2021 Toyota Venza Lease Deals and Prices
18910111214»
  • MichaellMichaell Moderator Posts: 271,471
    JoNat78 said:
    Hello, I am looking for money factor, residual and any incentives for 2021 Toyota Venza xle for zip code 53022 for 12k/36 month lease. Thank you.
    .00125 and 60%
  • JoNat78JoNat78 Member Posts: 27
    Hello I am looking for lease information on 2022 Kia Telluride S AWD zip 53022 money factor, residual and any incentives for 12K/36 month. Thanks
    2022 Telluride lease discussion
  • Hi! Could you provide the numbers for Venza XLE and Limited, 36/15, in zip code 48103. Thank you!
  • kyfdxkyfdx Moderator Posts: 276,818
    .00125 MF
    58%/56% residual for XLE/LTD
    Hello, I am not sure if the January 2022 numbers are out yet, but I am looking for money factor, residual and any incentives for 2021 Toyota Venza xle for zip code 53022 for 12k/36 month lease. Thank you.
    January programs will be released tomorrow.
    Hello, I am looking for January 2022 lease information including money factor, residual and any incentives for 2021 Toyota Venza xle for zip code 53022 for 12k/36 month lease. Thank you.
  • spencertimmspencertimm Member Posts: 18
    I'm looking for the RV and MF for a 2021 Venza XLE and Limited in 95819. Looking at a 36/15k lease term.
    .00125 MF
    57% XLE
    55% LTD
    Are these numbers regardless of zip code? I'm looking for zip code 53022 along with any incentives. Thank you.
    .00125 MF
    57% XLE
    55% LTD
    .00125 MF
    57% XLE
    55% LTD
    We don't have the specific numbers for your region, yet.
    The residuals are likely to be the same, and I'm probably 90% confident of the MF, too.
    But, until they're available to us, I can't say for sure.
    Thanks for checking. I'll check back in a day or two to see if you have received the specific numbers for my region.
    Hello, I thought I'd check in to see if the January 2022 lease information is available including money factor, residual and any incentives for 2021 Toyota Venza XLE for zip code 53022 for 12k/36 and 12k/24 month leases. Thank you.
    .00125 MF
    65%/59% residual
  • allyyseeallyysee Member Posts: 1
    Ask your 2021 Venza lease questions here! Get info about prices, money factor, deals, incentives, and payments.
    Hi, what is the MF & RV on a 2021 Toyota Venza XLE?
    36 month, 12k miles, zip: 19111 and 20902
    .00125 MF
    59% RV
    edited January 2022
    Good morning, a dealer responded that the residual for 2021 Venza XLE for my zip of 53022 is 57% when I thought it was 65% when I confirmed on this forum. Is the 65% the TFS set residual? Perhaps they are using a different bank. Can the dealer set their own residual rate? Thanks for your help.
    57% is correct for 36/15
    65% is for the 24 month term
    Thank you Michaell. Dealer confirmed 57% for 36/15 and 59% for 36/12 which aligns with your numbers. Thank you for clarifying.
  • nicoflux17nicoflux17 Member Posts: 21
    Hi, could I please have the MF, RV and any incentives for:
    2022 Venza XLE / Limited Trims
    zip: 98188
    12k/ yr
    36 mo. term
    zip: 98188
    12k/ yr
    36 mo. term
    .00083 MF
    59% XLE
    57% LTD
    Random question... Yesterday, the lease calculator had defaulted to the 59% RV for the XLE trim as you have mentioned. Today, it is defaulting to 63% RV for the same XLE trim (2022).
    I'm assuming this may be just an error on the calculator or is it possible that the RV can change in the same month?
    This is the 2021 model discussion. I think your discrepancy is using two different model years.
    zip: 98188
    12k/ yr
    36 mo. term
    .00083 MF
    59% XLE
    57% LTD
    I know that this is the 2021 model discussion however, the 2022 forum doesn't seem to exist. I did ask Michaell specifically for 2022's and I was given the 2022 MF and RV - which doesn't match the calculator.
    Was I perhaps mistakenly given the wrong values for the 2022 model year?
    zip: 98188
    12k/ yr
    36 mo. term
    .00083 MF
    59% XLE
    57% LTD
    I gave you the 2021 numbers, as this is the 2021 thread.
    2022 Venza thread is now open; please repost here
  • Princechris911Princechris911 Member Posts: 1
    edited January 2022
    Hi New to leasing, what MF, residual, and lease or loyalty credits (if any) should I be looking for on a 2021 Toyota Venza Limited 36/10k, Zip Code 11429
    .00125 and 58%
    No loyalty
    Good morning, I'm looking for February 2022 lease information including money factor, residual and any incentives for 2021 Toyota Venza XLE for zip code 53022 for 12k/36 month lease. Thank you.
    .00125 MF and 57% residual
  • uncmikeuncmike Member Posts: 26
    edited September 2022
    MF, RV, MSDs and any Incentives for:
    2021 Venza XLE / Limited
    zip: 28025
    36/10 and 36/12
    Thank you very much!
    zip: 28025
    36/10 and 36/12
    No lease programs for the 2021 Venza
