A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
This an analysis I had done on my Bud's '01 Monte Carlo. (3.8L) The car is driven like "Aunt Minnie". Almost all short trips of less than 5 miles. He changes the oil every 6 months regardless of the miles.
Schaeffer labs did the report
Miles on Car 7220
Miles on oil 1503
Oil Filter: A/C DELCO Ultra Guard gold
copper.......90
iron.........16
chromium......1
aluminum......3
lead..........4
moly.........79
phospherous.943
zinc........945
magnesium...372
calcium....2770
anti-freez ..0%
Fuel Dilution..positive
H2o...........0.2%
silicon......14
viscosity cst...8.63
sae/iso......20w
sulfur.......16
oxidation.....0
nitration....19
Comments were viscosity reduction due to fuel dilution
Oil s/b changed
This is the more reliable GM V-6 historically.
I do like it when things make sense though. {:O}
They only carry Chevron in the 10w-30 flavor, too. What 'bout use folks who need 5w-30? I'd gladly switch my Honda over to Chevron if I could get the right weight.
And there's no (none, nada) 5w-40 that our Passat wants! Bah! Where's the head Wallie?
Someone pointed out on another board that Target is clearancing its Havoline. Picked up 18 qts of the 10W30 (Texaco-made, not Equilon) for 68 cents a qt over the weekend.
VW Passat manual is quite strict:
no more 5W30. I asked my dealer and they use 5W30 and not 5W40. Where do you buy it ?
I tried Walmart, BJ's. Nothing.
Next stop - AutoZone.
Krzys
Valvoline Synpower comes in this grade, and is available at NAPA auto parts stores. If not on the shelf, they can order it...part #966. It's full synthetic.
Pani means Lady so your greeting should look like this
Dzien dobry! Jak sie Panu powodzi ?
Pan(u) means Mister.
Krzys
Anyway, good luck with the oil search! I found a supplier on the web who happens to be very close to my home. So, Valvoline 5w-40 will be the next oil in my engine, and I won't have to pay shipping!
You typically find it with the farm and truck oils since it designed for the big rigs, but still meets the SJ or SL (I don't recall which one right now) specs for Spark ignition applications.
See it here http://www.rotella.com/rotella_t_synthetic.html
"Is SynPower a full synthetic? Is SynPower motor oil PAO or ester based? Does it require a special filter?"
"Yes, SynPower is 100% synthetic. Synpower uses a proprietary combination of various types of synthetic base oils to obtain optimum performance.
No, a special oil filter is not required with Synpower."
But you'll notice that it doesn't actually answer the PAO/ester, pointblank.
ty
You don't say what engine (v6 or v8) or model year you have. My guess, and it's strictly just that, is that 10w-40 is not going to be the recommended oil. Most likely 5w-30, since that's been the trend for awhile. The Walmart filters have their fans here on Edmunds (there's a thread on oil filters here, too). If you want to splurge, you could get a Pure One or Mobil 1 oil filter (it's up to you).
You might want to post on the Lincoln boards here on Edmunds and see if another owner could help you out, for now. Good luck!
Edit - I checked Mobil 1's website - it looks like from 2001 onward, the oil recommendation is actually 5w-20 for both engines! It goes on to say that 5w-30 may be an alternative, but to check with your dealer.
Interestingly,the 2000 model year shows 5w-30 as the recommended oil.
Just pulled the product sheet for the Synpower from the web...it says it "is a premium fully synthetic motor oil that is formulated with the highest quality synthetic base oils and enhanced with the most advanced additive technology..."
Maybe I'm dropping them a question on their website for clarification. Here's the text of my question:
I'm sorry to bother you with this question, but the answer is not really clear to me in you FAQ.
The FAQ has this question:
Yes, SynPower is 100% synthetic. Synpower uses a proprietary combination of various types of synthetic base oils to obtain optimum performance."
Castrol Syntec has been cleared to advertise that it is synthetic, yet apparently isn't PAO or ester based.
So I'm looking for a "Yes" or "No" answer: Is Synpower (specifically in the 5w-40 formulation)PAO or ester based?
Thanks for your time!
I'll post any replies that I receive.
Valvoline makes a lot of private label oil and as far as I know all is identical to the name brand stuff. I think Valvoline is inferior to top oils like Pennzoil or Chevron. Reports @ Bobistheoilguy seem to indicate that it shears down rather quickly. Unlike SuperTech it lacks Moly, but that trait is shared by some good oils like Chevron.
I think that SuperTech, Valvoline and Shell (probably future ST oils) all constitute adequate but hardly outstanding oils. I think that Valvoline is probably inferior to the other big 3 dino sellers-- Pennzoil (best), Quaker State or Castrol.
I consider Valvoline to be a premium brand among the best mineral oils on the market, and rate it equal to Castrol, just below Chevron/Havoline. I also have great respect for Shell oil, and use it as an alternative. The undercurrent here is price. I always look for what I consider to be one of the acceptable brands, and I currently expect to buy it under a dollar a quart (after rebates). If this was on a chart, I'd be buying the "optimal" product, where the variables are price, versus status of brand in my eyes.
They also have added some moly to their mix since "SL" rated oils started to ship.
Chevron has yet to add moly to their dino (group2) product according to used oil analysis at Bob's site, but I assume their ZDDP package may have stayed pretty robust. Their product seems to hold up well to 4K miles.
Back in the spring of 1993 the Ford dealer, from whom I bought my brand new 93 Explorer, told me that Ford Corporation did not approve of Pennzoil motor oil for use in Ford Explorers.
If you have a source, please post it. Otherwise, you could ask this question on Bobistheoilguy.com
They used to have a Pennz rep over there that was willing to give specs. I forget his username.
