Visitor Agreement.
5W20 will not harm your engine.
It's just not as stable or long lasting as 10W30.
And the mileage increase with 5W20 would be almost too small to detect.
The most manufacturers recommend the 5W30 or 5W20 weights in order to accomodate the colder climate requirements (the # before "W" represents the flowing charactheristics of oils in the cold engine - the smaller the number, the thinner the oil.)
I'm guessing Castrol GTX would be best, but I've noticed the oil pressure drops(zero) when warm (at idle). People have told me to use 20w-50, but is that a good idea with temps dropping to 20 degrees? I can't image that would help... seems it would be harder for an old pump to get the heavier oil to the bearings! Any ideas while I'm nursing the engine to a rebuild? Are the "high-mileage" oils as good as they look?
It sure doesn't run like it's wornout!
http://www.cybrrpartspro.com/Manual%20Lookup/cal_ModelLookup.html
If anyone knows about oil I figured it would be here... please don't take it personal! I'm tolerant of all the viscosities
"People have told me to use 20w-50, but is that a good idea with temps dropping to 20 degrees? I can't image that would help... seems it would be harder for an old pump to get the heavier oil to the bearings! Any ideas while I'm nursing the engine to a rebuild? Are the "high-mileage" oils as good as they look?"
15w-40 was the thickest oil suggested for that engine. 20 degrees being the lowest outside temperature. I've never heard much about 15w-40, but remember reading 10w-40 was not good. Something about to many additives needed to get such a large spread.... any ideas if that's the case with 15w-40?
My unofficial knowledge of the GM basis for requiring 10W-30 to replace America's sweetheart weight (10W-40) may be a parallel argument to the probable(?) Ford/Honda position. I was told that GM determined the elastomers used to extend 10 weight oil out to the equivalent of 40 weight were prone to gumming in the engine. GM felt that shorter elastomers, such as those that would extend 10 weight out to 30, were not so prone to getting "sticky." I heard these tales in 1985. I had a hard time with this upheaval and feared for longevity problems. But I have never been one to keep a vehicle long enough for long elastomers to get me-- yet. I am now one of the many who fear the future under 5W-20... deja vu?
Off topic- They still have castrol and penske filters also, but no deals.
mike1qaz
5 qt container 10w30 or 5w30 either, at $4.17 a container.
What a price.
This oil will probably become Shell within the next several months after the Shreveport plant is closed down.
Is a present day cheap oil like Super tech Sl rated oil
better than the older specification SG, but "better brand" oil?
In other words does the specification upgrade form SG to SL override the cheapening resulting from going from a "better" brand oil to say super tech?
I have a '90 nissan p/u with 198,000 miles. Are the extended/high mileage oils products worth it?
I run 10w x 30 right now and wanting to switch to a heavier weight.
Should I switch to the castrol 10W-40 high mileagle? They also have a 20W-50.
Personally, 10W30 seems okay to me, unless you live in an area that sees REALLY hot temperatures.
texasjeep I think you could go to one of the "heavy duty" oils, like Valvoline All Fleet 15W-40. With miles that high, the wear tolerances in the engine might be better lubed with the slight weight increase.
If the weather is warm enough I like a 15W40 better than a 10W40 although the high detergency of a diesel oil could (possibly) knock loose some sludge out of a high mileage engine. If nothing's leaking or giving you trouble I think it's hard to beat plain 'ol SL rated 10W30.
Regular good maintenence will more then suffice
If I stil enjoyed changing oil I would still consider Dino Oils. But those days are gone forever.
I don't use synthetic oil any more, and even though conventional oils are getting better and better and are narrowing the gap, synthetic is still the better product.
5000 mile intervals with Mobil 1 should serve your vehicle quite well. You could probably stretch the interval to 7000-8000 miles without worry, but if the extra cost doesn't bother you, 5000 miles is an okay starting point.
I used Mobil 1 in the past and my comfort zone was 5000-6000 miles. Wasn't willing to go any further than that without doing oil analysis, and wasn't willing to do oil analysis.
