not sure where it is. I think I only opened the hood twice since I owned it so not quite sure where they stuck it.
acura is under the hood someplace also easily accessible. But Honda is good about that kind of stuff.
I used to go check on him a couple times per week and bring him food and (I'm almost ashamed to say) cigarettes. I'd start the car every once in awhile, but eventually let it sit too long, and it died. When it came time to bring it over to my place, I had put it on a trickle charger for awhile.
The Regal's battery, and the one in the Ram, both feel like they still crank nice and strong. No straining or sputtering. Sometimes, if they've been sitting too long, they might spin for a bit longer, but I'd guess that's because the fuel drained back into the tank and it just takes a moment to pump it back to the engine?
measures several things about the electrical system of my cars
including the % status of my battery.
You have to know the CCA rating for the battery, which is on the top label.
I had been checking the battery in my DIL Encore. It was about 60%.
Then months later I checked it in their garage at 35%. It barely cranked
over because it hadn't been started for a few days while she was
not on duty at the vet clinic.
It measures something about the status of the cells. Along with being
able to measure cranking and charging.
There's a 15% coupon in the current listing for $58.
https://www.amazon.com/TOPDON-BT100-Automotive-Alternator-Motorcycle/dp/B07Z67MMGC/ref=dp_prsubs_1?pd_rd_w=rGAym&content-id=amzn1.sym.ec3cee7c-6bd8-496a-8166-4fdb6d51cad1&pf_rd_p=ec3cee7c-6bd8-496a-8166-4fdb6d51cad1&pf_rd_r=YKMZWT7WEZ52MP0MNDE1&pd_rd_wg=w3EbC&pd_rd_r=4eca6fb3-dd40-4833-8dcb-3bc454acabbd&pd_rd_i=B07Z67MMGC&psc=1
I'm not sure what year they changed them over to needing the key. My '69 Bonneville needed the key, and I saw a '59 DeSoto Fireflite where someone was sitting in the back seat, playing with a power window without a key in the ignition, so it was sometime between those years.
I wonder if it was 1969 that they made the switch? There was that somewhat famous scene in the Brady Bunch pilot episode where they locked Tiger the dog in Mr. Brady's '68 Polara 500 convertible during the wedding, and he rolled the window down.
PS: Uplander, look at what's on the front fender of that Polara...I know you like that little detail
When I was a little kid, I remember playing with the power accessories (esp seat) in my mom's T-Bird and draining the battery, I don't know if a key was needed to operate that stuff.
That piece of trim just turns that car into a total siren!
I'm about 74% (LOL) sure, that my high school friend's '68 Bonneville Brougham power windows didn't work unless the key was in.
This I am sure of--power windows used to go up and down a lot faster in the sixties than they did in the '80's and later.
Kind of along these lines but most late 80s / 90s GMs you could press the volume knob while the car was off and the clock would pop on
On this style radio…. They all did it.
As for the windows, I’m sure as suggested it was for safety and I’d wager security. Would be pretty easy to stick a wire hanger in between the window and press the switch
I thought it was odd that the Cavalier had that feature, but not Grandmom's LeSabre. I wonder if it was a running change that they made during the 1985 model year?
My '89 Gran Fury had 10 presets! There were only 5 buttons, but then there was another button you could press to cycle through "FM1" or "FM2". It also had, by default, 10 presets for AM, but I seriously doubt anybody needed more than one AM station by 1989!
These days there's only three radio stations I tend to listen to. If I don't like what's playing on one, I can usually find something on one of the other two. Naturally though, they all go to commercial break around the same time!
That radio (and all its faceplate variants) must have been made in stupidly high numbers.
This Chrysler one too in that similar 1.5 din size was in everything Mopar in the late 80s way into the 90s
Ford seemed to have more variety with their single din headunits, but this one was very popular in that timeframe too found in nearly every model except Lincoln
To be fair, it even happened a MB - you'd get the same radio in a 190E as a 560SEC.
Most likely this one in the Taurus.
I still have to get used to having the radio stay on when you turn the car off, until you open the door. makes it harder to remember if you turned it off or not!
I think most cars today have the retained accessory power.
My ‘79 Scirocco kept power to to radio, I think my ‘83 GTI didn’t. Germany vs US I guess.
Still, it's interesting that the El Camino's wheelbase actually went UP in downsizing! I imagine there aren't too many instances in automotive history where a downsized car ended up on a longer wheelbase. I think the '89 T-bird was slightly shorter than that '83-87, while the wheelbase grew from something like 104.4 to 113". But I don't think anyone ever thought of the '89 T-bird as "downsized"! I believe the '57 Plymouth was slightly shorter than the '56, despite the wheelbase growing from 115" to 118". But again, downsizing wasn't the goal here.
Over the weekend I saw an Olds Silhouette (2nd gen) and then no less than one minute later saw the Pontiac version. I can’t remember if it was still the Transsport by then or not. Montana maybe?
Just weird to see both of those in such a short time frame. Most are long gone.
That car is a second series fintail, the 230S replacing the 220S, which moved up to a W108 250S after 1965. That car has some minor trim differences (less wood and a few fewer chrome bits come to mind), but is functionally the same as my car.
It's on his site, too:
https://mercedesheritage.com/free-classifieds-only-classic-mercedes/show-ad?id=1629
Avantis were built on their own line, really much more hand-work involved, through Dec. 26, and trucks were built through Dec. 27.
I always felt four headlights, full-radius rear wheel openings, and 15 inch wheels made these cars seem more like mid-sizes than compacts.
and I would like one of those playmobiles today!
Built with no radio. Go figure.
It hadn't always had the best storage in South Bend since day one. Glad it still looks this nice.
