2024 Land Rover Defender Lease Deals, Incentives, Rebates, and Prices
1246789
  • jcd_nycjcd_nyc Member Posts: 1
    Hello, looking for MF/RES,
    2024 Defender 110 S P300
    36/10 and 30/10
    zip 07631
  • MichaellMichaell Moderator Posts: 269,608
    36/10 and 30/10
    zip 07631
    .00298 MF
    68% / 66% for 33/36 mo, 10K
  • GeorgemaxGeorgemax Member Posts: 27
    Defender 110 S p300 & p400 X Dynamic SE
    33/36 7500miles
    Any incentives?
    zip 10305
    thank you
  • kyfdxkyfdx Moderator Posts: 273,569
    33/36 7500miles
    Any incentives?
    zip 10305
    thank you
    .00298 MF
    S P300: 69%/67% residual
    XDynSE: 65%/63% residual
    May I have the 48 month program on the p300 7500 miles as well.
    .00298 MF and 52% residual
  • robster21robster21 Member Posts: 88
    Hello- looking for RV, MF and any incentives on a 24 Defender 110 S 2.0L Gas 36/12k. Boston 02129.
    .00298 and 65%
  • bmacchiobmacchio Member Posts: 30
    Looking to order a 90 S or 110 S. What is the best value or sweet spot now in terms of residual and MF for these with 10k miles/year? Zip 92128
    Ideally I’d get a 90 x-dynamic SE with the 6 cylinder so what’s that and what is the best residual you see now?
    .00389 MF and 62% RV
    S with the 4-cylinder has an RV that is 7% higher
    110 S: .00298 MF and 66% residual
    110 XDynSE: .00298 MF and 62% residual
    90 S: .00389 MF and 66% residual
    90 XDynSE: .00389 MF and 60% residual
  • GarveymlGarveyml Member Posts: 5
    Hello- looking for RV, MF and any incentives on a 24 Defender 130 X 36/12k. 43221.
    .00127 MF and 51% residual
  • ShocknaweShocknawe Member Posts: 21
    Hello - looking for RV, MF and any incentives on a 24 Defender 110S X 36/10k. 75261.
    110 S or 110 X?
    If S, then P300 or P400?
    Sorry - P300
    Shocknawe said:
    Sorry - P300
    110 P300 S
    .00311 MF and 65% residual
  • caligirl0718caligirl0718 Member Posts: 1
    Can I please have the money factor and rv plus and rebates or incentives on a....
    2024 Land Rover Defender 110 P300S
    36M/12K
    Zip code: 85142
    36M/12K
    Zip code: 85142
    .00311 MF and 64% RV
  • SyltovSyltov Member Posts: 1
    Hi - looking for residual and MF for ‘24 110 X-Dynamic SE (P400) - 10k/36mo. Thanks
    .00311 MF and 61% residual
  • yosefckyosefck Member Posts: 27
    2024 Land Rover Defender 110 P300 S AWD
    36/10,000
    90210
    Rates, Residuals and Incentives please! Also, which trim has the best lease program.
    36/10,000
    90210
    Money factors are lower for some of the higher trims, but the residuals fall off a cliff, compared to this base model. This one will lease for the lowest payment, I'm sure
  • Mmac47Mmac47 Member Posts: 23
    Looking for MF/Res
    2024 Defender 110 V8 Carpathian Edition
    zip code 60189, 10k/33 mo and 10k/ 36mo
    Mmac47 said:
    Looking for MF/Res
    .00107 and 51%
    .00119 and 50%
    Please rates for p300 110 S
    24/33/36 7500 miles, zip 10305
    thank you.
    thank you.
    .00376 and 76%
    .00311 and 67%
    .00311 and 66%
  • kkilo1323kkilo1323 Member Posts: 38
    edited May 2024
    MF/Residual
    2024 P400x 110
    15/24
    15/36
    15/39
    12065 - Any incentives?
    kkilo1323 said:
    MF/Residual
    2024 P400x 110
    15/24
    15/36
    15/39
    .00209 and 58%
    .00183 and 50%
    .00189 and 47%
  • anderm30anderm30 Member Posts: 122
    Can you tell me the 36/12 numbers for a 130 X-Dynamic SE in 37919? Thanks!
    .00155 MF and 56% RV
  • MkremkoMkremko Member Posts: 7
    Defender 130 x 36/12 and defender 130 x dynamic SE 36/12 in 93730? Thank you!
    X - .00122 MF and 50% residual
    X Dyn SE - .00155 MF and 56% residual
  • BobC1BobC1 Member Posts: 12
    2024 110 S P400 24 month 10K miles MF and Residual 02420
    .00376 MF and 70% residual
  • JK213JK213 Member Posts: 7
    Hello, I’m looking for MF/RES for:
    Both 2023 and 2024 Defender 110 S P300
    36/10 and 36/12
    zip 91604
    Thank you in advance!
    36/10 and 36/12
    zip 91604
    2024
    .00311 MF and 64% residual
    Ask 2023 model questions at this link
  • chefauto1chefauto1 Member Posts: 18
    Hello can you provide the MF, RV, and any incentives for the 110 X dynamic SE and the S for a 10k/24m please? If a different configuration is optimal, please let me know. Thank you!
    Zip 33415
    Zip 33415
    S - P300 or P400?
    S - P300 or P400?
    Both please
    Zip 33415
    chefauto1 said:
    S - P300 or P400?
    Both please
    .00376 MF
    75% S P300
    70% S P400
    70% X-Dyn SE
  • Alex1412Alex1412 Member Posts: 6
    edited May 2024
    Can I please RV and MF for defender 130 s p300 and 130 outbound 36 months 15k miles
    Zip 90813
    Zip 90813
    36months 15k thank you
    Zip 90813
    P300 - .00311 MF and 63% RV
    Outbound - .00145 MF and 54% RV
  • randomgolferrandomgolfer Member Posts: 4
    MF and RES for 2024 Defender 130 X-Dynamic SE
    7500 / 36
    92260 and 90277
    7500 / 36
    92260 and 90277
    .00155 MF and 58% residual
    Zip 33415
    chefauto1 said:
    S - P300 or P400?
    Both please
    .00376 MF
    75% S P300
    70% S P400
    70% X-Dyn SE
    Hello, just wanted to follow up and request the 36m/12k numbers for the 110 p400 X-dyn SE please
    Thank you for the information. Do you get these numbers directly from the dealers?
    chefauto1 said:
    Zip 33415
    chefauto1 said:
    S - P300 or P400?
    Both please
    .00376 MF
    75% S P300
    70% S P400
    70% X-Dyn SE
    .00311 and 60%
