Visitor Agreement.
I used to know a trusted mechanic like that. Complaining wife and all. Seems like the older he got the better he could handle it.
I can too, but the hardwired nodes yield more than twice the speed of the all wireless.
Here is a speed test connected to a hardwired node
Here is upstairs, same distance away from node but all wireless.
How did he get it back to the dealer? I hope he didn’t fill it back up with oil. Regardless, that engine would be toast after even a few miles of driving without oil.
Oh, I’m sure. But, like I said, what would I use the extra speed for?
As part of the string of apologies they said that he should drive it for a while and if anything crops up, that he should bring it back and they would make it good. He seemed fairly satisfied by their response, not trying to deny anything or evade responsibility. We will see.
Talking service….
When I picked up the EQE the person detailing it accidentally destroyed one of the key fobs. Dealer ordered one and overnighted it to me. Of course it needs to be programmed. I’m not driving 3 hours to get it done, so they made arrangements for the local dealer to do it for me. Earliest appointment 12/5. I hope I really don’t need service!
True anything over 100 is still very robust. I guess I’m acting like a car guy and more power is always better lol
And the person that told him to “bring it back” should have gone out the door with the guy who didn’t put any oil in.
That shop is totally incompetent. Although they were honest enough to admit it was their fault. Apologies wouldn’t satisfy me. Only a crate engine would do that.
Would you trust that engine if you were going on vacation?
Did the detail guy step on the fob or drop it in a bucket of water?
I’d say he stepped on it
As far as extended warranties are concerned I think the average one pays out less than 20% of the cost of the warranty. So odds are very good that you would be better off putting the money in the bank. But if it makes you sleep better at night go for it.
As long as you are able to get what you want (movies TV videos and music) without buffering more speed is pretty useless.
Somehow I think that they might follow through with the promise since they would lose a court case if sued over it if it is a provable fact that they didn't put the oil in.
so if you are OK with paying OOP for the worst case, makes no sense to get it. Same with life insurance. If whoever is left behind has plenty of money to bury you and live on, don't really need it.
caveat though, if you are buying a used Range Rover, you have to have one.
I disagree. I work from home and often have large construction docs sets (1GB+) and without a robust connection they take a long time to DL. I noticed a huge improvement when moving to a mesh system with a hard wired node near my office
Anyone a Chris Stapleton fan?
https://www.roadandtrack.com/news/g41901842/2023-ram-2500-traveller-full-image-gallery/
Incredible upload speeds, wow
what a poor design. had to use the push pin extractor tool I bought (along with 200 pins of various types and some trim removal tools) to pop 2 pins out (one came out, the one I broke last time had to get busted out). Then pull the air tube off, which was wedged on tight and felt like it was attached, so hard to make yourself yank it that hard! but it came off. Then had to undue for screws buried low on the airbox itself (and of course in my socket kit, could not find the 8mm so had to use a screwdriver). Then pull the top up, which was buried under some wires so had to be twisted around a bit to finally have enough space to yank the air filter out.
by this point I had tools and parts spread all over the bed cover of my truck that I was using as a workbench. All for a simple air filter replacement. Thankfully the bottom of the filter was pretty black and nasty looking. I would have really been annoyed to do all this work and have the filter look perfectly fine.
next time, a 10 minute job with many fewer tools pulled out. Or I will sell the car by then instead.
Geeez, all that finagling for an air filter. How much would you have been willingly to pay “a guy” to do that?
Maybe next time just let the car pass out from air starvation before changing the filter.
I bought this a few years ago on Ebay. It wasn’t very expensive and it works really well. I generally add air at our local gas station but recently it has been out of order. The wife is traveling to her parents tomorrow. I did a quick car inspection, check oil, tires, etc. The tires were uniformly down about 2 lbs, so I added air. This tire inflator is nice to have when needed.
Take two..
Before he became ill he likely would have been much more insistent.
I never thought about the consequences of snuffing out a few mice.
I was directing that question to you but I’ll take that as a NO.
I meant to ask at the last
Oil change but forgot. Surprisingly they did
Not come out to upsell. If they told me $50 I likely would have said do it. Filter was in the $20 range I think.
What brought that on? I was talking to you.
They had to replace the engine. It didn't make it.
And, yes. I knew better.
Your friend probably doesn't feel up to it but I'd be concerned about their verbal assurances. On Judge Judy verbal agreements are hard to enforce unless their is some proof. As time goes by it will be harder for him to prove if he does have a problem. I'd want it in writing and it would have been nice to have a copy of the video. The dealer seems to be honest and is trying.....but I have heard of engines seizing pretty quickly when their is no oil in them. Sometimes, by the time the light comes on it is too late.
with seizing, if it did not happen already, probably safe. Especially if they checked the oil filter and no metal pieces in there.
I thought your initial post said there was oil on the dipstick but maybe just a little? So it was low but not empty. If it really had no oil he would not have made it home.
24 years later it's still running great.
How was lunch? Lovely. Did you get gas? No, too tired. And, I'm going to the gym Monday morning, ~30 mile round trip. How much gas do you have left? Ummm...
She'll go to the gym tonight, I'll get her gas at noon time.
The struggle is real.
My wife will fill up the X1 herself or else let me know when the range drops below 100 miles.
That’s why folks need more than one EV in the garage. I always try to have a back up. Kinda explains why I have 4 battery powered drills each with 2 batteries.
I was lucky if my wife remembered to tell me the light came on. Back when she drove a lot more. Then I would lecture about giving earlier notice. At least she never ran out. Now she barely drives so I always know where the gauge is.
Even in Jersey she just told me she needed gas and I got it. And that was where they only have full service. Up here in self serve land zero chance she is stopping for gas if she has to put it in. Would have to be a real emergency.
BJs PUG with my discount, $3.71/gal. Good to be sub $4 again.
Gave the A7 a long charge, showing 29 miles of range. Which is the furthest I've noted going on electrons only. Doubt highly I'd get that, unless going downhill, coasting with a tailwind for a good portion of the travels. But, still think it's cool.
Somehow Mrs. j never had a problem putting in gas but she could never figure out how to pop the hood to refill the washer fluid. I guess you could say her mechanical acumen topped out with the gas cap removal/replacement, squeezing the pump nozzle and not forgetting to take out the CC.
I suppose in an emergency she could get the hood open. Maybe. Probably not on the ford since that works oddly. But if she did would have no clue what anything was and would be afraid to touch it.
