Subaru Crew - Future Models II
11112141617446
  • ramonramon Member Posts: 825
    the new passat like a4 will have 180hp instead? 220hp is TT territory and that means they are using KKK K04 turbo instead of K03 which all 1.8T uses other than the big boys like TT.
    anyways if you want rear seat room. Try a saturn L sedan or wagon.
  • amishraamishra Member Posts: 367
    the new a4 will still only have 150 bhp with the 1.8, and 220 bhp with an optional 3L V6
    http://www.audiworld.com/news/00/newa4/content3.shtml
  • tshadletshadle Member Posts: 38
    I read with great interest Drew's post about the VDC getting stuck in the sand without a "VDC Off" switch because that is exactly where I plan to take it.
    Juice - check out your response to post #57 in Subaru Legacy/Outback VI "VDC and Snow"(Man, did I have to HUNT for this!)
    "Subaru says the traction control system is less invasive than most, allowing the AWD to work first, and only then will it interfere."
    I hope you're right. Maybe Patti can get some info on VDC performance on sand.
    Tom
    The new A4 will be priced a bit higher, too. I think the 1.8T already makes 170hp and they're using a new V6 engine for the 220 horses.
    I like the look of the Passat, though I like the old one just as much. The nose looks a little droopy, but not ugly. The rear lights look odd, but I'll get used to it.
    I guess I didn't finish reading Edmunds' coverage, Drew. 180hp sounds good in such a light vehicle. Still has that torsion beam (non-independent) rear end, though.
    Tom: that info came from the early press releases. I hope so, too.
    -juice
  • brekkebrekke Member Posts: 304
    If the non-WRX new imprezas are gaining 300lbs will that negate the extra hp? I've heard more than one person say the current OBS is underpowered. And what is the diff between SOHC and DOHC? I know what it stands for but not what it means. The non WRX imprezas are SOHC? I don't need a superfast car, but I'd like a small wagon that can hustle when I want it to. I also hear a lot of people say "I don't need AWD and I don't want to carry the extra weight" but don't the advantages of AWD outweigh the disadvantages? Sigh, I'm spending WAY too much time in these forums...Too many questions, too little brains.
    Caroline
  • locke2clocke2c Member Posts: 5,038
    Absolutely. The OBS will have the 2.5L now but I doubt the 2.5L will see a power upgrade, or at least not one sufficient to offset the 250lb weight gain.
    The same thing happened to the 2000 Legacy and Outback.
    -Colin
    I think the 2.5l will more than make up for the extra weight. 23 extra horsepower.
    The current 2.5l (Phase II) is SOHC, which means it has one camshaft per bank of cylinders, or 2 total with the boxer configuration. That cam controls both intake and exhaust valves.
    The turbos and older 2.5l engines (Phase I) are DOHC. They have two camshafts per bank of cylinders, or 4 cams total. One cam controls the intake valves, the other the exhaust valves.
    The DOHC design typically allows for more precise valve control, higher redlines, and good peak horsepower.
    SOHC is simpler, cheaper, and makes its power lower in the rev range.
    Do you need AWD? Well, what kind of weather do you drive in? Any dirt or gravel trails? FWD is adequate for most people, AWD is just sweet, though.
    -juice
    weigh only 2900lbs. a few more lbs than the current models. It's teh WRX that is over 3000lbs. So I doubt there's any performance loss....at least not significant.
  • miksmimiksmi Member Posts: 1,246
    Re: #636 Geezer?! :D Busted by WDB!
    Re: WMarton Jan 23, 2001 8:47am
    > ..my height adjustable rear-view mirror.. Does anyone else have this pet peeve or am I only one?
    Bill, its one of my many human factors engineering peeves. Way behind the cup holder though. Seriously, a height adjustable rear-view mirror is a good safety feature and why I made the joke. Automotive ergonomics have much room for improvement. The good news is these features will, once produced in economies of scale, make automobiles more usable for those with some types of disabilities, e.g., range of motion.
    The adjustable pedals in the Ford Taurus for those with *gasp* outlier leg dimensions are another good Ford idea. (limit discussion to Ford design, not implementation) Bill, cost accounting [note to Graham: this is your segue] also affects design issues like your height adjustable mirror, as would other adjustable vs. fixed components, e.g., the driver's seat. Don't laugh, the Model T didn't have airbags either. Ergonomics -- think about when we started and where we are.
    ..Mike
    ..Mike
  • subaru_teamsubaru_team Member Posts: 1,676
    I'm hoping to drive a VDC in a "sand" area (old SOA Volleyball court later today or tomorrow. I'll let you know how it goes. However, I did drive it on a wet, soap covered plastic sheet during a test. The only time the VDC kicked in was when I tried extreme moves (swerving/jamming on the brakes, etc.). Since the first system to check an out of control situation is a cut back in the fuel injectors, I can't see it as a big concern with the brakes. On the sand, I can't see gunning it to 60 MPH and pulling the steering wheel all the way to one side without easing off the fuel.
    I'll let you know how it goes as soon as I try it.
    Patti
    I think Drew was concerned that the VDC would activate the brakes when traveling in or actually stuck in loose sand. I'm not going to ask you to go out and get yourself stuck but.. Anyway it's the low-end torque, stuck situation rather than a high speed out of control one I am worried about. Thanks.
    Tom
    Cool, so the VDC cuts engine power and uses the brakes. Better systems use both strategies.
    I can't seem to find a curb weight for the new OBS, but the WRX wagon weighs 3165 lbs, so let's estimate about 3000 lbs for the OBS.
    So we'd have:
    2001 OBS = 2835 lbs / 142 hp = 20.0 lbs/hp
    2002 OBS = 3000 lbs / 165 hp = 18.2 lbs/hp
    Which is about a 10% improvement. Not bad. Other factors like gearing come into play, but let's assume those will be similar.
    Even if the OBS weighs as much as the WRX wagon does, it's still only carrying 19 lbs/hp or so, still a 5% improvement in the power/weight ratio.
    -juice
    Alwin, where have you seen an OFFICIAL curb weight on the 2002 2.5RS? I have *heard* that it is only 2900lb, but even if used an aluminum hood (like the WRX, but sans scoop) I have trouble believing that.
    However if it is true-- Subaru's wet curb weights are very accurate, unlike some other brands-- then a 2002 2.5RS would handle much better thanks to the vastly improved chassis.
    -Colin
    In Post #454 of the Highlander SUV Forum a test driver already ran into the situation I'm worried about on the VDC:
    "the traction-control system (which limits wheel spin by braking wheels individually or adjusting braking pressure - can't be turned off) didn't allow us to move forward because one of the front wheels kept spinning. The poor salesman didn't even mind helping to push the vehicle out!"
    This was in a snow situation.
    Tom
    If the WRX wagon weighs 3160 lbs, it's hard to imagine the RS would weigh 2900. The WRX doesn't even have the sunroof.
    That's the 2nd complaint of the Highlander's traction. The other was that review.
    Maybe they should hire Subaru engineers! :p
    -juice
    where you "heard" it. - the iclub. 8-)
    I don't doubt it considering it has less accessories compared to the WRX. So 100lbs less is quite believeble.
    will be lighter for the simple facts:
    VTD may be a heavier unit
    Less sound deadening material (which is pretty heavy)
    no turbo unit and associated piping
    lighter seats
    lighter suspension components
    -mike
    WRX also has side airbags and the CD player, which the OBS probably won't.
    -juice
  • p0926p0926 Member Posts: 4,423
    Local paper recently had reviews of both. The reviewer gushed about how wonderful the 4-Motion was and what a bargain it was in spite of it's 30k + price tag. Same reviewer was lukewarm about the LL Bean, nothing real negative but nothing positive either. So when did VW get this great up-scale image anyway?
    -Frank P.
    Actually, VW's marketing was ingenious. Allow me to elaborate.
    Remember the Da-da-da commercial? It came out just before the New Beetle did, and brought attention to VW even though its products were ancient and outdated.
    I'm not kidding - they won all kinds of awards from Advertising Age, which rarely awards the auto industry at all.
    The timing was perfect. The New Beetle came out, drawing crowds to the dealers. Then the new Golf, Jetta, and Passat, once those folks realized the Beetle wasn't very practical.
    Note that their prices are much higher than preceeding models, though sales are up (sounds like Subaru, no?).
    Those higher prices positioned VW as a higher-priced alternative to the Hondas and Toyotas of the world. So people started seeing VW as upscale - you pay more and get a little more too.
    The catch with Subaru is that VW had built a better bridge. Passat V6 GLXs were already priced in the high 20's, so 30k for the 4Motion didn't seem so bad.
    Even Outback Limiteds like my dad's cost only $25k, and that's about as high as Subaru had gone (since the SVX). So $32k for a VDC seemed like a huge jump, even though in the real world you can get an LL Bean for about $2k more than my dad paid.
    -juice
    from a Toyota salesman from Springfield, VA., posting in the Highlander forum.
    Bob
    cliffy1 "TOYOTA HIGHLANDER SUV" Jan 24, 2001 10:44am
  • theobtheob Member Posts: 148
    Boy am I glad I'm getting a VDC and didn't wait for the HL! Sounds to me like Toyota kinda missed it on that one. When I get my VDC next week, I'll have to ice down part of my driveway to prove that it will climb with just one front wheel getting traction.
    Hey Patti, WDYT? Will I be let down or shall we take some video to prove that the VTD works as advertised?
    Theo
    Doesn't the VDC have the center LSD too?
    -juice
    "The HL has a limited slip center differential and open front and rear differentials."
    The only specs I can find say the 2001 Outbacks have the Limited Slip only in the rear axle. Why and whether this makes a difference I have no idea.
    Bob - Thanks for the link.
    Theo - Waiting on test results.
    Tom
  • FrankMcFrankMc Member Posts: 228
    of movable pedals. My wife is short and would like to be able to sit a little further back from the steering wheel now that she has been informed that you shouldn't sit too closely to air bags. With movable pedals she would be able to sit at the distance that the safety experts recommend for airbags.
    Tom: all Outbacks except the VDC have the rear viscous LSD. The VDC lets the traction control do that job.
    I think it does have a limited slip center diffy, but I think they allow it to act before the traction control kicks in.
    -juice
  • bluesubiebluesubie Member Posts: 3,497
    It probably won't be long before a magazine does this comparison. The Forester and OB have performed excellent in some comparisons vs. other AWD & 4WD vehicles in the past few years.
    Patti - To really test the VDC in sand, try to take it to the beach. You can go to Island Beach State Park and get a 3 day pass for $25. I'm sure you could convince your management to let you test it. :-) Then again, you're closer to the Pine Barrens.
    Dennis
    My 2 cents - don't ask. It's much easier to apologize then to get permission.
    In any vehicle, driving in the sand it messy. Your undercarriage will get filthy with salt and sand, so make sure you wash it thoroughly.
    I had to do that twice!
    -juice
  • kenskens Member Posts: 5,869
    juice,
    In the case of the VDC wagon, isn't it the planetary gears of the VTD AWD system that 'act' as the limited slip center differential? Same thing for the Active AWD system with it's clutch pack. With our MT vehicles, it's the viscous coupling that acts as the center LSD.
    Ken
    Frank M- In addition to moveable pedals allowing shorter drivers to sit farther back, I believe that all new cars come with 2nd generation "de-powered" airbags that are not as dangerous to vertically challenged individuals.
    -Frank P.
    Ken: must be. I specifically remember Subaru stating that it allows the AWD to do its work first, then and only then is the traction control used. It would be interesting to read more about this, though.
    Frank - Soobs already do. Even my '98 Forester has de-powered bags.
    -juice
    Yiippppeee! It worked great. We went from dry land, through a really muddy section and onto the sand. The VDC lamp did flash (indicating that the VDC was kicking in), but nothing was felt. No change in performance, noise, or lack of traction. We tried a few different situations (fast, slow, turning, reverse, etc.) One thing I had noticed when we were testing it out on the soapy plastic sheet, it got a bit noisy when we were trying to get it to go out of control. On the sand, it wasn't at all noticeable. In fact, if the light didn't come on, I wouldn't have thought it had engaged.
    So, there's my opinion. I'll see if I can get a more technical explanation soon!
    Patti
    That's cool.
    Sometimes a real world spin (poor choice of words perhaps?) tells you more than any brochure.
    -juice
    Did you stop in the sand at all? and get really dug in? how soft was the sand? I think those factors would make a big difference.
    -mike
    that SOJ has just introduced "another" twin-turbo, 2.0 DOHC Legacy wagon. Not sure, other than the visuals, how it differs from the Blitzen?
    Ken—do you have any idea if they differ mechanically? I think(?) this latest version comes only with the automatic(?).
    Bob
    http://www.subaru.co.jp/
    Did someone call? :-)
    This one's kind of cool! It's a Legacy GT Limited Touring Wagon:
    http://202.217.201.209/showroom/leg_gtl/
    It's not quite as loaded as the RSK, but it has:
    VTD w/rear LSD
    4EAT (no manual -- whassup with that?)
    2.0 DOHC twin stage Turbo (260ps@6000, 32.5N-m@5000)
    Ken
    generally have automatics
    SVX...
    -mike
  • drew_drew_ Member Posts: 3,382
    Seems to me that strangely, Cliffy doesn't seem to know what a limited slip centre differential is and does. I think he also doesn't realise that traction control is simply a component of stability control. Stability control = 4 wheel traction control (brakes + engine torque reduction) + yaw control. Toyota's VSC works the same way on the Sequoia or the Highlander (or the 4Runner for that matter).
    The RX300's and Highlander's viscous coupling is still open and without the traction control system, all of the power could leak out to one axle. MB showed this at their Powertrip event last year on the ramp test (simulating a slippery boat launch or driveway). The AWD RX300 got stuck at the bottom of the ramp since it simply spun its front wheels when they were on the rollers and absolutely no power went to the rear wheels.
    To me, It's quite obvious what happened. This particular person who went on the test drive simply ventured to far into the snow. The traction control system did work, braking the slipping wheels. However, the one wheel (that was spinning) simply did not have enough power or traction to pull the vehicle out of the deep snow. THAT is why it was stuck. This is also where the off switch comes in handy. By deactivating the system (or at least most of its functionality), one can spin all four wheels at at least try to power one's way out of the snow by rocking back and forth. On a related note, I still think Subaru should consider adding an off switch for these situations on snow/sand just in case. IMHO, Toyota's 4 wheel traction control system does not seem to be quite as good as the MB/Continental-Teves system.
    Drew
    Vans and Aftermarket & Accessories message boards
    Drew, please join us next week for a chat.
    ..Mike
    ..Mike
    Ugh, I completely forgot! Sorry! And I arrived home shortly before the chat started too! Grrr...To kind of make up for it, how about joining me tomorrow in the Friday's Freeways chat at 5-6pm Pacific?
    Drew - point noted (and reported) about the on/off switch.
    Mike, the sand was about 10"?? inches deep, and soft. After the "mudder" drive and into the sand was when the VDC light came on. We went from a dead stop into a tight turn, dead stop straight, dead stop reverse, etc. We tried every different method we could think of. I was expecting to come across something that bogged it down, but it just didn't happen. The temps. were above freezing so I couldn't take it on some ice or deep snow to compare, but maybe next time we get some foul weather, I'll try that.
    Patti
    Just wanted to make sure it had a chance to get stuck before we went blowing sunshine up our own dresses! :)
    -mike
    Patti - Thanks a million for going to the trouble to go out and perform that test and for the info. I hope Subaru appreciates the job you are doing.
    Mike - excellent questions.
    Tom
    Re: WMarton Jan 23, 2001 8:47am miksmi Jan 23, 2001 9:54pm and FrankMc Jan 25, 2001 5:45am
    FrankMc, Thanks, thought WMarton and I were the only ones. How ya been?
    Patti, sounds like your job isn't much fun. Sorry to hear that.
    Tom, agreed. Patti... ROCKS! (oops)
    Drew, I think I can do join tonight. 5-6pm PT = 8-9pm ET. 8pm ET is tight but I'll get the kids to bed on time and join. Getting them to bed is harder than debugging a multi-threaded C++ app. You'll have a Emunds_Moderator handle? If so and possible, please note that you're Drew or something in the profile. Dana forgets/can't do that and it hurts my Lilliputian brain.
    ..Mike
    ..Mike
    I wanted to share this with you all since I've had a Subaru VDC on order for the last 4 1/2 months.
    Last night I test drove a Toyota Highlander V6 and immediately went to test drive a Bean-Mobile (no VDC available). My back was killing me. Good time for a test drive.
    First, my wife and daughter prefer the HL because of the extra room & seating. It's like a minivan with an SUV body. My wife loved the passenger seat. I thought the driver's seat felt hard. The seats were cloth. The stereo sounded great and the climate control worked well. The moonroof is huge.
    The HL pulled out from a stop with plenty of power. It cornered like the tall SUV it is and though it held the road well you could feel it tilt when pushed.
    The best way I can describe the ride is the way Healey of USA Today described it - "busy". As soon as we hit a stretch of road with expansion joints you could feel a series of high frequency bounces or vibrations that in the hard seat really bothered my back. On the highway the HL was smooth & quiet w/plenty of power. It absorbed big bumps well.
    The sales people were friendly, courteous & not pushy.
    The LLB felt like the sporty car it is with enough room but just enough. The moonroofs are just big enough to see out. I liked the climate control but the stereo seemed chincy when pushed.
    The leather seat was comfortable and got so hot after a while I had to turn it off. My wife thought the passenger seat sat too low. There's no reason to have split rear seat backs w/the traditional bench seat. Subaru needs to split that seat as well.
    The H6 pulled out with even more power than the HL I guess because of the lighter weight. It handled & cornered beautifully. I liked the gated shifter.
    You could feel bumps in the road. In fact our voices would vibrate as we talked but for some reason the LLB absorbed the bumps better & didn't bother my back as much. I think I'd rather have the H6 on a long drive. I know others haven't felt that way but I don't know if they had the leather seats. On the highway it was powerful, quiet & smooth w/no vibrations over expansion joints.
    When we got to the Subaru dealer the salesman acted like we were putting him out. He knew I had spoken to another salesman previously so he acted like we were being a pain when we asked for a test drive. He had to go inside a get a jumper kit to get the LLB started. The Subaru salespeople I've dealt with seem like they couldn't care less whether they sell these cars or not. I've had a VDC on order for almost 5 months from the next closest dealer. Time to shop elsewhere.
    Bottom line - Neither car was as jarring as the Pathfinder we're driving now. Even though my wife likes the utilitarian HL w/it's extra room I'm ready for the car-like H6 for every day driving. The bouncy hard seats in the HL killed my back.
    Tom
  • scarwafscarwaf Member Posts: 33
    For those of you who missed my report on my vdc please go back to mgs #606 thank you Bob
  • aakersonaakerson Member Posts: 71
    Our dealer called tonight; the DC we ordered for my wife only about four weeks ago is in; we pick it up tomorrow. Got here much quicken than the six or eight or 10 weeks or whatever that he had predicted.
    Tom -- sorry to hear about your Subaru ordering and dealer test-drive experience. Wish that Subaru could get strong enough that it could take on some of these dumb dealerships. We deal with a suburban St. Louts independent dealer(he has one store, sells primarily Subaru plus Isuzu and Suzuki) and he's been great through the years. Whenever anyone asks why I'm a total Subaru disciple, I tell em simply -- great car and a really good dealership to work with. As I've mentioned before here, I also had a BMW for three years (company lease) and the quality of Subaru service far exceeded the Beemer dealers. Unfortunately, to my knowledge, our Subaru dealer has not launched any kind of serious interned sales effort yet.
    Thanks much for your Highlander/H6 compare. I will admit the AL caught my eye when it started popping up on dealer lots. The more I read and hear, the more convinced than ever I am about the choice of the DC. The best news in your comments, from my wife's perspective, is that the bun warmers got so hot you had to turn them off.
    Amen. Oddly, Australia and IIRC New Zealand get the split squab/base and split back. Cost cutting for North America? Don't know. Patti, another request?
    Tom, Bob, thanks for your reports -- you guys are the trailblazers. Hats off!
    Ken, At Thursday's chat, you rekindled my hope for a turbocharged MT Legacy platform so I poked around SoJ. Found this nifty Equipment & Specificatios table; note two pull-downs in upper right. I don't have a specific question for you; just thought I'd toss it out in case you hadn't seen it.
    Note to Subaru of America:
    The SoJ site has significantly more accessible information and less content-free eye candy than the SoA site. The New Zealand (thanks WDB) and Australian sites, though in English, also lack the technical depth of SoJ.
    /rant on
    Seems like each country likes to re-invent the entire website.
    /jest on
    Never seen the IT group of a large regional company re-invent the wheel or develop fiefdoms, much less an international one; how odd.
    /jest off
    Yes, I'm ignoring the minor model name differences and feature quirks but much is applicable to all countries. It's a shame it's not re-used.
    /rant off
    Or translated to English. :p
    So the 2.0l twin-turbo Legacy GT-B E-tune wagon, model GF-BH5, is available with 5MT. Nifty. Any other goodies tucked away in the tables accessible from the pull-downs? Now if this makes it to North America, I'll be one happy camper. Make it so, Number One.
    ..Mike
    ..Mike
    Right On! (Or is it... "Write On"?)
    Mike- Thanks for the SOJ link, but they're... USELESS!
    Will we ever get a "English" version of the SOJ site?
    As more and more people access the Internet, you would think SOJ would offer a direct English translation of their site—if for no other reason that English is the number one "World" language.
    Subaru of Canada offers their site in both English and French. So, come on SOJ—get with the program!
    Bob
    Mike,
    The webpage you posted is exactly the one I was using to look up specs during the chat. If you could read Japanese ;-) , you'll notice that each of the two pull downs give you subcategories. For example, the "Equipment" pull down translates to:
    4WD System
    Suspension
    Lighting
    Controls
    Audio
    Seats
    Interior
    Exterior
    Saftey Features
    Table of options
    The "Specifications" pull down shows:
    Dimensions & weight
    Turning Radius/Fuel Economy
    Steering
    Suspension
    Brakes
    Engine
    Gearing
    Diagrams
    Low Emissions Compliance
    Happy surfin'!
    Ken
