Visitor Agreement.
Perhaps the oil you used before left behind a little bit of sludge and varnish and the mobil synthetic is just cleaning that up?
I found that when I used Castrol Syntec and then switched to something else like Mobil 1 or Valvoline Synpower, the following oil would look dark quite quickly. I tried not to let it bother me.
I suggest you get the oil analyzed if this is really bugging you. If the old oil is sitting in a container in the garage awaiting recycling, you'll have to really shake it up before taking a sample.
Or, you could merely have the NEXT next oil change's oil sampled and tested.
--- Bror Jace
BTW, who does these analysis, Pep Boys?
Ron
I really think this relates to the fact that the Jeep sits so much of the time without being driven. I am trying to drive it one day a week to work for a round trip of 54 miles of highway driving. I think I'll have the oil changed Monday, and then start checking the new oil at least once a week for color.
I will see how long it takes for the color to start getting dark next time.
tom
tsjay, I'm of the opinion that it doesn't matter how long a vehicle sits (within reason) as long as when it is finally driven, it is driven for at least 20 minutes to allow the PCV system to rid the crankcase of any accumulated moisture. So, avoid short trips if you can. If you can't, change the oil & filter a little more often.
I think it's the variations in vehicles that's the cause of your darker oil. Maybe your rings are taking longer to seat or maybe they won't seat as well as the other poster's Jeep. Annoying as that may be, it's not likely to affect the longevity of the vehicle. Just oil consumption and/or color of the oil.
--- Bror Jace
There is also a small shop just a half a mile from my house that offers a similar deal.
In either of these places, you are allowed to hang out right there with the guy doing the work and "supervise."
I am putting so few miles on the Jeep now that my 5K oil change interval would be probably nine months or more. I know lots of you guys in here go a year on oil changes with synthetic, but apparently you are not seeing the oil get as dark as mine has.
I will spend a few bucks and have the oil changed tomorrow and then will pay close attention to the change in color as time goes by on the next cycle.
The peace of mind will be worth the money I spend on an oil change. I can get six quarts of Mobil 1 and a good filter for about $35 and spend another $6 to have it changed.
I am so grateful to all of you guys who have taken time to respond, and I will definitely keep all of you posted on how things are progressing during that next cycle.
thanks to all of you
tom
I also want to thank all of you who have provided great info on the different types of oil and on oil change frequency.
I especially thank all of you who have responded to my recent questions about the oil in my Jeep.
May your oil stay slippery and clean!
tom
Yes, you can mix the two oils. We don't recommend mixing two different
brands of oils or two different oil viscosities. For more information,
please call our technical hotline at 1-800-254-8957.
I don't see how mixing Maxlife with MobileOne falls within the oil recommendations.
When I sent the oil in for Analysis, QS syn blend, it was much blacker than I had ever imagined. However, the analysis showed that it was still in excellent shape.
So color alone is not an indication of a problem.
dave
Old wives tales they said about not mixing.
They also said all api graded oils were the same.
people do not like to hear that
Anyway, the guy I talked to on their 800 line a year ago was very knowledgeable (probably a chemist ... he knew what PAO was) and he should know if the two oils have additive packages which might interfere with each other.
Of course, what he may be allowed to say might still be dominated by a bunch of CYA nonsense. I'd like to think there are a few companies that are immune to this ... but I'm probably just kidding myself. <:^(
--- <b>Bror Jace
The problem started this fall, with the first morning frosts in October, at about 45K miles.
The first time I did not expected this and it was really dangerous: I had to make left turn across a street from driveway, and to merge into traffic in a place with bad visibility, between two small hill tops on the street. And the car crawled, not moved.
Today it was about 23F / -5C outside. When I glanced on the instruments they show 3,000 rpm at 10 mph; after the first 100 yards or so rpm switched to something like 2500 rpm, while the speed increased to 15, than 20 mph. I moved uphill, so the second set of parameters would be more or less normal for starting, while the start was unusually slow.
I believe, this behaviour is related to transmission or to its electronic controls. Probably it does not shift from the 1-st gear for too long when it is cold.
The last winter the car used to stick on the second gear when starting in frost, but not on the 1-st one.
The car had transmission service in May, at 40K miles. Mobil-1 synthetic ATF liquid, and the $80 Delco transmission filter.
Uses Mobil-1 5W-30 engine oil, and Pure One filter. So I do not expect problems in this department.
With the vast majority of those here, I remain unconvinced if you want to do it.
I definitely bought 15 quarts of Mobil 1 ATF at Pep Boys, brought the liquid for transmission service, and the shop returned one box (6 quarts) still packed.
I am servicing my cars at the shop for 5.5 years. This is a reputable shop, recommended by AAA. I like the owner, and have absolutely no reason to suspect anything unproper.
Any case, I thought it must not happens with natural oil based ATF either. Previousely the car used to stick on the 2-nd gear till warmed, but never stick on the 1-st gear.
However, I called the Chevy dealer today, and a very experienced service adviser told me this is normal for such a weather.
My wife pointed that it is the first winter without snow nor icing. Previously we used to clean the car from ice/snow in cold mornings, with working engine, till the windshield and windows became clear, and when we started to move, the car usually was warm already.
Additionally, we moved recently. Currently we are driving up a step hill for the first hundreds yards, while previousely the terrains were more or less flat, even a bit downhill.
In the future I will warm the car and will put it for minute or two on the neitral gear before driving, when it is cold. Or possibly even will buy a remote starter...
Leave it in until either the vehicle tells you its time for an oil change or 3000 miles, whichever comes first.
When asked about changing the oil in order to flush out engine shavings before 3000 miles I was told that is no longer a concern with GM vehicles as the engine has been flushed out (along with shavings) before it was installed.
Also was told that the original oil is nothing special. Just 5w-30 special weight.
Wait 3000 miles until you use any synthetic brand.
If you have any doubts contact your service manager. Don't take what you may have read on the net as gospel. A little common sense will go a long way.
It is true though that they did switch to Mobil 1 synthetic in 1992 with the LT-1 engine in order to get rid of the oil cooler. People race vettes, thats why it is needed, not because it is H.O. or high revving (it doesn't need to be!)
Yes, Mobil has been advertising for years now that their Mobil 1 has been the factory fill in Chevy Corvette, Porsche, Volvo, Aston Martin, Mercedes AMG, and possibly others.
--- Bror Jace
But Hydrocracked oils don't have as good of a cold temp start. -37 degrees centigrade instead of over -55. But that's a heck of a lot colder than it ever gets in my area.
I believe that you get about 75% of the synthetic oil protection at a generally much lower price.
I don't try to get extended use out of hydrocracked oils myself.
My experience with seal leakage on my current cars.
Dodge -- Conventional oil. Valve cover Leaked at 115,000, and 165K. Replaced with new valve cover as per TSB hopefully it will last longer. Will stay with conventional since recent oil analysis showed that it was working just fine and I only want it to last for another 30K.
Subaru -- Blended oil until 18 months ago, converted to synthetic. camcover and crankcase seals replaced at 90,000 (pre-conversion), and camcover gaskets at 125K. Very Hard working engine, will stick with synthetic.
Mazda -- Synthetic Blend only. Valve cover replaced at 115K, Cam and crankshaft seals, along with timing belt softened by oil leakage 120K. An expensive repair. Since I have replaced many significant seals recently,I'm converting this to Maxlife.
Most of the dino oil on the shelf passes SL/ILSAC GF3. The synthetic still seems to be SJ/GF2. Is this just old stock being cleared out, or is there a reason? i.e. Mobil dino meets the new standard but Mobil 1 still lists old standard.
We tend to compare and contrast synthetics more than dino oils. Since all the dinos have been reformulated once in the last few years, I'm pretty sure they're all comparable. I sort of favor Valvoline (based on reputation alone) but neither I nor anyone here is really "in the tank" for one brand over another.
The discussion about synthtics has more 'meat' to it because of the different formulations and the controversial shift from PAO to hydrocracked crude.
csandste, I think the recent shift to SL classification necessitated some reformulation on every dino's part ... so you see new bottles proclaiming "new & improved". Meanwhile, only SOME of the synthetics have new labeling. I've seen new Castrol, new Valvoline, etc ... but not all. I don't think I've seen a new Mobil 1 bottle yet.
--- Bror Jace
between the sh,sj,sl oils.
http://www.bobistheoilguy.com/currentapitest.htm#SJ
GF-3 oils must pass stiff tests in a number of areas that relate to better mileage and engine protection.
Volatility Cold-temperature gellation Foaming tendency High-temperature / high shear-rate viscosity Filterability Fuel efficiency Catalyst compatibility Low-temperature viscosity
gf2 oils were in fact a step down from a gf1 oil. so the gf3 is now suppose to be better than the old gf1 and of course the gf2 oils in respect to oxidation,antifoam,and such.
bobistheoilguy
I got in a bit of a discussion in the Elantra GT thread. A buyer's mother was going to change her oil at 1K or thereabouts. I stated that modern engines don't need a change at that mileage (no mention in the manual--regular interval) because:
1. there's no such thing as break-in oil and
2. modern engines don't have pieces of metal floating around in them.
I was challenged on the second point. Comments?
Is this oil hydrocracked? Any experience with it?
Before I knew this I changed the oil in my 2000 Accord at 1,000 miles. No problems so far at 27,000 miles. Uses no oil.
QUESTION: Do you think any damage could have been done?
splashing too much and possibly too much pressure and leaking seals....don't just blow it off, may cause some problems soon
Good luck
Rando
The real reason to worry about over-filling (aside from future leaks) your crankcase is because the crankshaft turning in the oil can produce excess foaming. This foam introduced into your oiling system (instead of liquid oil) can cause oil starvation and premature wear.
It's odd that OVER filling your car can cause oil STARVATION problems, but that's the way it works.
It's fairly easy to drain just a quart or so out of your pan. Just a touch messy. I'd do just that the next time you notice it over-full and be more careful filling it from now on.
You'd think a dealership would know better ... but I've never been too impressed with dealer service. Usually competent ... but not as good as they want the customers to believe.
--- Bror Jace
