I haven't found out where it lives yet. Maybe it's just visiting.
I didn't know Aston Martin made a SUV.
Now what gets me is that they have a car model named Valkryie and one named Valhalla. Since Valhalla is the Norse heaven and you are taken there by the Valkyries if you buy a Valhalla do you also have to buy a Valkyrie to take you to your Valhalla?
If you can spend a few $ extra, this one has zero wires. claimed 3 minute DIY installation. if you can screw on a license plate, you can install this. Looks like you have to turn it on when needed though since not wired into the reverse lights.
Maybe I am being too particular but that backup camera has one big problem that I am trying to avoid. It has to be plugged into the cigarette lighter. The ideal would provide power through it's own battery. With this one, and similar ones, you have to have to plug it into the cigarette lighter. That means you have a cord hanging down all the time, when I pack up on average for 30 seconds a day. I'd rather not have one if that is the case.
https://nerdknowbetter.com/best-battery-powered-dash-cam/
https://www.msn.com/en-gb/lifestyle/rf-best-products-uk/best-cordless-dash-cam-for-cars
"We can directly connect battery packs to the cigarette socket in the vehicle."
and the $129 one is solar powered and connects to the headunit vis bluetooth. That I think is battery powered so occasionally you need to plug in to the usb port (or take it in the house) to recharge. But that has no wires and zero connection to the car.
I do look from time to time but though they say wireless, they usually mean just the camera is wireless....but the monitor seems to need to be hardwired or plugged into the cig lighter...except the cheaper one @stickguy mentioned looks like a possibility.
Anyone got an opinion on it? They say it attaches to the backup lights wiring, and that probably won't interfere with the MB main wiring.
There is a more expensive updated version which is probably worth the extra $40. Do you see anything that can go wrong...is it foolproof, I don't want to mess up the wiring in the MB.
https://www.amazon.com/gp/product/B07DVNWNDH/ref=ask_ql_qh_dp_hza
I haven't seen wired into backup lights mentioned before, it seems so simple and sensible, yet they are hardwired or have a wire going to the cig lighter.
2013 LX 570 2016 LS 460
Too bad they introduced it just as wagons were going out of style in North America.
one benefit to that I think is since the unit always has power, you can turn the camera on when the car isn't in reverse if you want to. You can also hook up a camera on the front plate too if you want, and have front and rear views.
I got mail from them today offering an additional 3 months for free. The catch? You can't get the extra 3 months unless you give them credit card info.
I’m pretty sure that to be able to view both the front and rear cameras the monitor would have to be capable of receiving two video input signals and that would require a split screen monitor. There is nothing wrong with that but I doubt you’d get that for the price shown in your link.
A way for the single video input signal monitor to work would require a manually operated dual video input switch with one video output going to the monitor. However, again the cost will go up and you will NOT be able to see both camera signals at the same time when using a video switch like the one I described above.
You’ll have to pick your poison.
Like I said, to do that requires a video signal switch so you can select your preferred view.
though I do have some boxes of old electronics parts downstairs that I moved and need to sort through, and I am sure there are a few A/B switches and cable splitters in there!
I can’t see @driver100 doing anything other than shifting into reverse and watching the monitor.
As for those old video game A/B switches, they may not have sufficient shielding that the new video signals need today but it wouldn’t hurt to give those to @driver100 since he wouldn’t know the difference anyway. He’s probably still trying to figure out how the muffler bearing works that he got 20 years ago when he thought he’d try becoming a DIYer.
I added a backup camera to my aftermarket head unit in the Charger. That’s a whole different scenario, though. It would probably be less troublesome in an MB to replace the whole thing than try to get the OE head unit to do what you want.
Then I looked into the after market units that sit on the instrument panel. They would have to run wires all through the car and the monitor would have to be hard wired (which they wouldn't do on an MB) or run the famous cord to the cigarette lighter.
These units are kind of what I envisioned they should be making. I am first going to see what my neighbor who is good with this stuff says, and if not I can see if there is a shop that will install it. It won't be me..........most things I end up breaking or creating a costly repair.
And by "turn on signal", I'm referring to a signal to the head unit to switch to displaying the input from the camera.
Trying to integrate with any OEM type system can be nearly impossible. And in some cases, trying to replace the OEM system is more trouble (and cost) than it's worth. Some factory systems are easy, you have a double DIN opening in the dash, and Crutchfield (or others) can sell you a wiring adapter. Other OEM systems are much much more difficult to try and replace.
Good answer, and probably the new one has any bugs worked out of it. I got a reply from an Amazon customer about the power supplied by backup lights......
"I hooked mine up to my backup lights and it worked fine."
Now I need to buy it and find someone who will install it.
By the time you get a back-up camera or its equivalent installed on your car, many of us will have passed on and you’ll have fewer posters to haunt about this - but new posters who replace us might find your plight intriguing - who knows?
So for the sake of us older folks, get this done before we are not among the living! 🤪😜
I am starting a Go Fund Me fund. The sooner you all contribute the sooner I can get this done.
For several years now, we have all struggled with your posts about not having a back-up camera on your “old” C Class. Finally, you might have a solution but you are again coming up with excuses - wiring, cost, positioning, to name a few. Now you want us to pay for it! OK, I pledge $1.00 to your project!!! 🥸😜🤪
Keep waiting. I’d rather croak.
