentives on a 2021 GMC Sierra 1500 Crew Cab Short Box 3.0L 4WD Denali Ultimate Package 36/10K and 48/12k in or around 45013
    .00066 MF and 64% residual
    .00109 MF and 57% residual
  • Hoosier1695Hoosier1695 Member Posts: 2
    Hello. Could I please get the Money Factor and Residual for a 1500 SLT, AT4 and Denali, both 4wd Crew Cab, on a 36/10 lease? Zip code 46060. Thank you again.
    SLT/AT4: .00015 MF and 60% residual
    Denali: .00066 MF and 64% residual
  • KHsoccer31KHsoccer31 Member Posts: 12
    Can I please get MF/Residual on a 2021 1500 SLT, Diesel, 4WD Crew Cab on 36/15 and 39/15. Zip is 44236. Thank you
  • The_Buffalo6The_Buffalo6 Member Posts: 13
    Hi, looking for mf, rv, and incentives for a 1500 elevation crew cab, 4wd, 36/12, 08096 zip. Thank you
    .00015 MF
    57%/55% residual
    .00010 MF and 60% residual
    Could I please get MF/Residual and incentives on a 2021 GMC Sierra 1500 Crew Cab Short Box 3.0L 4WD Denali Ultimate Package 36/15K in or around 45013
    .00066 and 61%
  • LZLFischLZLFisch Member Posts: 8
    edited March 2021
    Can I please have the MF/RV and incentive on a 2021 SLT and Denali 4WD Crew Cab. 36/12. 46062
    SLT: .00015 MF and 59% residual
