2021 Honda CR-V Lease Deals and Prices
1568101113
  • drnkaslndrnkasln Member Posts: 11
    Can I please get the MF, residual, and incentives for both the 2021 Honda CR-V Hybrid EX-L & Touring? Zipcode 06611 - 36/12 please
  • kyfdxkyfdx Moderator Posts: 272,631
    .00120 MF and 64% residual
    Either trim
  • RamLevoitRamLevoit Member Posts: 47
    Can I get the MF, residual and incentives for the following 2021 CRV in 07801 for 36/12 and 36/15:
    - EX
    - EX-L
  • MichaellMichaell Moderator Posts: 268,949
    - EX
    - EX-L
    .00120 and 61%
    No incentives
    Either trim
  • AnasSaadAnasSaad Member Posts: 1
    Could you please give me the MF, RV and incentives for Honda CR-V EX zip code 48080
    .00120 MF and 61% residual
    No incentives
  • IsThisMicLiveIsThisMicLive Member Posts: 8
    edited May 2021
    Could please provide the MF and RV for 98178? If possible, could you provide both 36 and 24 month values?
    - CR-V EX AWD (gas, hybrid)
    - CR-V EX-L AWD (gas, hybrid)
    How many miles per year?
  • JaviercitoJaviercito Member Posts: 19
    May I get the MF, RV, and incentives for the following trims of a 2021 HONDA CRV: LX, Special Edition, EX, EXL, and Touring models in zip code 10705?
    Thank you very much for your help.
    edited May 2021
    15K miles. (but I wouldn't complain if you added the factor for 12K and 10K -- otherwise, I'd assume 2% and 3% based on other responses)
    15K, with the adjustments noted for lower mileages
    .00120 MF
    Hyb
    EX - 70% / 63%
    EX-L - 69% / 62%
    Gas
    68% / 61% for either trim
    No incentives
    edited May 2021
    12k per year, 36 months
    .00120 MF
    62%, not found, 63%, 63%, 63%
    No incentives
    Thank you very much, your help is appreciated
  • norespnsenorespnse Member Posts: 7
    May I get money factor, residual value, and incentives for a 2021 CR-V CVT 2WD EX for 60056? Thank you!
    edited May 2021
    .00120 MF
    Gas: 68% / 61% for either trim
    Sorry, but I am a bit confused. Focusing only on the Gas for EX AWD and EX-L AWD (in 98178): Is it 68% RV for 15K, and 61% RV for the 12K and 10K options (with answers the same for both trim lines)?
    .00120 MF
    The 68% is for 24/15, 61% for 36/15
    .00120 MF
    Ahh, that makes sense. But, I was meaning to ask about the difference between 36/15, 36/12, and 36/10. Based on an earlier response, I assume they would be 15: 61%, 12: 63%, and 10: 64%.
    .00120 MF
    Yes, that is the correct adjustment.
  • ErsincoErsinco Member Posts: 6
    Hello guys!
    I'm looking for MF/ RV and incentives for the following:
    36mo/ 15k, 60640
    LX, EX both AWD.
    Thank you for your efforts!
    Ersinco said:
    Hello guys!
    36mo/ 15k, 60640
    LX, EX both AWD.
    .00120 MF
    60%/61% residual for LX/EX
  • MooochMoooch Member Posts: 42
    Hi, I need the numbers on
    36/12 Base model
    33165
    36/12 Base model
    33165
    No base trim for the CR-V
  • mdickersonmdickerson Member Posts: 18
    I need MF, residual, incentives on crv ex-l AwD for 36/10 and 36/12 in 43844
    .00120 MF and 63% residual
    No incentives
  • drew92drew92 Member Posts: 3
    edited May 2021
    Hey guys, May I ask for the MF+RV+Incentives for a
    2021 Honda CR-V LX AWD 24m/12k and 36m/12k? Zip code 02148 Thank you so much!
    .00120 MF
    68%/62% residual
    36/12 Base model
    33165
    LX please
    Moooch said:
    36/12 Base model
    33165
    LX please
    .00120 MF and 62% residual
    Good afternoon KYFDX,
    May I please get the RV, MF, and incentives for a 2021 Honda CRV EX model in zip code 10705?
    36/15 term
    Thank you in advance
    Oscar
    36/15 term
    Oscar
  • socalsuvsocalsuv Member Posts: 4
    Can I have RV, MF, and incentives for a 2021 Honda CRV EX model in zip code 94538?
    36/10 and 36/12
    Sam
    36/10 and 36/12
    Sam
    No incentives
  • matrix12345matrix12345 Member Posts: 75
    Can I please get RV, MF, and incentives for a 2021 CR-V LX AWD gas, 36/10 in Zip 12534.
  • Mark789Mark789 Member Posts: 1
    Hi, can you please provide the MF, residual, and incentives for 2021 Honda CR-V EX in NJ, 08817 ?
    36 months/12k miles
    .00120 and 63%
    No incentives
    36 months/12k miles
    .00120 and 63%
    No incentives
    Can I please get RV, MF, and incentives for a 2021 CR-V EX AWD gas, 36/10 in Zip 12534.
    Thank you very much, sir.
  • mannyjmannyj Member Posts: 5
    Hi, Looking for MF, RV, and incentives for the CR-V EX-L AWD. 36/10k. Zip is 10303. Thanks in advance!
    No incentives
  • NiceCarGuyNiceCarGuy Member Posts: 6
    Hello there, I am looking for MF/RV and incentives for 2021 Honda CR-V Hybrid EX, 4dr All Wheel Drive, 36 Months/12,000 miles per year for 90024. Thank you for the information!
  • ammclammcl Member Posts: 23
    Hi, can I get the MF/RV/inceptives for 2021 LX 2WD 36/10k zip 77840
    .00120 MF and 65% residual
  • zndski97zndski97 Member Posts: 22
    Looking for mf, residual, and incentives, for a 36/12 lease in 16201 for the following models:
    2021 Honda CR-V EX-L AWD
    2021 Honda CR- V EX AWD
