2022 Jeep Wrangler Lease Deals and Prices
11516171820
  • MichaellMichaell Moderator Posts: 268,537
    Can I get the Money factor and residual for 2022 Jeep wrangler 4xe sahara for 36 months 10k mi/yr for 64081.
    If standard MF, please provide the standard rate. Thanks.
    Standard MF and 61% RV
    .00248 MF for 36 months
  • rellimpsrellimps Member Posts: 16
    Can I please get the MF and residual for 2022 Jeep wrangler 4xe Sahara for 36/12k? Zip 46628.
    If standard MF, please confirm that rate. Thanks!
    Standard MF and 60% residual
  • Ruffiano99Ruffiano99 Member Posts: 1
    edited September 2022
    Looking for the Standard MF and residual for a:
    2022 Jeep Rubicon Unlimited 2.0L
    48-months/12K per year
    Zip code 08884
    Thank you!!
  • kyfdxkyfdx Moderator Posts: 272,380
    Zip code 08884
    Thank you!!
    Standard MF and 59% residual
    48 mo = .00225 MF
  • JiggaRJiggaR Member Posts: 46
    Hi-
    Can I please get the following
    2022 Jeep Wrangler Willys 4DR 36/12. MF Numeric? Residual? Zip 07003
    JiggaR said:
    Hi-
    Standard MF and 65% RV
    .00312 MF for 36 months
    Any incentives?
  • njnoiznjnoiz Member Posts: 9
    Hello:
    Would love residual and MF for a 2022 Wrangler Sahara 4xe....3 yr/36k...in 70471
    Any incentives?
    None that we see
    njnoiz said:
    Hello:
  • trikerytrikery Member Posts: 53
    Looking for the MF and RV for Willys 2dr in zip 11375 (Not Willys S)
    36 / 10
    48 / 10
    Thanks for the help!
    36 / 10
    48 / 10
    Standard MF
    60%
    57% residual
  • AahhccAahhcc Member Posts: 12
    Can you please share MF/RV/Incentives for 4xe High Altitude 36/10 for 20817
    No incentive info
  • justinrrsjustinrrs Member Posts: 14
    Can I get mf/rv for a 2023 willys 4dr in 48183 with 36/10, and 48/10. 36/12, 48/12.
    2023 Wrangler discussion
  • Jloe132Jloe132 Member Posts: 6
    Hello there,
    could i possibly get numbers for 2022 Wrangler 4xe Sahara for 36 and 48 mos 10k per year.
    Thank you so much!
    Jloe132 said:
    Hello there,
    Thank you so much!
    Standard MF
    61% / 56%
    Jloe132 said:
    Hello there,
    Thank you so much!
    Standard MF
    61% / 56%
    How about the MF and is it the same for High Altitude 22 wrangler 4xe as well?
    Jloe132 said:
    Jloe132 said:
    Hello there,
    Thank you so much!
    Standard MF
    61% / 56%
    Same for the HA.
    .00312 for 36 months
    .00245 for 48 months
  • techCarLovetechCarLove Member Posts: 21
    Can I please have MF, RV and rebates/incentives 2022 4xe Rubicon and Sahara
    36mos. 10k zip code 11719
    Standard MF
    63% RUB
    61% SAH
    No incentive info
  • EdmundadviceEdmundadvice Member Posts: 4
    edited November 2022
    Good morning,
    Can someone please provide MF, RV, and incentives for 2023 wrangler sahara 4xe for zip code 33432
    10k/36
    12k/36
    Good morning,
    10k/36
    12k/36
    2023 model discussion
  • sspringlesspringle Member Posts: 32
    Could you tell me what the residual is for a 2022 Rubicon 4xe for 36 months and 12,000 miles. Would you also be able to tell me the MF? If it is the standard MF, what is the current number for that.
    Standard MF and 59%
    36 months = .00296 MF
  • KorakKorak Member Posts: 11
    Anyone know the current MF and residual on a Willys and Sahara (both 4 door) for a 36 month/10k lease. Zip is 11766. Thanks in advance!
    Standard MF
    60% SAH
    63% WIL
  • kevinv9191kevinv9191 Member Posts: 3
    Can I get the Money factor and residual for 2022 Jeep wrangler 4xe sahara & rubicon for 36 months 15k mi/yr for 21401.
    Standard MF
    57%/55% residual for RUB/SAH
    36 mo = .00296 MF
  • mrcobmrcob Member Posts: 3
    Hi, may I please get the MF (numerical) and RV for a Wrangler Unlimited Sport Altitude. Area 92679.
    Looking at a 12/42 or 12/48.
    Standard MF
    59%/58% residual for 42/48 mo.
  • cndnbkncndnbkn Member Posts: 76
    Hello, Can you please tell me what the MF RV and any incentives for a 2022 Rubicon 4xe 36/10 for zip 27517?
    No incentive info
    Any incentives for 2022 4xe rubicon for 27517 zip?
    $7500 lease credit
  • Maddog72Maddog72 Member Posts: 33
    Hi there looking for current incentives for jeep 392s in zip 08055..thank you!
    Standard MF and 54% residual
  • miketythonmiketython Member Posts: 40
    Hi, can I have numbers for 36/10 term on a 4xe Sahara? Located in 08816. Thanks.
    Standard MF and 57%
    Can't determine if there is the $7500 PHEV bonus, or not.
    Standard MF and 57%
    Confirm $7500 PHEV bonus available.
  • dannassdannass Member Posts: 9
    Hello, looking for the MF / RV / incentives on '23 Sahara 4xe, 36/10, 48228. Thanks!
  • Shanahere3Shanahere3 Member Posts: 10
    Could you please provide current MF/RV & incentives for 2022 Wrangler Unlimited Sport 4x4 turbodiesel 36/10 and 39/10 for Zip 33312?
    Standard MF
    65% / 64% RV
  • 216MiraCLE216MiraCLE Member Posts: 73
    Good Evening!
    I'd like MF, RV and incentives on a 2022 Wrangler 4xE Unlimited Sahara.
    36/12k
    39/12k
    32720
    and if it is standard MF, what is that exactly?
    Good Evening!
    36/12k
    39/12k
    32720
    Standard MF
    56%
    54%
    36 = .00338 MF
    39 = .00378 MF
    Good Evening!
    36/12k
    39/12k
    32720
    $7500 PHEV incentive
  • obiwan_kenobiobiwan_kenobi Member Posts: 19
    Hey. Can I get the MF and RV for a 36, 39/12k 4xe Sahara. What's the standard MF? Any incentives for 94706?
