2022 Porsche Lease Deals and Prices (All models)
13468913
  • MichaellMichaell Moderator Posts: 268,957
    Hi can I get the Residual/MF for a 2022 718 Cayman GT4 with 11803 zip code:
    -36m/10k
    -42m/10k
    -36m/7.5k
    -42m/7.5k
    .00210 MF
    56% / 52% for 36/42 and 10K
  • mattsrsmattsrs Member Posts: 64
    Can I please have MF/RV and MRM for 2022 Cayenne e-hybrid for 36/7.5k and zip 19063?
  • kyfdxkyfdx Moderator Posts: 272,632
    .00210 MF and 59% residual
    MRM
    Coupe: $112,900
    SUV: $111,000
  • J07J07 Member Posts: 3
    Hi What is the MF and residual on 2022 Cayenne and Macan, 36/12k. Zip 11530, Are numbers different for base versus S? Thank you
    .00210 MF
    Cayenne - 59% / 55% for Base / S
    Macan - 59% for either
  • Mcwilson1983Mcwilson1983 Member Posts: 7
    Could I get RV, MF and MRM on ‘22 Cayenne Base, 60035?
    .00210 and 57%
    MRM $88,500
  • ssimssim Member Posts: 113
    2022 GT3 (Touring, if that matters)
    60/5k ; RV/MF/MRM Please! ZIP 90211
    .00245 MF and 41% RV
    MRM $198,400
  • bw5556bw5556 Member Posts: 14
    Could I please get numbers on both a 2022 Macan S and GTS?
    36/10, 90035
    Resid/MRM/MF
    36/10, 90035
    Resid/MRM/MF
    .00210 MF
    60% S (MRM $82,400)
    61% GTS (MRM $100,000)
  • s0upbones0upbone Member Posts: 7
    Could I please get numbers on both a 2022 Taycan 4S and GTS?
    39/10k, 36/10k, 39/12k 44122
    Resid/MRM/MF
    Resid/MRM/MF
    .00210 MF
    52% / 50% / 48% for 36/39/42 and 10K
    MRM
    4S - $129,400
    GTS - $157,000
  • anchaliaanchalia Member Posts: 43
    What is the rate of interest on a CPO Panamera for 72 months, when financed through Porsche.
    2.99% APR
  • ck1980ck1980 Member Posts: 20
    Hello. Could I please get numbers on a 2022 Taycan base? Zip code is 92630.
    36/10k, 36/12k, 42/10k , 42/12k
    .00210 MF
    52%/48% residual for 36/42 mo, 12K/yr
    .00210 MF
    Thank you. Could you also please provide residual for 36/42 month 10K/yr? Is it simply 1% higher?
    .00210 MF
    Yes, add 1% for 10K
    Taycan Base RWD (sedan)
    36/10k - MF/RV/MRM Please, ZIP 90211
    .00210 and 53%
    $102,800 MRM
  • bpine1979bpine1979 Member Posts: 3
    2022 Targa 4S
    36 vs 39 mo lease
    Lowest mileage allowed
    5k? or 7.5k?available
    Zip 80921. Looking for MF/Resid/MRM. Thank you.
  • evevevevevev Member Posts: 2
    2022 porsche 911 carrera rwd coupe 10k miles 36 months 18045 zip
    bpine1979 said:
    2022 Targa 4S
    36 vs 39 mo lease
    .00210 MF
    58%/56% residual for 36/39 mo, 5K/yr
    $177,300 MRM
    .00210 MF and 62% residual
  • Hi May I have MF/ residual for a 2022 Panamera 4S E-Hybrid for 36/12 in 33480.
    Thank you in advance.
    .00210 and 54%
  • Dan1980Dan1980 Member Posts: 5
    Hello, could I have MF/Residual for 2022 Pamamera base and 4s for 36/10 in 30519.
    .00210 MF and 58% residual
    Either trim
    Does One Time Pay Lease lower MF at all?
    Yes - subtract .00045 from MF for one-pay
  • btaback721btaback721 Member Posts: 22
    I am looking for MRM, MF and residual for 36/10 for a 2022 Taycan 4S in zip code 11791 please. Does MRM vary based if the car is equipped with the larger battery?
    Thanks!!
    Thanks!!
    .00210 and 52%
    $129,400 MRM
    No change based on battery size.
  • kp01988kp01988 Member Posts: 7
    Can I pls get MRM/MF/RV for 2022 Cayenne ehybrid 36/10k and any lease incentive atm. Thanks.
    .00200 MF and 58% residual
    MRM = $111,000
  • avz12345avz12345 Member Posts: 15
    Can I get MF/RV/MRM (zip 60712) for:
    1) 2022 Cayenne GTS: 39/10k and 36/10k
    2) 2022 911 Targa 4 GTS: 24/5k, 36/5k, 39/5k
    .00210 and 55% / 57%; $131,300
    .00210 and 58% / 55% / 53%; $194,400
    edited February 2022
    Thanks for this! Sorry one more:
    Can I also get the numbers for the Cayenne GTS 24/10k and 42/10k?
    Thank you again!
    Can I also get the numbers for the Cayenne GTS 24/10k?
    Thank you again!
    .00210 and 64%
    Sorry - I think my edit on my prior post went through too late - can I also get 42/10k for the Cayenne GTS?
    Thanks again!
    Thanks again!
    .00210 and 53%
  • lylesweelyleswee Member Posts: 64
    May I have MF/RV/MRM (zip 20878) for:
    1) 2022 Cayenne GTS: 39/10k, 36/10k, 42/10k
    2) 2022 Cayenne GTS Coupe: 39/10k, 36/10k, 42/10k
    3) 2022 Taycan Cross Turismo 4: 39/10k, 36/10k, 42/10k
    .00210 MF
    57%, 55%, 53% for 36,39,42 and 10K; $131,300 MRM
    57%, 55%, 53%; $134,700
    53%, 51%, 49%; $113,800
  • barad55barad55 Member Posts: 18
    Can I get MF&RV zip 95020 for:
    2022 Taycan Base RWD: 36/10k, 39/10k and 42/10k
    .00210 MF
    53%, 51%, 49% RV
  • tonyfu511tonyfu511 Member Posts: 22
    Can I get the MF, RV and MRM for 911 C2S coupe 36/12k in zip code 94551? Thank you so much!
  • advisor246advisor246 Member Posts: 2
    Dealer is asking for $5000 over MSRP for a 2022 Macan S, is that market today given the shortages?
    Also, could I get the MF and RV for Macan S in zip 10023? Thank you.
    .00210 MF and 57% residual
    See Price Checker link, below
