Visitor Agreement.
That even goes to show that following the manufacturer's advice, contrary to what you know in your heart to be right, (I tend to inflate my tires closer to the max) can even be downright dangerous!
Bravo!! >:^D
5W20 is best for Ford's (and Honda's) corporate goals, NOT your engine!
--- Bror Jace
My Lube manager saw a video where a 10W-30 gummed up the valves on a new Ford. It seized the engine. So I wouldn't recommend that.
This test was not on 5W-30.
For those with overhead cams and hydraulic lifters the 5W-30s extra ability to flow better really makes a difference if temperatures are in the 40s and below. Those cars have a tendency to tap until the oil warms up. I know the manufacturers say it's not a problem, but I'd still rather have it minimized.
I've also been surprized about how much easier it is to start as well using a 5W instead of a 10W.
see ya
Rando
With that said, do you recommend that i put 10W40 in my engine? Mine has 96K on the clock.
I live in Florida and its warm enough to use the 20w-50 all year long. If I lived up north I would use something else. The 20w-50 seems to be working fine.....
I used 20w50 Kendall mostly. Long live the truck!
see ya
Rando
http://cgi.latimes.com/class/highway1/yourwheels/20020313/t000018575.html
"Chevron Supreme Motor Oils SAE 5W-20, 5W-30, 10W-30, 10W-40, and 20W-50 are formulated with ISOSYN (TM) base stocks, a shear-stable viscosity index improver, and contain detergent, dispersant, wear control, antioxidant, corrosion inhibitor, and foam suppressant additives."
I'm trying to decipher that sentence; does it mean that the ISOSYN base stocks are a viscosity index improver? What does that mean?
Does anybody know anything about Chevron Supreme?
I'm wondering if Chevron Supreme has any similarities, either in composition or expected performance, to the hydrocracked 'full synthetics,' Valvoline Max-Life, etc. If so, that would make it a *huge* bargain-- I picked up a case of 10W30 at Wal-Mart for $1.09/quart.
I did notice that the 5W30 at Wal-Mart did not have the ISOSYN on the bottle (they must still have some old stock of 5W30).
That Chevron mumble jumble surely is intended to fill space and not tell the consumer anything! (:oÞ You might consider buying up some "old stock" to avoid the SL category a little longer.
I'm sure the Chevron web site explains ISOSYN somewhere, but I didn't bother to search around for it.
The "Data Sheet" page does have some useful information about the oils, such as flash point, % zinc, % phosphorous, base number, sulfated ash %, pour point, viscosity index, etc. Unfortunately, I'm not well-versed on what are good and bad numbers. Any web sites that give good explanations or baselines for these types of characteristics?
Chevron Supreme & Citgo Supergard have the highest flash points (in 5W & 10W-30) that I've found in an oil with no PAO. This means they have the highest % of hydrocracked base oil.
http://www.docs.citgo.com/msds_pi/241488.pdf
http://www.chevron.com/prodserv/nafl/auto/content/motoroils.shtm (click on MSDS)
SJ: had lower flash pts, higher % anti-wear additives
SL: higher flash pts(better against sludge/breakdown), but lower anti-wear %
Folks, does pjksr's theory in post #1220 hold water?
Recently, my quest has been to determine how good Chevron Supreme's oil is, and whether it qualifies as an ultra-cheap way to get a high-quality hydrocracked oil. A couple folks have posted bits and pieces that lend support to this idea, but I'm hoping for more...
http://www.tosco.com/internet_pub/repository/lubes/44_tn3_4.pdf
I'm not sure what effect (if any) moving to the SL standard had on ZDDP levels.
--- Bror Jace
The SL oils seem to be a genuine improvement over SJ.
--- Bror Jace
But, according to the excellent article <b>adc100 provided a link to (it was in PDF format) above, they merely increased the protection against wear and decreased the volatility and boil-off when going to SL.
I didn't see anything that suggested they were decreasing the ZDDP in SL any further. Maybe I need to read it again?
--- Bror Jace
Now what are we going to discuss here that this should end the ZDDP anti wear properties discussion?
If we want some more ZDDP we can just add a bottle of STP. But according to the article. Why would we want to add anything.
Are the SL oils comparable to the hydrocracked synths in the amount of hydrocracked in the blend?
Does this change your thinking on the Mobil-1 SL possibly having inadequate amounts of zinc?I'm still considering Amsoil,which seems to have about as good an additive package as is available,but the SLs could affect that decision.Thoughts?..TIA!
before they made that decision ...
It does look clear though that decreasing the phosphorous (taking the zinc along with it) was strictly for the health of the emissions system/catalytic converter..just looks like they started that effort back with the SJ oil.
Looks like I may need to apologize to the SL folks, and start complaining to the SJ folks!!!
and COONHOUND, we can still complain about the reduction of the ZDDP, we just have to keep in mind that we started losing it further back than we realized
The question I have is this... Will it make much difference if I use one brand then another (not at the same time). I mainly use pennzoil, but have picked up clearenced Valvoline and Mobil 1 (5qts under $10!) I was told years ago to stick with one brand, but that was for the dino stuff.
Seems like you all are over analyzing the situation. I think most cars are getting well over 100,000 miles and most people are not very anal about their maintenance. Jiffy lube every 3000-5000 miles...Am I missing something??
Constantly changing standards
Denial that Synthetic can be used for extended drains;
Addition of synthetics and hydrocracked (Highly refined) oils to standard motor oil;
Damage to the catalytic converter;
Seal leakage and swelling issues requiring expensive repairs;
Frequency of oil changes;
Engine Sludging if not drained at proper interval;
Anti-wear additives;
EPA Mileage requirements forcing move to thinner oils;
and the list goes on.
Assuming that the ZDDP levels in SL oils are the same as SJ, they still would be better because the base oil has to be made more stable.
One thing that I think, ZDDP levels aside, is that The SL standard is narrowing the gap between "conventional" oils and mass-market (PAO and hydrocracked) "synthetics". I don't see how the price difference (double to triple) can be justified much longer.
More on Monday ...
--- Bror Jace
They will probably have to bite the bullet on pricing conventional oils with only minor price increases....I don't think the big majority of folks will start buying synthetic until they have no other choice,,
see ya
Rando
The new SL GF-3 levels are a better improvement over the GF-2. Fact is, GF-2 was not as good as the old GF-1. This is no longer the case, GF-3 SL base oils are definatly a better base stock oil than its previous counter parts.
here some of the test info requirements for both sl and sj oils
http://www.bobistheoilguy.com/currentapitest.htm#SL
bob
If the car does crap out at that kind of mileage and she wants to keep it, a wreck yard engine with 100,000 miles can be had for $300-$400.
I would also look, why the engine was so low on oil? Does it have a leak, or what?
After this I would just hope that the engine was not damaged substantially.
Disclaimer: this is just a common sense suggestion. I do not know much about cars.
