A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
1-Decene Homopolymer Hydrogenated is the main ingredient and that's not a PAO
The head Subaru tech at my dealer has seen the inside of an engine that used Mobil1 and in his words, "It was so clean that you could eat off of it."
OTOH, my dad used Castrol GTX 10W30 in his Chevy pick-up (V6) and changed it every 3k. He lives in SC and tows cattle a few times a year. He sold it at 215k because he just wanted something new. He never had to touch the engine.
-Dennis
(soon to switch to synthetic in my turbo @7500 miles)
Aside from the pride in knowing that one's engine has like-new tolerances, what is the benefit? Fewer/smaller leaks? Longer-lasting parts? I often wonder just what the benefit is of an engine's tolerances remaining tighter (i.e. closer to original), less wear on internal engine parts, a 'cleaner' engine, etc. etc. etc.
Why should I be concerned about my engine's parts being subjected to more 'wear'? What is the harm to the engine? And as long as the engine runs and performs well, why should I be concerned with how 'clean' it is or isn't?
As far as the cleanliness of the engine goes, thousands of Toyota owners have wished their engine was kept cleaner preventing them from having to buy an $8K engine when it sludged up.
Specifically, I expect our 1998 Isuzu Trooper to run for 200k miles or more. I do not think I am hindering that goal by running well-regarded conventional oil and changing it every 3,000 miles. I don't think my previous strategy of Mobil 1 changes every 5,000 miles would make the engine any more likely to reach 200,000 miles trouble free.
The main reason I tried it in the first place is because my engine uses about 1/2 quart per 1000 miles. Not a big consumption problem, but I wanted to see if it does what Valvoline claims it does. It did absolutely nothing to slow consumption. I have read where some folks have had good luck getting it to slow down or stop oil leaks. I don't have any leaks, so for me, it did nothing.
I'm probably gonna catch some flack for this one, but here goes. I changed out this oil at 3K miles, and it was pretty much pitch black in color. My last oil change, I used Chevron SL, and I didn't change it out until 5K miles. It's color was a dark honey color, which isn't much darker than it was when it came out of the bottle. Keep in mind I'm having to add about 1/2 a quart per 1000 miles in each case. I have to say, these results look very familiar. Back when I was using any ol' dino, the oil was always pitch black at 3K. When I switched to Mobil 1 full syn, I wouldn't change my oil until the 6K mark, and at that point, the oil was a dark honey color. Could it be Max Life is just a plain ol' dino in a fancy bottle, and the Chevron SL is closer to a syn than a dino?
I know there have been many points of view given about the color, or darkness of the oil. Some of you have said the darker the oil, the better it's doing it's job by suspending the crud instead of leaving it in the engine. If this is true, then does this mean that dino's do their job better than syns because they get darker sooner? I am going to somewhat disagree with this theory because I believe a true syn like Mobil 1 is superior to a dino. I believe syns suspend just as much crud, they're just able handle more without breaking down and becoming saturated because of their superior structure, which is why they appear to stay cleaner longer. I think the trickiest part about oil is determining where the line is that separates dinos and syns. What is a dino, and what is a syn? Is a hydrocracked dino really a syn? In the case of the Chevron SL, it certainly displays the characteristics of a true syn. In the case of the Valvoline, it acts like a plain ol' nothin' special dino.
Someone tell me where my thought process has gone wrong, because I'm thinking this Chevron SL is the best stuff available for the price.
You seem to be demanding more proof from the Chevron Supreme than of the synthetic oil(s) that you already believe in. Maybe that's okay, but part of me thinks it's a little inconsistent. Not picking on YOU here, because I think many folks probably look at it the same way.
I'm not trying to disagree with your conclusion that Mobil 1 is an excellent oil; I agree that it is, but I really am not 100% convinced of that. And much of our 'evidence' or 'reasoning' for why it's a good oil really isn't all that powerful. I'm also not convinced that Chevron Supreme cannot go 7000 miles and do well. Will I try it for that long? No, not yet. Not when it's $1.08/qt and I haven't heard others doing that with success.
You are really contradicting yourself with statements like "I'm not trying to disagree with your conclusion that Mobil 1 is an excellent oil; I agree that it is, but I really am not 100% convinced of that." and "I'm also not convinced that Chevron Supreme cannot go 7000 miles and do well. Will I try it for that long? No, not yet."
Either you think that Mobil1 is an excellent oil or you don't. There is no eveidence that Chevron will go 7K. I don't blame you for not pushing it.
I don't share the opinion that Chevron is good for 5K miles or that it is as good as many of the other "so called syns" but I will agree that it appears better than other dinos.
Sometimes you just have to agree to disagree.
I wouldn't do extended drains (over 3k) on any oil without using an analysis at 3k to see if an extended drain was feasible. Making assumptions on an engine/oil combination without knowing the facts could be costly.
Previous poster stated that if hydrocracked oil were significantly lower priced that PAO oil it would be a good buy. I agree, but the reality is that on retail in NYC, Mobil 1 is about $4.89/qt on a good day, while Castrol and other like it are at $4.65-$4.75/qt. The price differential is not enough. IMO, you'd might as well go for the Mobil 1 and get the almost assured performance of a PAO. If hydrocracked synthetics were about $3.50/qt, I would actually consider it (as long as it is not Castrol). That would actually bridge the gap between, syn blends and PAO prices. If Castrol, QState/Pennzoil, and Valvoline did that they would steal alot of the syn business away from Mobil and still make as much or greater profit that Mobil per sale due to the low cost of production of hydrocracked synthetics.
Does the PAO somehow "maximize" the additive's efficiency? I am not a chem engineer, so I don't have much knowledge of how the high temperatures in engines have an effect on on additives.
Everyone has their own comfort level.
Also, let's say that I accept that Chevron goes 5K with no problems (which I don't yet). This would be the economical analysis.
.................Chevron...Mobil1
Price/qt........$1.09.....$3.58
qt/change.......5..........5
$/change.......$5.45....$17.9
miles/change...5000.....7500
mpg...............14........15.5
gas gals/change.357.1...483.9
$/gallon.........$1.6......$1.6
$ gas/change...$571.42.$774.19
changes/100K...20.......13.333
$/100k miles...$7251....$6690
Mobil1 still saves me $561 dollars over 100k miles. So, how is the Chevron cheaper again?
Someone please show me the data. Regardless of what the basestocks are made of, I would like to see the proof.
Dennis
Secondly, as far as mpg, I quoted exactly what I got when I switched from dino to Mobil1. The change was dramatic and easy to see in the first tank of gas. Are you saying that Chevron Supreme delivers higher mpg than standard dinos. If so, I have seen anyone else claim that yet. Give me some evidence man.
Further you state
Then, there is the Mobil 1 gaurantee.
I assure you that this warranty is not worth the paper it is printed on, none of these warranties on oil are whether they are Amsoil, Quaker State or Mobil. You will never, ever be able to show the oil caused the engine failure.
Anyway, if you are indeed getting the mpg from Mobil 1, that is great. And, with brands of oil it always comes down to whatever you can live with and what makes you happy. Personally, Mobil 1 is not it for me as my Camry would eat it up and spit it out in the form of sludge at 7,500 miles but again, each case is individual.
We have zillions of cases of 150,000 plus mileage engines going strong on the cheapest dino available with Fram filters changed EVERY 3000 MILES. Go figure!
I could make a copy of the receipt and find a way to post it here for those of you who don't believe I got the oil for that price.
I also agree that the gaurantee is not worth much since I will not be able to prove the damage was from oil but just the fact that they are willing to put it in writing is worth a little to me.
For me, Wal-Mart never has the stuff I want on sale at the time I want it. I've never seen Mobil 1 in a Walmart or Target ad.
If the gas is $1.60 per gallon, at 14 miles per gallon your gas cost is $0.1143 per gallon. At 15.5 MPG your gas cost is $0.1032. That totals $11,430 in fuel at 14MPG and $10,320 in fuel at 15.5MPG. That is $1,100 plus right there. Take out $129 for extra oil cost and you are at $980 in savings.
Of course, that is based on your 10% increase in mileage. I too have never seen that kind of increase.
How much does anyone think that the car manufacturers would pay to have their CAFE (Corporate Average Fuel Economy) number increase 10%? If Mobil 1 could really increase your mileage by 10%, then every manufacturer would test their cars with Mobil 1 in the engine and rate their mileage based on that. In turn, their CAFE number would go up 10% as well. Manufacturers spend millions of dollars to increase their MPG figures a few points to meet the ever rising government mandated CAFE number. Raising it instantly by 10% would be like finding the Holy Grail. I am skeptical of that claim.
I usually start looking @5K miles in order to have a chance to buy it before my 6K changes.
BTW, I'm also toying with extending my changes to 7.5K with the M1.
I also use Chevron Supreme and Pennz when I miss the M1 display, but for 4k miles tops.
I have an 01 Accord and Tntitan posted results at 5k for the chevron oil on Bob's board. The results were not great at 5k. The consensus on that board was to limit it to 4K changes.
Now I know that his results don't necessarily condemn all chevron users to less than 5k changes, but I'll err on the side of caution until other user analysis proves it can go the distance. IMHO for 3-4K changes chevron is a supreme choice. For longer, go with the M1.
mike1qaz
I personally do not like Castrol Syntec, not for it performance, but due to Castrol muddying the label "synthetic oil" for the consumer. Castrol has significantly lower production costs when they produce their "synthetic oil" vs Mobil. I would like for Castrol to pass along the savings to the consumer, then I would more inclined to look at Castrol in a more favorable light.
The conventional dino oil as of the SL branding is hydrocracked group 2 oil. Pennzoil, Chevron/Texaco, Castrol, Motorcraft/Conoco all start with group 2 base oil.
mike1qaz
Also, for those of you that refuse to believe that I got the 1.5 mpg additional when switching. Someone said they could believe a 0.5 mpg increase. Well, I would say you should try it and see what you get. However, if you do only get 0.5 mpg increase, then you save $394 in gas and subtract off the extra $129 in oil costs, you still have a $265 savings.
The point I'm making here is that Chevron Supreme is not saving you money over Mobil1 so don't try to make that argument. It's just not true. Do the math for yourself.
As far as the price of Mobil1 goes, I found another store tonight, BJ's Warehouse Club, that was selling it at an everyday price of $23.39/ 6 qt case. That's $3.90/qt. Those of you who haven't seen this kind of price, its because your not looking for it. Does anyone go around to 4 or 5 different stores to shop for a product they don't intend to buy? Others who do buy it don't really want to spend the time to find it so they just spend the higher price and still get the Mobil1. Please stop believing this myth that you can't get Mobil1 for less than $4/qt because its just not true either. It would appear that some here work for Chevron or maybe they own stock in them.
I am an open to a presentation of facts just not these myths that have been talked about where Chevron is more economical than synthetic.
