Visitor Agreement.
Say what? A $12,000 BICYCLE?! Is he aware that gold does not make for a good bike frame?
Yes. like everything else, it is INSANE. I've seen them in bike stores and can tell you that $12K isn't anywhere near the highest.
I was at my doctor a little while ago. I went through some tests and nothing further is needed unless anything gets worse. I guess I could be considered lucky in this instance. They have documentation.
I'm not really interested in pursuing additional compensation other than my car.
That was like the time the electric utility boom truck stopped in front of me and proceeded to back over my hood. The driver admitted fault to the cop and the utility wrote me a check without argument.
Admittedly, I know NOTHING about bicycles, but I know CF doesn’t cost that much these days (as a material). Amazon (and other online places) has CF bike frames in the $ hundreds, not $ thousands. Just sayin. Ain’t no way in hell I’d spend the same on a bicycle as for a decent used car or even a nice new motorcycle.
As it turned out I was able to get the car rotated enough that I could shoot into the pit entrance. No one was the wiser. Except for me- I never tried to drive that line again.
Wife broke wrist, made a claim, said no to initial insurance offer and settled for ~$12k.
BWM was totaled by insurance, became the Mazda CX-5.
People who lie about this stuff should receive fraud charges when found to be liars.
Yeah, @fintail for the new Federal position of Insurance Investigation Commissioner.
Well depending on what you want that could be cheap.
https://www.performancebike.com/pinarello-dogma-f-disc-cadex-sram-red-axs-road-bike-summit-red-54cm-pi-22-fdsc-54-bkrd-1/p1465769?v=1455928
————————————————-https://www.performancebike.com/pinarello-dogma-f-disc-cadex-sram-red-axs-road-bike-summit-red-54cm-pi-22-fdsc-54-bkrd-1/p1465769?v=1455928
You’d think for almost $17K they could provide a more comfortable seat like my Schwinn had. No wonder bikers walk funny.
Anyway, my point is, if you think you may have an injury that will show up later....then get continuous treatment, don't show up 3 years later and expect you can be compensated.
Thanks for the advice though.
When something starts hurting any more, I wonder if I did something, or this is just how I am now.
Actually those seats are much better for you as it allows better hip movement when peddling.
If you use a hose and there is a problem, warranty is void.
Another over hyped electric item.
She is now happy. Which at least buys me some time.
Hmm lack of Bimmerness lead to bummerness
Delete
https://finance.yahoo.com/news/hertz-loses-another-200-million-from-its-evs-172735716.html
2018 430i Gran Coupe
On my way back from satisfying my Chick-fil-A addiction this morning I was traveling on I-87 in moderate traffic at 70 when a motorcyclist flew by doing at least 100 if not more. Within a minute he disappeared around a curve a mile ahead. If anyone had changed lanes he would have been splattered amongst the trees. Then, when the speed limit dropped to 55 an Infinity blew by at about 90 while weaving in and out of all three lanes.
Of course there was the normal contingent of BMW drivers turning, switching lanes etc. without ever touching their turn signals.
I think I’ll stay home the rest of the day.😫😫😩
Sometimes is great to have nice neighbors and friends
I was converting a switch to a switch/outlet combo next to our peninsula down the shore and needed a 6” piece of wire to create a jumper for the neutral. Of course I didn’t have it… was going to the store and asked my neighbor if they had a piece and they did which saved me a trip to the store.
Also - nothing blew up and it’s all working. A win for today. A one beer job!
You’re lucky the power was in the box where the switch was. There are times when electricians put the power in the box where the light is (or whatever is being controlled by the switch) then they make a switch drop to the box where the switch is. If that was done, you wouldn’t have had a neutral in the box for the switch/receptacle combo you installed. It never hurts to get lucky.
I had just replaced the light and noticed there was no feed there… that’s what prompted me to do it since I knew the feed was in the switch box.
It’s now against code to have the feed at the light. All switches must have a neutral at the box
An accelerator pedal
as it is meant to be, bottom hinged.
I learned early. Grandpop was an electrician.
It’s not rocket surgery.
You need a good teacher and you have to ask the right question. Also you have to know how many cables (romex cables with 2 or 3 current carrying conductors in each cable) and know where the cables go (like to power, do the cables run to lights, switches or receptacles). Then it’s a simple matter of connecting them together correctly. Easy peasy.
Essentially all I did. I needed a small piece of wire because the neutral was wire nutted together in the back of the box and I wouldn’t put two wires under one screw.
Where I come from that’s being a wire-swapper.
Sometimes just trying to fiddle with the fixture bracket far exceeds the actual wiring.
————————————————You’re right, putting 2 wires under a screw is a definite no-no. However, some receptacles, usually the heavy duty ones, have the screw attached to a plate and there are 2 slots under the plate that allows 2 wires to be put under that plate (you probably know what I’m talking about). So, when you tighten the screw the screw pushes the plate against the wires. In your case you’d have had to untwist the 2 neutral wires that were wire nutted together and straighten out the twisted wires so you could have put them under the plate. Sometimes when you do that the wires break off which could have left them a little short. So, I’d have done what you did by using a white pig-tail to make the neutral connection to the receptacle.
————————————————-Yeah, I know what you mean. More about needing mechanical skills than wire swapping skills.
Love those type of devices that have the plate. All the speed of back wiring but with the secure connection.
As a bonus I cleaned up a lot of junk that had been bugging me.
Where’s the pic of that masterpiece?
I'll probably pick up the new one tomorrow. The new one - exactly like the old one.
I'm girding my loins for the fight with the F&I guy who doesn't do any "F" and does not even call your insurance agent anymore, so they don't do any "I" either.
Don’t you?
