Visitor Agreement.
This +1
Beautiful M340i!
Congratulations.
Excellent choice!
What equipment & options?
- Ray
Somewhat biased - by over 20,000 miles driving an M340i...
@breld - congratulations on the M340. I had no doubt that’s what you would end up with. It just happened 30 days faster than I figured it would.
I bet you will swap out the front pieces for shadow line in no time
I must admit that I like the contrast of the darker grey with the chrome though
The reason for this is that when I was in the Navy, I bought 2 Chevy’s (‘56 and ‘62) from an uncle, due to his failing health, that had 6 cylinder engines. I swore up and down after the second time NEVER AGAIN.
This +1
Well, stickguy wishes he ordered the Maverick hybrid with less horsepower (And now he's ordered one!). And I'm actually glad I have the 2.4 in my 2018 TLX rather than the 3.5 V-6. The acceleration is fast enough for me with the 4-cylinder, and on my last highway trip of 420 miles at c.70-75 mph I got 38 mpg. But we are the exceptions that prove the rule.
There would have to be over a 25 mpg difference in fuel economy to make me take the model with less hp- and even then I wouldn’t be happy about it.
in a smaller room, a screen can be too big to view comfortably. and for HP, if you aren't racing, having too much power for the chassis and tires can be counter productive. the TL 2.4 was plenty quick enough, and better balanced handling having a lot less weight over the front end than the V6 model.
from reviews that actually got results, if it is primarily going to be used around town, actual MPG is going to be close to double. And the powertrain seems to be more suited to FWD. I think resale is going to be better too on that model, but we shall see.
Yes, they are - Mineral Grey. The lighting makes a big difference in the appearance.
The wheels are 19” and surprisingly, not staggered.
Because of xDrive. If it were RWD, pretty sure they would be staggered.
All I can say is ... wow! Even though I was on suburban roads and wasn't really able to let the car show me what it's really all about, you can certainly feel the HP wanting to be let loose. Ride and handling are as expected for a mid-high end BMW, though my extra pandemic poundage found the sport seats a bit confining.
Nonetheless, a fantastic car. Even though it's blasphemous to say, I could probably be very content with a 330i.
The house - well, the house was to be expected, but the garage is something else. Plenty large enough for them to expand the fleet, add lifts, convert some of it to a man cave, etc. One of the features I really liked was that the garage door openers were off to the side of the door, not in the middle of the ceiling, between the tracks.
Was too open jawed to get any pictures.
A Jaguar convertible with 96377 miles. What could go wrong?
Nothing that hasn't gone wrong before.
Thanks @rayainsw - it has the premium and driver assistance packages. Power tailgate, Harman Kardon.
I’m really impressed with the new sensatec. Compared to the very plain look on my 2018 X3, the new models are perforated and have contrast white stitching. Looks much more upscale, and I actually prefer the feel of it over the leather.
2025 BMW i5 - 2017 911 C4S - 2024 VW GTI - 2026 MB GLE450 - 2024 Genesis GV60 - 2019 Cayman
Just think how good you would look driving it back from the repair shop.
Sometimes I’ll drive the Jeep to Taco Bell.
On most domestic models I’d run from that mileage but for those Japanese cars I’d take them but wouldn’t pay that much. The Jag would be fun to drive….right to the mechanic.
And yes, you also know my habits…have already looked up the black trim pieces. 😀
I definitely drive to preschool. And work. On a crazy weekend, even the zoo.
Rebel…
Do one of you guys have a set of Michelin Cross Climate 2s? I had a set put on my Mom’s 2020 RX350. Her OEM tires (Bridgestone Ecopia?) lasted about 27K miles. She took it in for a tire rotation & NY State inspection the other day. The guy told her the tires barely passed safety inspection & advised she get new tires before the winter.
I’ve been starting up my Prelude and letting it run almost every day. I sprinkled some baking soda on the carpet to help soak up any moisture. Vacuumed it up and sprinkled some more down. The musty smell seems to be dissipating. I do see some rust on the bolts of the seat tracks.
I set up the Q7 for surgery last night before bed. I assumed it would be colder this morning, so I wanted to be able to get right to work. However, at 0830 when I finally dug into it, it was about 25 degrees, which really isn’t uncomfortable when you’re working.
Above is a shot of the bottom bushings in situ. And, below, showing the damage after removal.
It was very fast to get them out, compress the springs, and reassembled.
However, after installing the top brackets onto the car, lining up the bottom bushing with the wheel assembly was unbelievably difficult!
I ended up having to contort my body while hanging from a 6’ steel rod like a monkey to get the leverage I needed while also inserting the bolt into the passage of the mount and bushing. I’m sure it looked as ridiculous as it felt, but it got the job done! All told, I needed about 200# of leverage 3’ out from the lever point on the top of the wheel assembly.
It is done now, though, and I saved about $800 in the process. Now I just need to get the alignment completed.
Oops. I worked on it from 0930 (not 0830) to 1230. Not bad. It probably would have gone faster if I didn’t take nearly an hour trying different things got get the lower mounts joined. Once I finished the first side with the bar, the second one took perhaps two minutes to settle.
The temperature was above freezing by the end, which felt pleasant, but the ground started getting a little soggy due to the dusting of snow melting upon contact.
On the VW/Audi thread, the wife’s 13 Jetta, which we bought new, has only given us minor/annoying electrical issues. One just ended up being a fuse, but the other two persist. First, the front passenger window is a bit of a dance to close. Seems like it thinks it’s hitting something and goes back down unless you just nudge it through a critical point about 2/3 closed. The other is the TPMS which seems to have failed when the original battery died last year. I can only complain so much about a VW. My brother has had a few VWs and Audis and said the 16 A4 sedan he had was the best car he has owned. Not sure how many others he doesn’t talk about.
in this case, not the automatic transmission!
So after just over 3 years with the RDX I can now say I wouldn’t have gotten out of a situation without AWD. Didn’t arrive in time to park in the gravel lot at the Kentucky Castle so we were directed to the large grassy area. Which was quite wet, and more than a little muddy in spots. As we were departing, the wife noticed some guys one row over, trying to push a Fusion that was stuck in one of those muddy spots. I tried to go up our own row, but where the upgrade got a little tricky and more muddy, the two rows were parked very close together. I didn’t want to risk a wiggle ending badly, and got a little bogged down. I decided to back up to a gap that would get me to the next row, which was just as muddy but at least there was enough room that I could saw plus or minus a good 45 degrees as I powered my way up the hill.
Would have been easier with a better AWD or traditional 4wd but I’m not sure how it would have gone with 2wd.
and even with that, we only have 10,600 miles on it. Just don't do much local stuff I guess.
I got our FWD Enclave stuck in that very same situation
Saving 800 bucks is nice but you’re going to spend 900 bucks running the heating pad before you thaw out. :'(
some jobs, just way easier with a lift. and of course safer.
We wish you continued progress and hope you’re behind the wheel again in no time.
Have the tire shop call Michelin- they were great in offering money towards replacement tires when the Premier LTX tires were bald after 14k miles (60k mile warranty)
Strong work skipping the middle step although who knows, right now you may have been money ahead with the middle step?
Are you changing out the front and rear chrome pieces and exhaust outlets and badges? I’d be tempted to plasti dip them given your buying habits…
