Visitor Agreement.
My son is home on leave from the U.S. Army (1st Armored Div.) and as a gift I rented him a 2005 Dakota Quad Cab (4.7, auto, 4x4) from Enterprise. I was able to get some seat time in this truck and my overall impression is very, very good. The first thing I noticed was the exceptionally quiet cabin. This is by far the quietest truck I've been in to date, including the Tundra and the much overhyped F150. Compared to my '03 Dak with the 4.7, there is hardy any engine and drivetrain noise. There was a complete absence of wind noise and only a slight hum from the tires. The new 4.7 Magnum engine receives a carbon fiber composition valve cover that virtually eliminates noise from the valve train.
The 4.7 seemed a little slower off the line compared to my 4x2 Club Cab, but this truck also outweighed mine by about 900 pounds. My son says he's getting about 17 MPG in around town driving, which surprises me.
The seats are softer than my '03 and quite comfortable. The driving position seems a tad lower than the previous generation. Handling was excellent and with a noticeably lighter steering effort than my '03. The brakes seemed lighter and more positive.
Although I liked the white-faced instrumentation, it still disturbs me that Dodge left out the oil pressure and voltmeter gauges. The interior is nicely done, but seemed a little too Germanic and understated despite the wood-toned center escutheon surrounding the radio and climate controls. I did not like the more slender center console, but I can see that this is what allowed for the nicer (ie: wider) seats.
I was very impressed that this truck was still perfectly screwed together at 21,000 miles, with absolutely zero interior assembly defects, squeaks, buzzes or rattles. The platform seems extremely stiff and the cabin gives the feeling of being encassed in a solid block of steel.
It is difficult for me to compare the ride of this Quad Cab to the previous generation since I have only ever driven one of the earlier design. However, the ride of this 2005 Quad 4x4 was judged to be identical to my 2003 Club Cab at 53K. I think that means the ride might have been improved in the Quad, but I'll let other owners of the last generation to weigh in on this.
I have always found the new generation of the Dakota to be contemporally handsome and good looking except for the front end. I'm finding that the frontal appearance isn't offending my eyes quite as much as it first did, and since I was able to spend some time behind the wheel looking outward I can say that there is so much to like about the new Dak that I could forgive the jutty appearance of the front end. In truth, the only new truck design that I find has a more appealing front end design is the new F150. the Tundra, Titan, and Silverado are even uglier to my aging eye.
Bests,
Dusty
Bests,
Dusty
This includes the PCM, cat-converters, O2 sensors... and anthing else they do not specifically mention in the owners manual that needs to be periodically replaced. (ie..PCV valve)
The CEL itself is also a Federally-mandated indicator for the consumer to tell that all the emmissions equipment is working.
As for the P0155 code you can look it up yourslef at ( http://www.obdii.com/codes.html )
P0155= O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
BANK1=LEFT
BAN2=RIGHT
SENSOR1=upstream
SENSOR2=downstream
Since they are telling you that they cannot tell from the code which O2 sensor is the issue -- they are BONEHEADS!! (or outright lying to you)
HOWEVER: The 2000 Dak was available with BOTH the 2-sensor and the 4-sensor system. (I know this for CERTAIN because I orderd my 2000 Dak from factory and had the option) You need to determine if your Dak has the "pre-cats" or just a single cat.
2-sensor system= just one single cat.
4-sensor system= pre-cats + single cat
thegrad
was right! Well after 3 balances and now I'm told two of the
tires are so out of round they won't ballance!!!!
At least the tire place is replacing the two tires!!!
I've never had this problem before!! Anyone else ever purchase
tires that were out of round?
Dusty
My question is about my tranny. It seems to need to downshift a lot, and takes its time upshifting. On the highway, rolling at about 65, I start up a grade, not serious, but certainly enough to lose speed, and it slows down to about 58 (without any movement on the accelerator) before it will jump down, and then it really revs up. Sometimes I have to put my foot into it a bit, for it to kick down. Normal behavior for a DD 6 cyl?
Would appreciate any suggestions for new replacement tires.
The truck is equipped with Goodyear Wrangler RTS P265/70/16.
These tires have been somewhat troublesome for me. Too many flats.
I would like to go with an "LT" rated tire. LT265/70/16.
I am hoping that this type tire will be a little more durable.
Any suggestions will be appreciated.
Bob
... and also, NOKIAN!
I have the VATIIVA on my Dakota... they are quiet on the road and have awesome snow traction. (Nokian tires are made in Finland where snow is a way of life.)
I also have NOKIAN tires on my 56MPG volkswagen and have used them on past vehicles. Personally, I would not even CONSIDER any other tire.
Did anyone ever tell you that you DO NOT NEED "LT" tires unless you plan on carring heavy loads for long distances? The "LT" tires add more sidewall stifness.... thus ride like a rock.
Thank you for the suggestion.
I'll check them out.
I would be willing to give up a little ride comfort for a more durable tire.
During the first year of ownership of the truck, I had to replace 3 tires because of unrepairable flats near the sidewall area.
Have replaced rotors twice, need to do it again, autostore said to try turning the rotors first while they are on the truck before trying to replace again. Never heard of this. Is this worth trying?
I also have gone thru some Rotors before settling on somthing that works. (Check out what 3 Vermont winters did to my powerslot rotors.)
I have been running Bendix rotors with NAPA "Ceramix" pads. They seem to lasting longer than anything else I have tried AND have much better braking power than stock components. The BONUS is that ceramic-based pads do not leave all that black crud on the front wheels.
To more specifically answer your question, the factory shop manual says that all rorors MUST be turned while mounted on the vehicle. Using this process tends to make for a truer result than turning on a brake lathe.
You did not mention WHY you need to replace the rotors... if they have been warping... you are either using CHEEP mexican rotors, have not been using torque wrench on lugnuts or did not season the rotors when new.
The rotors have warped. So, if I get new rotors, do these need to be turned while on the truck? I have been through three sets, none cheap mexician rotors. Any suggestions on seasoning the rotors properly? Thanks, Andrew
BTW: Are you CERTAIN that your rotors are really warped? Are you feeling it thru the brake-pedal, steering wheel or just a general pulsing feeling? My rotors often get "cruddy" and need to be cleaned up. (about 4 times a year.)
Try this: Do some VERY heavy braking until some smoke is released.... then DRIVE WITHOUT STOPPING for at least 30 minits to cool things down. You may find that your supposedly "warped" rotors are all fixed. (Because they were NOT warped...just cruddy)
Do new rotors new to be turned while on the truck?
Then, there are several tests that are run to ensure that the system can hold that pressure under various conditions.
If those tests fail then the MIL comes on to show the driver that there is a code available. The specific code can be directly referenced to the test that failed. (The federal government mandantes what tests must be done and what codes they will flag if there is a failure.... aka ODBII)
The factory shop manual has very good descriptions about the specifics of each test and what constitutes a "fail". Many of the tests are only run after a "drive"
A "drive" is carefully defined by the Feds....
basicly the engine must be cold when it is started.
reach full-operating temparture.
then be running for a specific amount of time.
Many of the codes will reset themselves if 3 consecutive "drives" do not flag a failure.
I have an '04 Quad Cab. Last week the blower motor only had high speed. Today it stopped completely. It's cold in Cleveland! Any thoughts? WOuld it be a fuse or resistor or does the motor need to be replaced?
Thanks in andvance,
Tindmac
I just bought a 2003 Quad Cab V6 3.9L. It has 88000 kms on it (54 680 miles). High for an 03, but in good shape.
I have 1 week before I have to pick it up. The question is this. Should I anti-up for the extended warranty? This is the Chrysler Gold warranty that covers the powertrain and the non-powertrain components.
So basically, what are the things that are likely to go on this truck?
Any help appreciated.
Wa
After 65K miles, I've only spent about $610 (US) on non-scheduled maintenance. That was for a heater core ($550), a pinion seal ($50), and a blower resistor ($10). Since the extended warranties I was looking at when new were in the $1000-$1500 range, I'm still well ahead. With the miles you have on your truck, I'm sure the warranty is a bit more.
As far as common problem areas go, front brakes are one. But, I think they came out with an improved brake design in 2003, so you may not have any problems. Another area is balljoints. There was a recall on them. I'm not sure if your 2003 was under that or not. Another common problem is the blower resistor tends to fail. But it's an easy $10 fix.
MODERATOR /ADMINISTRATOR
Review your vehicle
BTW: There is no "linkage" on a hydrolic clutch...its all liquid. (just like your brakes)
I changed the fluid in my manual xmission (and xfercase and differentials) over to RedLine. Not only was shifting noticibally improved, I also gained 2-4 MPG.
0301 is code for misfire detectected on cyl # 1
Could be something as easy as a bad wiring connector or could be the injector itself
The 2003s got a different and improved set of brakes and I think perform and last longer than the previous years. As Sunburn mentioned, ball joints were an issue on early '03s. The uppers were covered under warranty and still are. The lowers are not. My suggestion is to grease them periodically regardless.
The heater blower motor resistors are famous for failing. Mopar's gone through three interations of the resistor design. The jury's still out, but as indicated the part is fairly inexpensive and easy to install.
Intermediate steerings shafts have a tendency to get rusty and cause a snapping or clunk in the steering. This was also warranted by Dodge in 4x4s. Not sure about 4x2s.
Let's see, some complaints of premature air conditioning failures due to leaky evaporators, and I'd noted a couple of heater core failures as well. The failure rate seems quite low on these items, though.
Oh, yes. The fuel cap. Older Daks experienced failures which trip the MIL indicator and give a diagnostic trouble code of P0456. 2002s and down also experience the rubber fuel vapor return lines cracking causing a similar code.
Can't think of anything else at the moment.
Best regards,
Dusty
Does anyone know how long sway bar bushing should last and is their anyway to prolong their lifespan. I've read on the board that you can lubricate the bushing but I'm not sure what you use (grease/oil?) and how to apply. I assume you have to get inside the bushing to apply the grease which sound complicated.
Any input would be appreciate cause I'm getting tired of the groaning noise but don't want to pay $123 to replace two front front sway bar bushings again.
Thanks - Brake4me
As you may have noticed, we are reorganizing the Forums to allow better focus and easier searching when you have a particular problem or comment about any given vehicle. Many of the large generic discussions (like this one) will be closed to new posts, and we ask that you continue in the more focused discussions that you can find at the Group page for the vehicle, linked below. This discussion will not be deleted, so you can still search for information in it.
We recognize this is going to take some getting used to (for the hosts too!), so please bear with us. If you have any questions, you can always email the host of any discussion - the link is at the top of each page to the host who oversees that discussion.
If you don't see a discussion in the group appropriate to your question or comment, start a new one, or send me an email, and I'll point you in the right direction!
kcram - Pickups Host
Dodge Dakota Group
