1286228632865286728683236
    mjfloyd1 said:
    I have shoved a screwdriver through one and use that to turn it and get it off. Kinda messy though
    I definitely thought about that, but I wasn't yet positive the new filter was correct so I didn't want to damage what may be the only one I had. FYI, the new one was correct.
  • roadburnerroadburner Member Posts: 18,674
    edited January 2023
    @jmonroe1 said:
    How wrong could it have been to buy a car for 5 bucks?
    There has to be a story about that.
    The local Chevy dealer had a Memorial day promotion, there were three somewhat decrepit cars. The Riv was to be "sold" for $5 at 10:00 am, another car at 12:00 pm and the last at 2:00 pm. The deal was that everyone there at that time had their names put in a hat and one was drawn. The ads for the promo didn't get wide distribution and when I heard about it I told no one. I showed up at 9:55 and I was the only person there; I waited on pins and needles until 10:00- when the sales guy I knew walked into the showroom and said, "Write up the deal for RB on the Riv!"
  • corvettecorvette Member Posts: 11,830
    I have one of the oil filter tools with a long fabric strap that goes around the filter. It would take a ginormous filter not to fit inside it.
  • oldfarmer50oldfarmer50 Member Posts: 24,738
  • breldbreld Member Posts: 6,988
    I know it's "just" the 4 cylinder, but this strikes me as a fun little vehicle for $38k.
    https://www.cars.com/vehicledetail/00913557-1981-489d-bb0a-b4f15ec96443/
  • xwesxxwesx Member Posts: 18,119
    It's all hype until/unless it comes to pass!
  • explorerx4explorerx4 Member Posts: 21,229
    @breld,
    I messaged them and said you'd be right down to pick it up. :D
  • jmonroe1jmonroe1 Member Posts: 9,966
    Thanks. Very strange that the dealer didn’t hype the promo. Today they hype free wieners for Memorial Day.
    I imagine you did quite a bit of wrench turning on that $5 beast.
  • stickguystickguy Member Posts: 54,546
    that is a lovely car. would be perfect with a manual, but in this case I could make an exception!
    It sounds like you missed the opportunity to jumpstart a hooptie fleet with two more cars by hanging out there until 2:00 PM.
    edited January 2023
    mjfloyd1 said:
    @qbrozen said:
    When you don’t have a large enough filter wrench on hand for your JDM diesel truck and your monster channel lock pliers are MIA and daylight is almost gone:
    -----------------------end quoted material--------------------------------------------
    That can be a bad idea. Back around 2000, I owned a Ford F250 with the 460 V8, used mainly for hauling a 5th wheel travel trailer. Back then, I did all of my own oil changes, but for some reason I had one oil change done at a quick lube. And wouldn't you know it, they apparently tightened the oil filter with an impact wrench. Don't ask me how they managed to tighten an oil filter with an impact wrench, suffice it to say that oil filter was not coming off.
    I tried the screwdriver trick, and tore the oil filter in half. The next day, I bought a giant pair of channel lock pliers. That succeeded in removing all but the base plate, which was apparently welded to the mounting block. I finally paid to have the truck picked up by a wrecker and taken to the dealership. The dealership only charged me for an oil change, surprisingly. I went in the back and asked the tech how he managed to remove the remnants of the old filter.
    "Judicious application of a hammer and chisel."
    Which was an idea I had considered, but discarded due to fear of scarring up that mounting block so that it wouldn't properly seal.
    I predict improvement in lease prices in 3 mos. Maybe 6 mos, 9 mos, 12 mos, 18 mos, 24 mos ...
    Back in the early 70’s a young coworker who had a ‘68 GTO decided after listening to us guys talking about working on our cars it was time for him to do his first oil change. He always took his car to the dealer for everything but since he was recently married he wanted to save as much as he could so he could buy a house. Anyway, he couldn’t get his filter off so he called me for some advice. I asked him if he could unbolt the mounting flange that held the filter housing to the block. He was lucky and got it off then he brought it to my house with the old filter still on it. I put the flange in my vise and used a 2 foot pipe wrench to grab the bottom plate of the filter. It still took a good bit of force to break it loose but it finally came off.
    I told him to put some oil on the gasket of the new filter and only tighten it 3/4 to 1 full turn, and no more than that, after the filter made contact with the mounting flange that he now had in his hand once he installed it to the block.
    Even back then dealers must have used new hires with no training about how to do an oil and filter change. So they used a lot of force to install filters so that they wouldn’t get chewed out if customers came back with an oil leak at the filter.
    Strange how I NEVER had a problem getting a filter off that I installed but have had several sailor cursing episodes with shops that installed filters too tight. I will say that the heavy duty cap wrench that I have that fits over the end of the old style metal filters usually gets the job done before my cursing burns my ears.
    Oh yeah- but it was fun.
    The C43 gave me a couple of Low Battery warnings Saturday and Sunday, so I called the Louisville M-B dealer yesterday and they were able to look at the car this morning(no trials or hearings today- fortunately). The culprit was a bad battery- I was on my way in a bit over an hour; a good first impression.
    If I didn’t have the Integra Type S “reserved” I’d be giving it some serious thought.
    I also had a great first impression at my MB dealer when I had it in to address the various issues on my wagon. The warranty is up in about a year - I even looked up some costs and info on extended warranties the other day! Obviously I didn’t purchase anything cause, well you know, a whole year!
    just buy it. will give you something to trade in on the Acura.
  • au1994au1994 Member Posts: 3,830
    Nice color combo, price actually seems reasonable and would be plenty peppy with the 4 cylinder. As long as you have never driven the 6 you may never know the difference.
    I already have 2, 2 liter 4 banger turbos in the fleet. might as well make it a trifecta!
    other than the cost. always a minor sticking point.
    That’s funny, I had the same experience with my 69’ Plymouth. Only I didn’t have money for a tow truck so we tied my car to the bumper of my friend’s and he towed me to the garage. You should have seen the looks they gave me when I told them I couldn’t afford to pay them to both remove the old filter AND change the oil too. I had my buddy tow me back home where I completed changing oil and filter myself.
  • MichaellMichaell Moderator Posts: 269,855
    Uh, you do remember that he had a Supra?
  • fintailfintail Member Posts: 58,983
    Not sure if the system is the same on my car, but I get low battery warnings a lot. I think they have it set so if it discharges below 90% or something, it gives a warning. I've checked the charging system in the diagnostic mode, and found no issues. If I am cleaning the car and have the doors open for 10 minutes, or drive the car several times on short 10 minute drives, esp in cold weather, I will get the notification. So far I just ignore it. If I drive for 20+ minutes the warnings cease.
    There are more than a few complaints on the Maverick boards about battery warnings--I think Ford refers to it as going in to deep sleep mode, or something. I suspect the warning shows up if the truck had to do any form of load shedding while turned off.
    I had 'The Works' done on my Explorer today.
    It even had a separate printout of the battery test.
    The previous time, at a different dealership, not going back there again, they mentioned that the tested the battery.
    I got also got an online buy offer for the Explorer from Carmax today.
    I have one of those battery testers (disclaimer: from Harbor Freight, so take it for what it's worth). The battery on the Maverick has tested at 1,000 CCA despite being labeled at only 700. Hopefully, that gives it a longer runway before it dies.
    That was the issue; the warning was not going off.
    I think most of the deep sleep issues are on the hybrids. Sounds like there is something (likely software) related that drains the 12v battery. Plus that is undersized maybe. I'm sure there have been some EB problems but usually a bad battery.
  • tifightertifighter Member Posts: 3,875
    I want you to test drive it, just to see how you fit. I agree that the value seems pretty good. And that’s the color combo to get, IMHO.
    edited January 2023
    @tifighter,
    HA HA Good one. B)
    I’ll swing by for a test drive next time I am running errands in your neighborhood!
    Though I actually like the newer one a lot. Many goodies. Though yours is a classic.
    Three acquisitions today
    Two out of three are disappointments. And I just so happen to run into a driver for Duncan imports. We chatted for about a half an hour
    Were you trying to talk him into taking back the ones that were a disappointment?
  • kyfdxkyfdx Moderator Posts: 274,084
    @qbrozen What is the 3rd acquisition? The trailer?
    That was my assumption...
    @qbrozen,
    I assume you made sure your overall length is legal.
    edited January 2023
    @qbrozen,
    Is there an illegal length? I'm certainly shorter than a school bus or 18-wheeler.
    Yes, 3rd acq was the trailer. The most expensive of the three, too.
    And, no, Duncan doesn't want my hand-me-downs. Lol. I'll give more when I have time, but blue one has bad paint on the hood and silver one has slipping auto trans. Hopefully the 2nd is solved with a fluid change.
    I've come to the conclusion, for those keeping score, that one should never buy a vehicle with less than a 4-B-B score on the JPN auction report. Apparently, 4-B-B is perfect, while 3.5-B-B allows for needing repaint, and a 4-B-C can allow for rust. A 4-C-C can be rusty and have cigarette burns on the seats. I don't know what the hell the 4 means in that case. It boggles the mind how one letter or a half point can make the difference between perfect and major rehab. I can only imagine a 3-C-C is scrapyard fodder.
    edited January 2023
    Hey, at least you're getting the hang of it!
    I like the trailer. I don't see many that size with the big gate ramp on it like that. Is that a twenty footer?
    yes, 20-foot. It was a leftover at the trailer dealer 160 miles from home. Who knew trailers did "leftovers"? They claim original price was like $5500. I paid $3700, but then added the spare and holder for another $175, and they had some dealer fees, believe it or not. OTD was $4100 and some change.
    So that gate can actually fold down onto the floor, which I thought would work well for me so the bumper of the car could hang over. BUT, driving over the gate was another matter. While on the angle of my wood ramps, the gate was grabbing the underside of the car, so I couldn't load it like that. I have plans for a couple of mods on the trailer, such as cutting off the front rail so I can pull tires right to the edge, and adding metal to the underside of that gate so the tires can drive over it easier when it is flat on the wood bed.
    @qbrozen,
    Over a certain combined length, you need a commercial drivers' license.
    Here's what I found for New Jersey(unofficial).
    In New Jersey, trailer towing laws limit the total length of a combination of vehicle to 62 feet. They also require an independent braking system that can be automatically applied in the event of a breakaway on every trailer. They also want to see a braking system that works in unison with the brakes of the towing vehicle. If a trailer weighs more than 3,000 lbs, there need to be brakes on all of the wheels, and the gross weight of a trailer without brakes should not be more than 40% of the weight of the towing vehicle.
    If the connection is made via a hitch, there needs to be a chain or cable in addition. The signaling on every trailer needs to include two (2) tail lamps, two (2) stop lamps, two (2) turn signals, and (2) reflectors, one on each side. The mirrors need to allow the driver to have a clear view of traffic behind and on the sides, and a maximum of one (1) boat can be towed at a time.
    edited January 2023
    Yeah, it takes a lot of trailer to combine over 62'. I think the only thing out there that could exceed that limit is a 5th wheel with a hitch trailer attached behind that (which is very rare; I've seen that only twice that I can remember). Even when I drove my grandparents' 1997 F350, which is about 24' long by itself, pulling a ridiculously long 35' enclosed triple-axle bumper-mounted trailer, I was still only at about 60'. Man, that thing was so big. I recall stopping at a couple rest areas in Washington: I'd park in the truck lanes, and I was just about the same length as a tractor w/ single trailer.
    As for Q's trailer, if you have a welder available, you might consider cutting and repositioning the front rail such that it allows the tires up to the edge of the deck but still provides a stop (so, maybe put it at a 45 or 60 degree angle toward the front).
    If that's a solid deck, you might also consider putting in some e-track to give you excellent and convenient locations to strap down your vehicles whether hauling one, two, or more!
    Better move fast. If you believe the experts on YT, CarMax is right behind Carvana on the way to bankruptcy.
    Those "experts" haven't actually studied the companies, and their financial/RE assets, then.
    I don't think the YAA guys know how to interpret financials.
    Since when does having a car on "reserve" stop you?
    Since the market has softened and dealers are baking all that into trade values. It's been so nice to "try out" cars over the past couple years, but those days are ending.
    @qbrozen,
    Not to mention the ones that are graded 1-M-M. :'(
    For this we need a sad face :(
