By the way, this is an Isuzu-made 3.5L V6. DOHC, 24 valves. I'm not sure of the other technical highlights that might be of interest to you.
Other thought is to go with a 40 wt. oil. You would have to go with synthetic here. Mobil 1 0W-40, Delvac 1 5W-40, or even Rotella 5W-40, Amsoil/Redline/Shaeffers also works. An alternative which has reduced oil use in a 94 Toyota is 3 quarts of Mobil 1 10W-30 and a quart of 15W-50. I just dumped Rotella 5W-40 in it yesterday-we'll see.
Al
This is the kind of advice that people like me - well-meaning do-it-yourselfers who understand very little about how automobiles work - need.
I'll have to ask the Trooper folks to find out if the 3.5L on the 98 Troopers has cap/rotors/wires. IIRC, the motor is a little unusual - I think it has a coil pack directly on each plug and therefore no traditional 'spark plug wires.' Or something like that.
About the only thing I know is the location of the engine oil drain plug, filler cap, and oil filter.
The vehicle used conventional oil - Castrol GTX - from 10-16k miles; synthetic blend - Castrol Syntec Blend and Valvoline Durablend - from 16-50k miles; synthetic - Mobil 1 SJ-rated Tri-Synthetic - from 50-67k miles; and Citgo SuperGard SL-rated conventional oil from 67k-present (almost 75k).
Any suggestions on what oil will help clean things up? I'm thinking one of heavy-duty diesel-oriented oils might be a good idea. E.g. Mobil Delvac (is this the same as the '1300' stuff?), Chevron Delo, Shell Rotella T. I'd like to try something that's readily available off the shelf, which rules out Amsoil, Redline, Sheaffer's, etc.
I'd be willing to run this clean-up oil permanently if cost isn't too high. I'm no longer willing to run extended drain intervals long enough to offset the per-quart cost of synthetics.
The only cleaner additives I've heard NOT characterized as snake oil are Schaeffers Neutra and Auto-RX. I'm not anxious to buy a case (12 containers?) of Neutra, nor am I anxious to lay out 20 bucks for a bottle of Auto-RX. Plus I'm looking for quick results - I can get a good cleansing oil today vs. ordering via phone or Internet for Neutra or Auto-Rx.
By the way, some of the Chevron Delo 15W40 gallon containers at Wal-Mart, as well as the gallon and quart containers of 15W40 Shell Rotella T, were SJ, not SL rated. The datestamp on some of the containers showed August and September 2001! So if anybody's interested in using SJ instead of SL, some Wal-Marts have plenty of old stock.
It was disappointing to see no 5W30 Chevron Supreme at 2 different Wal-Marts this week. There isn't even a sign for it on the shelves. Both stores did have 10W30 (not a lot) and 10W40 (2-4 cases).
I don't understand at all how combustion engines work, but it's been suggested by a few folks online that an engine consuming lots of oil is very likely, perhaps certain, to have significant carbon buildup.
The engine seems to run fine and I've noted no other 'problems' besides the oil consumption. Fuel economy is in line with other Troopers with this 3.5L engine, no funny noises, no visible signs of oil leaks, no trouble starting, etc. I'm not sure if any of that stuff is relevant.
I like the idea of helping to clean out the oil-eating motor in my Trooper with a high-detergent oil such as the Delvac 1300.
Winter here in Michigan typically hits 10-20F for the lows. Occasionally below that but not real often. I'm assuming the truck will start just fine running the 15W40 but I'm a little nervous about excess wear since the 15W40 is quite a bit thicker than I've run in any vehicles.
Also, how will I be able to tell, without doing oil analysis, if I'm subjecting the engine to lots of wear by running the 15W40? Will it be apparent through hard starts, noisy startup, or other obvious signs? How else can one tell?
Any thoughts on this?
Pumping viscosity is 19,000 cP at -25C and 52,000 cP at -30C. Cranking viscosity is 6,000 cP at -20C and not rated at -25C.
I changed to this oil a couple hours ago and I'm not expecting any problems during the cold weather here, which is rarely below 0F. I'm really hoping this oil cleans up the motor, and I plan to change the filter and top up the oil after about 1,000 miles. More than the cleaning, I'm hoping for reduced consumption. My last change interval was 3,100 miles with Citgo SuperGard 5W30. My Trooper used 2.5 quarts during the interval, which is a quart every 1200-1300 miles.
My Trooper owner's manual recommends 10W30 unless cold weather is prevalent; then it recommends 5W30. But the manual also shows most common weights, up to 20W50, as being acceptable for various air temperatures. 15W40 is okay for 0F to 100+F.
At least for a little while, I think the Delvac 1300 will be a good way to clean things up. Today I started the engine cold (probably 35F in my garage) and the engine fired up as quick with the Delvac 1300 15W40 as with the 5W30 Citgo SuperGard that preceded it. Did about 10 miles of city driving and the engine and vehicle seemed to be running the same as before.
After driving the truck a few miles tonight, I checked the level again and was relieved to see the oil on the dipstick was much closer in color to the fresh oil that was added in yesterday's change.
Is this normal, or does the dark oil on the dipstick immediately after the change suggest that things in the motor are dirtier than they should be?
In the back of my mind is a nagging idea that using an oil whose intended primary use is in diesel engines may not be the best thing for a gas engine, even though the oil is approved for gas-engine use. This doesn't scare me to death, as I was willing recently to drop Delvac 1300 into a vehicle that I dearly love and plan to drive for 200k+ miles. But I'm still not convinced it's a great idea to run a diesel oil in a gas engine over the long term.
"The diesel engine oils contain significantly greater detergency and total base number (TBN) which helps keep the engine clean. This additional detergency is not recommended for gasoline engines since it could increase the tendency for spark plug fouling."
http://www.amsoil.com/products/atm.html
I'm 120 miles and several starts, including a few with the engine being dead cold and air temp around 30-35F, into the Delvac 1300 15W40. Truck seems to run the same with the Delvac as it always has with 5W30. It's a bit early to tell on consumption, but the dipstick does appear to be in the same spot as 120 miles ago. So I'm hopeful that the thicker oil will reduce my consumption.
By the way, the Delvac 1300 15W40 is API SL-approved. Like most other diesel oils, it meets a host of other specs and guidelines that many gas-engine oils don't bother with.
"gasoline engines are much more hard on oil than the diesel engine, turbo or not. Most of that comes from the lack of solvency remaining in reformed gasoline today. Of course a turbo or Supercharged gasoline engine will cook oil faster."
"Most diesels have large(er) sump capacities than do gasoline engines which is one reason why the latter is so tough on oils."
Just some thoughts...
I know you weren't asking me, but I think you may have hit the nail on the head. Of course, we don't know for sure.
After 250 miles running Delvac 1300 15W40 in my gas-engine Isuzu Trooper, the truck is still running fine. But that probably doesn't fit your definition of a long-term test
And may the new SL year bring you improved additive packages...
Anyway, I am in Ca. I have an Odyssdy and the manufacturer recommends 5w30. Based on what I read so far, it is to enhance gas mileage with lower viscosity.
Just wondering if I should switch my other cars to also 5w20. Seems like there is really not much harm to use 5w20 instead of 10w30. Actually would there be any problem in switching back and forth between the two viscosity oil. With the lower viscosity, would there be enough lubrication on my car engines???
