Visitor Agreement.
I like the sign that says “please touch”. That’s the same sign I used to put next to my fragrant herbs at the farmer’s market.
Did he use nickels for the bumpers and chrome? LOL
Excellent. Proves my point, I am a very informal friendly guy:
Which journal was your article published in? (Casual)
In which journal was your article published? (Formal)
It’s not an error to end a sentence with a preposition, but it is a little less formal. In emails, text messages, and notes to friends, it’s perfectly fine. But if you’re writing a research paper or submitting a business proposal and you want to sound very formal, avoid ending sentences with prepositions.
btw...it also says; Grammar snobs love to tell anyone who will listen: You should NEVER end a sentence with a preposition!
Let me see here. Someones says they have nothing on which they can improve in poor grammar.
Others correct that statement and are referred to as "dinoaurs."
Others improve that statement and are referred to as "snobs."
@Ioldfarmer50 s that similar to the snobs who look down on Canadian French as opposed to French French?
Probably....there is a difference. In high school we learn Canadian French.....we would probably get laughed at if we tried using it in France. Too bad you reminded me...that brings back fond memories of going to summer school every year to pass French...and I still can't speak or understand it.
That said, the house is all plaster, solid wood and brick. The roof is slate, which was replaced (and great expense) about 10 years ago, and will probably last another 100 years. The only dry wall is where repairs had to be done to electrical and/or plumbing.
No nothing about mold remediation. I don’t know if they have to tear out walls, drill holes in walls/wood…I just don’t know enough to understand the undertaking.
Real estate agent said it was priced at market (which is what I bid), but could be bid up. Now, it’s stuck in limbo with the current owners allegedly unable/unwilling to tackle the mold issue. I don’t want to tackle it,either. I’m just not smart enough to do it.
Is there some point to this name calling?
"Snobs" was part of the quoted text, I had no control over that.
"Dinosaurs" was my doing, I thought it sounded nicer than "Old F---s"
When did he ever make a point that made sense?
(is that even close to being a sentence? :@ )
Others correct that statement and are referred to as "dinoaurs." (Actually, it was dinosaurs :@ )
Others improve that statement and are referred to as "snobs."(as explained, that was the direct quote).
Just joking....as I say, it is the thought that matters. When I taught elementary school we laid off proper grammar or correct spelling...it was the creative thinking that was the main thing.
I have a 1954 house that has been heavily remodeled a couple times in its life, the latest a thorough re-do in 2005, to the point where the appraiser said the "effective" date of construction is 2005. Not sure what might be older than that in here, maybe a couple electrical outlets and a light switch. Structurally, it passed inspection with flying colors. I found the original building permit, it was $13K.
My late grandmother's early 60s house also had no issues at inspection when we sold it, and they had virtually no issues with the house in nearly 60 years of ownership.
I don’t recall anybody referring to it as a paint job.(?)
The whole family worked on it together. Free child labor FTW!
Exactly....his wife didn't want him to spend the money for a paint job. And, as the story goes he had all of these pennies saved up that would be very difficult to get rid of. So, as we say in French, it was in lieu of a paint job.
Driver called it a paint job, check the original post.
Plus I was thinking about it, there is a good possibility there are a few of those pennies that are worth more than a penny.
From what they said 7-8 years ago, they didn't have very many on hand, and a large number came straight from the mint.
My house is only 3.5 years old now. There are definitely things that contribute to it’s energy efficiency and structure that differ from older homes
Steel beams/columns were used as the main support structure in the basement. Exterior walls are all 2x6. The basement walls are all insulated (can see in unfinished part). There is also a ton of insulation in the attics.
It all adds up to a much more efficient home. My utility bills are virtually the same here as they were in a house half the size. The HVAC in the old home was brand new so it’s an apples to apples comparison.
So while I agree 50s and 60s homes were built to last they weren’t built as tight and insulated as today’s homes are.
Some were a bit rare, but probably not valuable. I wonder if he put them all heads showing....or tails, or alternated?
BTW, several folks in here have mentioned sub-flooring and roofing in homes built in the 50’s that had tongue and grove plywood. To the best of my knowledge I don’t think tongue and groove plywood existed back then. At least I never saw it in my area. Subfloors and roofing were usually #3 grade pine sheathing 3/4 inch thick (various widths) with plenty of open knot holes but this wood was still very strong. The reason it’s no longer used is because of the time it took to nail down each board. Today, tongue and grove plywood or OSB is used because it is just as strong or even stronger but it can be installed much faster. A win/win for everyone.
I mentioned tongue and groove boards. Yes much longer to install for sure!
As for the air quality. My house actually required a high CFM fan in the upstairs hallway bathroom on a timer for ventilation. We disabled it, as it didn’t seem to be making a difference either way.
Edit. Disabled the timer by taking off the program. Still works manually.
I have been considering the best way to insulate the basement walls in the unfinished part of the space there without having to construct framed walls around the perimeter. Gluing insulation panels to the concrete sounds appealing but I think they would need some sort of fire-resistant barrier on top.
and camera so that others can view it when I send them a link.
I tried setting up Dropbox, but I don't see how to just give someone a link to see a 15 second
video of the granddog playing in the yard or a 10 second clip of a classic car driving by on the interstate.
Sending the videos via my cell phone company to their cell phone drops the
sharpness greatly, probably to limit the size below some maximum Megabyte size.
The cloud? I hear folks always talking about the cloud.
Well "valuable" is subjective. I tend to look for wheat ear pennies and separate them out and keep them. I routinely check the value and some are worth a couple of cent's but I have a few that would fetch a buck or more. I'm still looking for a 1943 copper penny
YouTube, TikTok, Imgur (possibly).
re: tongue in groove flooring, pretty sure my grandma's house had that, as the floors weren't nailed. Hardwoods throughout save for kitchen and bathrooms/laundry room, would be insanely expensive today. Real wood and materials like the slate (I think) entry and large raised hearth fireplace would only be seen in higher end houses today.
We went from a 700 sq. foot summer cottage to a 2100 sq. foot actual year round house. We did this big addition and renovated the old part on my house in 2010 and used 2x6 construction plus spray foam. The house was too tight. We have an automatic humidistat on the bathroom fans and always use the range hood when cooking. The windows would still fog up when it got cold so I had to run a dehumidifier the first winter. We had to retrofit an air to air exchanger and it works great. It has 3 speeds so I can adjust it as needed. No more foggy windows
So, lots of mainly busy work I need to do today. Got an early start. Pulled the car out of the garage noticed the “low fuel” light on. First stop, Costco for gas.
Surprisingly busy for early in the a.m. Get in line, which moves quickly. Both pump spaces empty in front of me at the same time. Pull up behind an F250, who pulled up the same time as me.
Swipe the Costco Card, and we’re off. My fill up is quicker than the F250s. On the right of me is a guy who pulled into the pump, but with his filler on the opposite side of the pump. He got the hose to go around to the other side of his mini-van to the filler but his body was partially in the space between the islands.
After I fill up and get my receipt, I go back to my car to pull around the F250. No can do without either hitting the guy refueling his minivan, or hitting the F250. There’s just not enough space.
I use a service/MPG tracker on my iPhone. Get into my car to put in the data while I wait. No more than 30 seconds go by than the guy waiting for the pumps behind me, honks. I look into my rear view and wave at him, not sure where he wants me to go. He honks again. I waive again.
Finally, he gets out of his car, and comes up to my window and yells at me to “move out of my way”. I try to put on my “zen” face and tell him I can’t move until either the guy to my right finishes or the F250 in front of me finishes and pulls away. He gets even louder at this point and tells me to “get out of my ‘f^&c#!#&’ way”.
Well, this is getting ready to spiral out of control. I get out of my car, calmly point to the lack of space between the guy filling at the right pump, and the lane between the islands. And, firmly tell him to get back in his car and wait his turn. He just stands in the middle of the island, red faced, as the F250 has finished fueling and pulls away.
I get back into my car, start it up, and pull away. This is horses’ posterior is still standing in the island yelling at me, which the cars behind him are now honking for him to get his car out of the way.
Good Friday Morning to my Edmunds friends.
He flipped for it
