I think the best job is the one you don’t need.
For most of my adult life I HAD to have a job (two of them in fact) just to make ends meet. 70+ hours a week was typical. Now I have a job that I don’t need but it’s the most fun I’ve ever had working. I see the boss first thing in the morning and then I’m trusted to do the right thing with the company’s assets all day with minimal supervision. Nobody looking over my shoulder, almost no paperwork and only one real rule—don’t hit anything.
Now I work 20 hours a week with options for an extra 10 at my discretion.
Every now and then someone has to create turmoil in the workplace which I don’t understand but even that is fun to watch. If only they’d work that hard to be happy.
I get along just fine with the judges and the defense attorneys that I work with. In some circuits everybody fights with each other like cats in a bag. I would not work in one of those circuits under any circumstances.
I am in the medical communications field. Largely advertising drugs and devices direct to doctors, but some consumer, as well. New job will be less promotional and more … science-y. Medical training, medical journals, that sort of thing. Yes, I am odd man out being a gearhead in this business.
Good luck with your new job. Sounds like you were there only long enough for a cup of coffee.
If you continue with job hopping you’ll have to sign up to Edmunds new site…Chronic Job Hoppers Anonymous.
I am trying to protect it though. Last fall I sprayed wd-40 into the door bottoms and rocker panels which I’m hoping will slow it down a little. This year I’ll try a repeat with Fluid Film.
The old cargo van has developed an intermittent start glitch over the last six months or so.
Usually it starts right up, no problem but occasionally when I turn the key I get nothing but a click. Turn it again and it starts right up. I thought it only happen after sitting awhile in cold or rain but recently it’s been happening at any time. Once I started it up and then shut it down after a second. When I went to start it up…click. There other night I was running errands and it happened three times in a row.
The van has never failed to start after the second or third turn of the key but I worry that eventually it will leave me stranded.
My thoughts are: ignition switch, starter selonoid or dead spot on the starter itself in no particular order.
Can anyone think of any other possible causes?
(disclaimer - I have very little mechanical knowledge, so take everything I say with a shaker of salt)
I can't remember that I ever got the problem solved - that car had a series of maladies that ended when I totaled it about 4 months before graduation.
My guess is the solenoid. I’d also check the engine ground straps. I have an old friend in the BMW club who was preparing to replace the starter on his older 528i but the problem turned out to be a corroded ground strap connection.
Can you connect a voltmeter to the solenoid to see if you are getting 12 volts to the solenoid when you turn the key?
If you have someone to turn the key while you are out under the hood, have a stick ready that you can bang on the starter with while the other person holds the key in the CRANK position. The vibration will often cause the solenoid contacts to "make" or the starter armature to make contact on a dead spot. Usually I recommend a small hammer or something metallic, but that depends on the location and ability to access the starter housing without touching the B+ lead or the keyed wire to the solenoid. I'm usually giving this advice for 3800 engines where the starter sits right under the front of the engine.
Since you hear a click, it's likely the theft protection is working. Otherwise I'd ask what kind of antitheft it has, the small chip in the key prong or the passive code transmitter (PK3key) in the head of the key. Then I'd suggest watching the lights on the dash to see if the security light comes on briefly and goes out as the key is turned to indicate proper reading of the security device.
The same thing recently happened to our Sonata recently, it was the starter. Apparently part of the gears on the starter worn down enough that if that part was in the right position it wouldn't turn over the engine.
I’ve had that happen before so I won’t rule it out. I’ve used the “wack it with a hammer” trick on a bad fuel pump. That’s my level of car repair.
The reason I say try the battery first is because I’ve seen batteries act up like that before and you have other batteries but probably not other parts that are easily swapped out.
Good luck and let us know the real fix.
That’s what she said.
I’ll wager one Kia Keyfob
You'd lose! There's a direct correlation.
"Warp factor 8, Engage" - Captain Picard
Had to smoke a young guy in a Ford Focus ST trying to play games on the freeway yesterday. What does it mean when someone wipes their shoulders with their hands? Is he dusting himself off for another round after getting gapped?
As they say “you can’t bet what ya don’t got”
Hilarious orthopedics and Anesthesia conversation
https://www.pinterest.com/amp/pin/126171227030775002/
Another funny one
For those who don’t get it, the other surgeons are coming because the patient is an organ donor
https://www.dailymotion.com/video/x2s6th7?fbclid=IwAR1KI2ZjZSJZbW5RpCzvx_KQnuXpX72o_GPhefIaX_ghMuMASF79JjvwG40
Just under $54 with wash and interior sanitizing.
Thought the brakes might be coming due, but checked out ok.
A couple of days ago I was driving the Clubman and had a run with an E60 M5 while headed home on the twisting less direct route; he was kind enough to let me keep up. It had an aftermarket exhaust and that S85 sounded glorious.
Yesterday I had a newer Mini Cooper JCW want to play in a two lane left turn lane. I was in the 2er so it wasn't that close- but the MC JCW is sweet.
I am at the airport waiting for the flight home. And Saints be praised its a miracle, I am actually at the very first gate in the concourse.
I turned in the Altima yesterday and was pretty I pressed with it. I reset the MPG reading on the dash when I got it and it was reading 28.8 average Mpg when I turned it in, all Orlando Street driving, no highway.
Yesterday and today I drove the SIL's moon car, a 2004 Honda CRV. it was holding up pretty good seeing that it's 17 years old and pushing 240k miles.
Overall I preferred the Altima.
Well by now I guess you know that flight you’re on is not going to Chicago. Don’t you know it’s illegal to have a close gate for your flight.
She should follow the one lawyer’s advice and file with her insurance company and let them fight it out. I’d think that the Ford dealer giving her a rental for a month is essentially admitting guilt. Either way, it’s less painful to file and move on.
Then fight over value with her own insurance company 🤣
On top of full replacement cost, the woman, should at least, be refunded the installment payments for loss of use and secondly, she should refuse to drive the car as it has become unsafe since the damage is so severe putting her and family's life at risk. Besides, why should be dinged on her insurance policy when she shares no blame for the accident.
I didn't know that Arizona had a monsoon season so severe in fact that it inundated the desert state with flood waters, mud and debris. Is this part of the new normal or just a repeat of the thousand year flood hinted at by meteorologists.
With a couple more rain events like this the desert will turn green and the persistent drought in Arizona will be no more and Phoenix will become an even more livable city with more accommodating temperatures.
Life often isn't fair.
