2023 Hyundai Palisade Lease Deals and Prices
1567911
  • darkkmanodarkkmano Member Posts: 14
    Can I have the MF and RV for a 2023 AWD Limited and Caligraphy? Looking at both 36/12 and 36/10 values, zip code is 01701. MSRP is $51,490 for the Limited and $53,885 for the Caligraphy.
  • MichaellMichaell Moderator Posts: 265,315
    .00248 MF
    57% RV
    Either model
  • jkraebeljkraebel Member Posts: 30
    Can I please have the MF, residual, and incentives of the 2023 Pallisade AWD Calligraphy for 36 mo lease/10k miles for zip 11901.
    .00248 and 58%
  • bulion33bulion33 Member Posts: 10
    Can you please provide the MF, RV and any incentives on XRT for 36/12 and 36/15 in 92782? Mahalo!
  • kyfdxkyfdx Moderator Posts: 268,108
    FWD or AWD?
    Sorry, FWD
    bulion33 said:
    Sorry, FWD
    .00248 MF and 57% residual
  • chawkskichawkski Member Posts: 10
    Hi there. Looking for residual and MF on a Palisade SE AWD, in 80210 for 12/36. Thank you!
    .00248 MF and 62% residual
  • FuzzyPantsFuzzyPants Member Posts: 1
    Hello, May I please have MF, RV, and incentives for a 2023 Palisade Calligraphy AWD. 36 months / 10 k(or less), zip code : 78660,
    edited May 2023
    .00248 MF and 58% RV
    Hi again. These numbers the same for the SEL trim ? Thank you!
    .00248 and 60%
  • fred45fred45 Member Posts: 4
    Hello. I am looking for the MF, RV, and any incentives on a 2023 Palisade SEL AWD 36/12, 23464. Thank you.
    .00248 MF and 60% residual
  • Enriquenunez03Enriquenunez03 Member Posts: 4
    Could I please get the RV, MF and any incentives for 2023 Palisade SEL AWD for zip code 33165
    24/10k, 36/10k, and 48/10k or whatever other monthly term exists with 10k miles.
    36 - .00248 MF and 61% RV
    39 - .00248 MF and 58% RV
    42 - .00264 MF and 56% RV
    48 - .00264 MF and 51% RV
    No 24 month term
  • DannyAlvarezDannyAlvarez Member Posts: 7
    Here are the numbers I received from my local dealer Paramus Hyundai in NJ for the 2023 Hyundai Palisade Calligraphy AWD
    36/15k
    $7000 down
    $983 a month
    the said credit was bad so money factor was 0.00385
    They said Edmunds Lease Calculator was wrong so I should take this deal.
    36/15k
    $7000 down
    $983 a month
    I would definitely shop around.
    You should verify your credit score, before you make any deals.
  • jese9jese9 Member Posts: 25
    edited May 2023
    Hi, what are the current Residual, MF and incentives, if any, for a 36/15 lease on a 2023 Hyundai Palisade FWD Limited and Calligraphy in 85296. Thank you!
    .00248 and 54%
    Either trim
  • acuratlx2016txacuratlx2016tx Member Posts: 9
    Hello! Can I please have the MF, RV, etc for a PALISADE SEL FWD, for 12k, 36M lease? Zip Code 77433
    .00248 MF and 59% RV
  • TastyhouseTastyhouse Member Posts: 1
    Hi - can I please have the MF, RV for a Palisade Calligraphy AWD 36/10. Zip Code is 19426. Thanks!
    .00248 MF and 58% residual
    Could I get these for June please? Thanks!
    36/39
    .00241 MF and 61%/58% residual
    42/48
    .00264 MF and 56%/51% residual
  • BinaryNimbusBinaryNimbus Member Posts: 2
    Hello all,
    Looking for residual and MF on a 2023 Palisade Calligraphy AWD, in 03062 for 12/36 and 10/36. Thank you!
    Hello all,
  • banditelvis721banditelvis721 Member Posts: 11
    Hi Looking For Hyundai Palisades AWD Caligraphy 36/10 zip 11563 MF and RV and incentives.
    ty so much
    ty so much
    A local dealer is reporting a rate of 6.9 which is a full point higher than this MF, and I have excellent credit. Are local rates highly variable?
    The dealer can mark up the MF by .00040, which equates to 1%.
  • PwnPwn Member Posts: 6
    RV/MF palisade SEL AWD 36/12 10305
    .00248 MF and 60% RV
  • deweydog78deweydog78 Member Posts: 18
    Hello, could I please have MF and residual for zip 84095 for an SEL w/ premium for both 12k and 15k miles? Thanks!
    FWD or AWD?
    FWD or AWD?
    AWD, sorry about that. Thanks!
    FWD or AWD?
    Thanks! Do you have the same for 12k?
    I appreciate it.
    I appreciate it.
    60% residual for 12K
  • farhan583farhan583 Member Posts: 1
    HI, was looking for Palisade AWD Calligraphy 36/10 75063 MF and RV along with 36/12. Thanks!
    .00248 MF and 57% RV
  • ford1431ford1431 Member Posts: 6
    May I please have the MF and residual value for a 2023 Palisade SEL Convenience + Premium AWD for both 10k/36 months and 10k/39 months? Zip code 10036. Thank you!
    .00248 MF
    61% / 58% residual for 36/39 and 10K
  • renaissanceturtlerenaissanceturtle Member Posts: 4
    Can I please have the MF, residual, and incentives of the 2023 Pallisade AWD Calligraphy for 36 mo lease/10k miles and 12k miles for zip 60630.
  • DonnieBravvoDonnieBravvo Member Posts: 20
    Can I get the RV and MF for a Palisade XRT FWD and SEL FWD
    36/12k
    zip 32789
    36/12k
    zip 32789
    Either trim
