$500 loyalty
.00123 MF and 54% residual
Also, are these numbers the base numbers (dictated by BMW) that the dealer would then increase?
MF can be marked up a max of .00040; RV is fixed by the bank.
Of course, your dealer could be using a 3rd party bank or credit union.
All of the above assumes you have top tier credit.
However, as of today, for my area (35801) the base BMWFS MF is .00123 and the RV is 56%, correct? Max MF would be .00127, correct? Just want to make sure my facts are straight before I go in to negotiate more.
Appreciate all your help.
Can I please get the MF and Residual for 2022 M4 Comp xDrive
36M 10K/12k
Zip 33626
Any incentives or discounts?
.00136 MF and 56% residual
Use the Price Checker link, below, for discounts
2022 M4 RWD coupe 24/12k
Please advise March money factor and residual for a 2022 M4 convertible comp xdrive 39/7.5k, 48/7.5k
98391
36/7.5
.00158 MF
57% residual
Please send me MF and residual for 22 M4 Comp 3yr/36k miles
Zip 70433
22 M4 comp convertible
MF and Residual
24/10 and 36/10
Any incentive like loyalty or anything?
90211
60% / 56% RV
$500 loyalty
2022 M4 Competition
3 years/45k miles Total
Zip: 16365
Can you give current on same
MF and Residual
24/10 and 36/10
90211
59% / 55% residual
$500 loyalty
Can I have Mf and residual on m4 comp awd please for 60502
.00176 MF and 52% residual
BMW will lock the rate, and give you the option to take the rate that is in effect at time of delivery
But, be aware that the dealer can markup the base rate.
Thank you! When I input the year, make, model, and trim on the Edmunds lease calculator it shows this residual and MF.
Would you happen to know whether the lease calculator is updated monthly to show the correct residual and MF for cars or was it a coincidence?
Yes, the calculator is updated, monthly.
Two sources give you the same specific rates, and you think it's a coincidence?
Can you please tell the 22 M4 comp coupe MF and residual for 36/10k. Zip code: 26505. Thanks
Can someone let me know the residual for 36/10k and 48/10k please. Also the MF rate for both if they differ. 2022 BMW M3 Comp. Also what rebates are available this month?
.00190 MF and 57% residual
No support for longer terms
2022 M4 Comp Coupe xDrive: 7.5K @ 36, 10K @ 36
2022 M4 Comp Coup (not manual): 7.5K @ 36
Are there any incentives? Thanks.
